Possible to get a 6” lift from a 3” already set on a tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by supkillah808, Sep 10, 2021.
  1. Sep 10, 2021 at 12:33 AM
    supkillah808
    supkillah808 [OP] Member
    Justin
    06 Black 4D 2WD Tacoma
    3” Lift
    Hello tacoma guys, I have an 06 prerunner tacoma. I have it on 3” lift pro comp with 35” tires. I would like to go higher on a lift because I do not like the look of a 3inch. Is it possible to add another 3” without a body lift or having to buy a new 6” lift kit? I heard doing a hybrid isn’t the safest route.
  2. Sep 10, 2021 at 12:42 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Get lift spindles
    Kelvin likes this.
  3. Sep 10, 2021 at 12:46 AM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    This. There’s several brands, Maxtrac being the most budget friendly.
    Strictlytoyz[QUOTED] likes this.
  4. Sep 10, 2021 at 12:51 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    You'll need to run a new setup in the rear if you wanna match the front. Preferably a new leaf pack and longer stroke shocks. If you wanna keep it cheap just run blocks. You'll still need new shocks in the rear. And longer brake lines all around as well
  5. Sep 10, 2021 at 2:32 AM
    supkillah808
    Justin
    3” Lift
    Would having to a 6” lift kit be cheaper instead or not? I’m a newbie
  6. Sep 10, 2021 at 10:19 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Your cheapest route would be what I stated. Getting lift spindles for the front. A block and longer shocks for the rear. Extended brake lines all around. If you wanna just get a new kit just ditch your current setup and get a maxtrac kit.
  7. Sep 14, 2021 at 3:03 AM
    supkillah808
    Justin
    3” Lift
    could you send me a link on which exactly to get?
  8. Sep 14, 2021 at 10:22 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
