Possible to convert non-steering wheel control to one with audio controls
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CNEDEER, Feb 13, 2013.
  1. Feb 13, 2013 at 5:42 PM
    CNEDEER
    CNEDEER [OP] If ya ain't first, your last!
    2005 Tacoma DC 4x4
    I'll explain it a little better than the title. Basically I am looking for a 2007 or newer tacoma double cab 4wd, but as petty as it sounds, I really don't want to buy one that does not have the steering wheel audio controls. To me it is convenience I love to have.
    Thus, with that said, is it possible to buy one without the steering wheel audio controls and convert it to one that does. My guess is that it is possible, but what all would it involve and how much would it cost do you think?
  2. Feb 13, 2013 at 5:46 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    I started and never finished. No one know for sure if its possible or at least I couldn't find any definite answer. I have the steering wheel then found out i need the correct clock spring. From there I'm not sure if its wired from the column to radio.
  3. Feb 13, 2013 at 5:48 PM
    CNEDEER
    2005 Tacoma DC 4x4
    Yea I wasn't sure what it involved. I was hoping someone on here has done it.
  4. Feb 13, 2013 at 5:56 PM
    t_e
    Erik
    miami,fl
    I'm pretty sure I can finish if I get the $150 clock spring.. I have the third plug behind the radio I just haven't traced it to where it stops. Could be as simple as plugging it in at the clock spring column side. I found a steering wheel from a 4runner and a new airbag cover for about $150
  5. Feb 13, 2013 at 5:58 PM
    CNEDEER
    2005 Tacoma DC 4x4
    So thus far, you have about $300 invested?
    Where did you find the steering wheel and airbag cover?
  6. Feb 13, 2013 at 6:02 PM
    t_e
    Erik
    miami,fl
    So far I have $150 in. Refuse to buy the clock spring until I know it will work. Just haven't gotten around to it. I found the steering wheel on car-parts.com and the airbag cover on ebay
  7. Feb 13, 2013 at 6:07 PM
    CNEDEER
    2005 Tacoma DC 4x4
    Gotcha. Hopefully someone will chime in
  8. Feb 13, 2013 at 7:02 PM
    t_e
    Erik
    miami,fl
    FYI I just found a schematic so I don't have to trace wires. I have to check the plug going into the steering wheel for the 3 wires. If my pre-runner is pre wired as its "supposed" to be then all I need is the correct spiral cable. I will attempt to check in the next couple of days.
  9. Feb 13, 2013 at 7:03 PM
    CNEDEER
    2005 Tacoma DC 4x4
    Great! Please keep me informed!
  10. Feb 13, 2013 at 8:22 PM
    DR Da_da
    DR Da_da Infrequent Member
    Northeast FL
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    I've been wanting to do this since I bought my truck new! I've asked around and searched the world wide interwebz, but couldn't find a definitive answer. I did find this, though. It's definitely helpful, but it's for a Toyota Prado (the wiring harness is different). I haven't looked at it in a long time, but for the electrical engineers here on TW it may provide enough info for them to complete the job on a Tacoma.
    As far as having the correct clock spring, will the recall clock spring I receive tomorrow (yes, going in for the clock spring recall tomorrow morning at my local dealership) be the correct version to accept the steering wheel controls? I still don't know if my truck is pre-plumbed between the stereo and steering wheel, but I know it's pre-plumbed for many other things (i.e. mystery connectors behind dash switch blanks).
    I'll be :popcorn:
  11. Feb 13, 2013 at 8:28 PM
    blitzburgh99
    blitzburgh99 Well-Known Member
    Houston, TX
    1999 Tacoma TRD 4x4
    239,600 (as of 7-20-13 and counting)original owner miles
    For those interested in the upgrade, I have a leather wrapped steering wheel with the controls available for sale. Excellent condition. No air bag, but they are available on eBay. $120 shipped.
    I was going to do this upgrade on my first gen Tacoma, but determined that the air bags are programmed different due to different body designs and impact zones. Don't want to risk safety.
    Good luck with mod!
  12. Feb 14, 2013 at 2:43 PM
    t_e
    Erik
    miami,fl
    I've been wondering if the new clock spring they use is now all the same and might have the correct plug. Might try that first.
  13. Feb 14, 2013 at 5:23 PM
    t_e
    Erik
    miami,fl
    If you can get me the part# for the clock spring they install i can check with the part# i need.
  14. Feb 23, 2013 at 2:11 PM
    t_e
    Erik
    miami,fl
    Update for you. I traced the correct wired into the spiral cable so my prerunner is pre-wired just need the correct spiral cable and it should work. Going to attempt the recall first and see if that gives me the right one.
  15. Feb 24, 2013 at 6:12 AM
    DR Da_da
    Northeast FL
    Sorry, I missed this earlier. My recall service invoice shows several different numbers/codes, but the closest thing to a part number is 04002-04104 (other numbers are 2529BD and 51430).
    What year is your truck? Excited for results - I'll be staying tuned!!!!
