Possible to fit 8" speakers in the front doors of a 2nd gen?
Discussion in 'Audio & Video' started by 6spd, Aug 20, 2012.
  1. Aug 20, 2012 at 11:36 PM
    6spd
    6spd [OP] Well-Known Member
    san diego
    2023 4x4
    I did a search, but did not find a solid answer. I'm planning on 7"s in the doors, but if 8"s can fit, why not? :cool:
    minus whale ask: what are the maximum dimensions that I can fit, depth wise, and diameter wise?
    Mods: delete this thread if need be.
  2. Aug 21, 2012 at 6:14 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    8's can fit but if the spacer required is more than 3/4" then you will probably hit the door panel. I have a pair of Peerless HDS 8's that did not fit. I could have done some shenanigans but I just wasn't in the mood.
  3. Aug 21, 2012 at 10:44 AM
    6spd
    san diego
    2023 4x4
    so its pretty much on the cusp of fitting or not? ah well, I was going to go with 7s, but I was just wondering if 8s would fit.
  4. Aug 21, 2012 at 10:59 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Haven't you asked this before? Anyway a member on here has a Rockford 3 way active in the doors with the 8" mid-bass and 6-1/2 mid in the doors, tweeters are stock locale iirc. So yes, it is possible but it'll take some fab work to do properly.
  5. Aug 21, 2012 at 11:05 AM
    6spd
    san diego
    2023 4x4
    doh! I forgot the title of my previous thread. pardon me for that. but thanks for the reminder(of that thread, and that one would need some fabbing on fitting up 8s).
  6. Aug 21, 2012 at 11:15 AM
    Warhorseforever
    Will
    Sand Lapper
    Ha it's alright I was just letting you know.
  7. Aug 21, 2012 at 11:19 AM
    Warhorseforever
    Will
    Sand Lapper
    And just FYI when I'm searching for something I don't usually use the site's search I usually go to google and type in site:tacomaworld.com then what I'm looking for. In this case I'd do something like 8" mid bass driver or 3-way active.
