Possible to fit a 7" or 8" in the front doors of a 2nd gen?
Discussion in 'Audio & Video' started by 6spd, May 10, 2012.
  1. May 13, 2012 at 4:35 AM
    lbridges
    lbridges Well-Known Member
    Lee
    Jonesville, FL
    2022 SR Access Cab
    None yet
    Home-made baffle plates (used King Starboard this time, but have also used Corian with great success) and yes, they are in the doors. With the Seas RNX motors I had to fit a 1" thick baffle to clear the window - provided just so you know that a 1" baffle will work.
  2. May 13, 2012 at 11:56 AM
    6spd
    6spd [OP] Well-Known Member
    san diego
    2023 4x4
    do any of you guys use separate crossover plates for a tweet/mid setup vs full active?
  3. May 13, 2012 at 12:14 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    your options are slim without mods, with mods anything is possible. My doors on my 2nd gen, 6 1/2 & 5 1/4.
  4. May 13, 2012 at 12:56 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Fitted a Polk DB6501 system to my RC.
    I mounted the crossover to the door behind the arm rest.
    Glad I put it there... having issues with my high frequency hearing so I set the x-overs for +3db on the tweeter... it ended up being too "crispy" and shrill and I couldn't mellow it with the EQ in the HU.
    I was able to pop the door panels and reach in to flip the switch to "0db" without removing the whole panel.
  5. May 13, 2012 at 2:37 PM
    Leer
    Leer Well-Known Member
    Lee
    Hilo HI
    2015 Tacoma 4x4
    Pray tell my friend, how can i accomplish this feat?
  6. May 13, 2012 at 2:46 PM
    Johns Taco
    Albuquerque, NM
    Fiberglass. Youtube should be overflowing with vids on making speaker pods.
  7. Aug 6, 2012 at 1:56 AM
    6spd
    san diego
    2023 4x4
    so, the idea of going active has been stewing in my mind since I had created this thread, and as of now, looks like I will start out with a component set up front, and a sub. question is, will the components I listed above be enough for a minimal active setup?
    HU - Pioneer 80prs
    amp - zed leviathan
    speakers - starting to look at separate pieces, straying away from the HAT 6x9's if I can find good prices on separates.
    these both have good crossover range, but I think someone had mentioned that I should get a processor that has one input so I could branch out, and would have even better control over the freq range. could someone name a couple of these items?
    just thought I'd give a little update.
    I'm still stock, as there hasn't been a dash kit created for the '12s, and I dont want to mickey mouse the install with something that doesnt quite fit right
    last note, when looking at partsexpress, etc, the specs for the speakers are for 8 ohms. this pretty much cuts the amps power in half, correct? the impedance(from 4ohm to 8 ohm) shouldnt have a factor in selecting an ampliflier?
  8. Aug 6, 2012 at 11:34 AM
    6spd
    san diego
    2023 4x4
    who can make 7" speaker adapters to fit the front doors on a 2nd gen?
  9. Aug 6, 2012 at 3:50 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    You can. Buy a cheap cutting board from walmart or comparable store use the old speaker rings to mark your boundaries and cut it out.
  10. Aug 6, 2012 at 7:06 PM
    6spd
    san diego
    2023 4x4
    Was hoping someone already had some made. I'm lazy. I just want to plug and play
  11. Aug 6, 2012 at 7:13 PM
    Warhorseforever
    Will
    Sand Lapper
  12. Aug 6, 2012 at 8:43 PM
    6spd
    san diego
    2023 4x4
    I actually chatted with Mr Marv, and I'm hoping he'll make some for me when I'm ready. I'm definitely gonna get one of his sub boxes, since he is revered here on TDub.
  13. Aug 21, 2012 at 11:31 AM
    6spd
    san diego
    2023 4x4
    so just an update on my selection of drivers.
    Im thinking of these for the fronts:
    SEAS Excel W18NX-001 7"
    Legatia L1 Pro R2 tweets
    Im thinking this combo because both drivers have good crossover overlap coverage giving my options instead of being stuck at one or two points. a pretty penny, but I dont plan on ripping my doors apart more than I have to.
    thanks again for the tips, and I will update this thread once I get everything installed(in a couple of months... wallet is a little flat...)
  14. Aug 21, 2012 at 1:13 PM
    dylan199
    dylan199 Well-Known Member
    Why not stick with HAT and use the Legatia L6V1 or V2?
  15. Aug 21, 2012 at 11:03 PM
    #35
    6spd
    san diego
    2023 4x4
    dylan - I didnt even consider those mids. I progressively made it up to the seas mids, and started looking for tweets and ended up deciding on those. when it comes down to it, it will be all about price, since I had seen a scratch and dent sale from an authorized HAT dealer on the net, was just too late to grab anything.
  16. Aug 22, 2012 at 8:04 AM
    #36
    dylan199
    If you can wait, I would hold off for another scratch and dent sale. The authorized dealer you are talking about is actually the owner of HAT. I bought my L6's from that sale and they look brand new!
  17. Aug 22, 2012 at 9:06 AM
    #37
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    How much are you paying for each set if you don't mind me asking? I think you can get similar performance for a WHOLE lot less.
  18. Aug 22, 2012 at 9:31 AM
    #38
    6spd
    san diego
    2023 4x4
    what would you recommend, Italyn?
  19. Aug 22, 2012 at 9:53 AM
    #39
    ItalynStylion
    Steven
    DFW, Tx.
    The Peerless Exclusive 7" mid is a fantastic choice. npdang on DIYMA (when that site was still useful) has done a considerable amount of testing on various mids. He found those to be top notch. They're less than half the cost of the seas drivers. I'm sure the seas drivers are great but I'm not sure how well they perform in the car.
    http://www.madisoundspeakerstore.com/peerless-woofers-6-7/peerless-830883-exclusive-nomex-7-woofer/
    The tweeters you're using are nice but very VERY expensive. I think you could get away with something much cheaper and still have incredible sound. These Vifa 1" tweeters are STELLAR and play very low. You'll be able to cross them over in a variety of places. They are fairly small too so mounting shouldn't be a concern.
    http://www.madisoundspeakerstore.com/hard-dome-tweeter/vifa-ne25vta-1-aluminum-dome-tweeter-4-ohm/
    PS: I already know what your next post is going to be. "Those are priced way less than the stuff I was looking at so there's no way it's the same caliber." And the truth of the matter is that it's absolutely the same caliber. When you start picking your own drivers you quit believing all the marketing hype and start learning to read the spec sheets. That's when things REALLY start to get interesting. ;)
