Possible to Compile a List of 4 cyl performance upgrades / makers
Discussion in '4 Cylinder' started by Idaho, Aug 22, 2014.
  1. Aug 22, 2014 at 11:10 AM
    Idaho
    Idaho [OP] Well-Known Member
    North Carolina
    Just looking to see if one could be put together by someone with the knowledge already or maybe there is one that already exists I haven't found yet.
    Basically as a new owner of a 2.7l 4 cylinder I haven't seen too much at all in the means of intakes, exhaust, performance filters, etc... that are for the 4 cylinders.
    I know URD has a supercharger kit, was there ever a TRD kit at one point?
    Just might be a good sticky to have as a reference in the 4 cylinder section as to who makes what being the various sites are flooded with V6 items.
  2. Aug 22, 2014 at 6:58 PM
    hortona
    hortona Well-Known Member
    99 tacoma SR5 w/ 3rz-fe
    Lce headers, k&N cold air intake with injen filter
  3. Aug 22, 2014 at 7:01 PM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    Plenty of Exhaust, LCE and Doug Thorley make performance headers. There was never a TRD S/C only the URD. With exhaust and headers a new MAF calibrator would help too.
  4. Aug 22, 2014 at 11:12 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    These are all the mods on my normally aspirated 2.7:
    1. LCE long tube header
    63eecebd-d227-4758-af55-202fc9a4543c_zps_c76abb5afe56ac871da739345075a31da92c58db.jpg
    2. Injen Long tube intake
    8a098052-48fe-43ec-a082-e93bd8aaf3e0_zps_432e7fed9e245571ffee1f2620ac3b05b5e88170.jpg
    3. Tooter 2 inch thick intake manifold spacer
    4. Flowmaster 50 Series Delta Flow muffler
  5. Aug 23, 2014 at 11:31 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    outside of forced induction the best gain is probably a good header and exhaust. The rest are pretty much gimmicks.
  6. Aug 23, 2014 at 11:35 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Or regear. KnowutImean, vern?
  7. Aug 23, 2014 at 11:43 PM
    tooter
    Greg
    Los Angeles
    I agree on the header, especially if it's a long tube, but you could even skip the exhaust. I dyno tested the stock muffler (RED) a Magnaflow (BLUE) and a Flowmaster (GREEN) and as you can see, the results were pretty close. The stock muffler is actually very well matched to the operating characteristics of the 2.7.
  8. Aug 24, 2014 at 9:10 AM
    vern650
    brandon
    hyrum, ut
    true that, on vehicles nowadays most of this stuff is all tuned to work together. Not like back in the day where they just slapped stuff like cat. converters on for legal reasons and you actually got gains from modifying them.
  9. Aug 24, 2014 at 10:01 AM
    tooter
    Greg
    Los Angeles
  10. Aug 25, 2014 at 9:58 AM
    vern650
    brandon
    hyrum, ut
    and that's what counts ;) thus the imco on my taco
  11. Aug 27, 2014 at 8:54 PM
    hoenah808
    hoenah808 Well-Known Member
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    any gains from the intake? where did u get the injen intake from? also u gonna be making anymore spacers around the end of this year?
  12. Aug 27, 2014 at 9:42 PM
    tooter
    Greg
    Los Angeles
    I don't know, as I ran that same intake on all of the dyno runs. There's a sign up list for the spacer in the 2nd Generation Marketplace where you can add your name if you're interested. It's not a commitment to buy. I'll bump it up to the top so it'll be easy to find.
    Greg
  13. Aug 27, 2014 at 9:47 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Has no one tried to turbo this motor yet or is the ecu pretty temperamental compared to the 1st gens?
  14. Aug 28, 2014 at 1:51 PM
    tooter
    Greg
    Los Angeles
    URD makes a complete 2.7 supercharger kit.
  15. Aug 28, 2014 at 4:26 PM
    MadTaco461
    CA
    Kinda stock
    That is impressive. I thought 4.7k was a lot, but you get all the stuff and its tuned. Literally bolt on.
  16. Aug 28, 2014 at 9:54 PM
    tooter
    Greg
    Los Angeles
    It's a very complete well thought out kit. URD produces high quality products. :)
    Greg
  17. Aug 29, 2014 at 1:45 PM
    Idaho
    North Carolina
    So am I correct in saying that there isn't a bolt-on exhaust for the 2.7? Seems everyone is having one made from whatever is their muffler of choice.
  18. Aug 29, 2014 at 4:35 PM
    wgreenlee1021
    wgreenlee1021 Off the Meds Again...
    Tailgate down mod....
  19. Aug 29, 2014 at 6:03 PM
    tooter
    Greg
    Los Angeles
    LCE makes a bolt on 2.7 cat back exhaust.
    Gibson makes a bolt on 2.7 cat back exhaust.
    Magnaflow makes a bolt on 2.7 cat back exhaust.
    MBRP makes a bolt on 2.7 cat back exhaust.
    Borla makes a bolt on 2.7 cat back exhaust.
    Shall I go on?... ;)
    Just search for "(your year) Toyota Tacoma cat back exhaust"...
    ...and they'll all come popping up at you.
    Greg
  20. Sep 1, 2014 at 10:15 AM
    SlowComa666
    SlowComa666 Well-Known Member
    San Antonio TX
    2014 SR5 Access Cab 2WD
    tooter did you happen to do a baseline pull before the mods?
