Possible to Haul a 4x4 Taco with Tow Dolly?
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, May 15, 2012.
  1. May 15, 2012 at 10:27 AM
    x2468
    x2468 [OP] Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    My family needs to Haul some stuff from Florida to New England, and I have the ability to take my truck behind the U-haul. My step sister just moved to Austin and she used a tow dolly to bring her front wheel drive car. So I assumed I could do the same with my truck if I just put the T-case and Tranny in neutral and let the rear wheels spin freely.
    However, on the Penske site it says that the flat bed trailer is highly recommended for RWD or AWD vehicles, and the dolly is only for FWD cars? and the flatbed one is only rated for 4,000lbs, which is too week. It says somehting about disconnecting the drive shaft if the vehicle is RWD???? How involved is that???
  2. May 15, 2012 at 10:51 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I wouldn't and I believe your Owner's Manual will tell you not to also. Unless you have a manual transfer case or drop the rear drive shaft, I wouldn't do it.
  3. May 15, 2012 at 10:52 AM
    x2468
    I have the manual transfer case. Dont have the owners manual, previous owner didn't have it.
  4. May 15, 2012 at 10:56 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Drop the drive shaft and you should be fine to tow it. Just for clarification you're talking about one of these right.
  5. May 15, 2012 at 11:01 AM
    Pugga
    Massachusetts
    With a manual transfer case, if you put it in N, you should be fine but I'll let someone with a 1st Gen confirm (no manual transfer case for 2nd Gens :(). It's obviously safer to drop the drive shaft, that way nothing can really happen to any of the drive line components since they won't be connected at all.
  6. May 15, 2012 at 11:04 AM
    bamma
    bamma Well-Known Member
    Spokane, WA
    Current: 2016 Land Cruiser, 2023 Tundra TRD Pro, 1988 FJ62 and 2020 4Runner Limited
    Yes, you can tow with the transfer case in neutral. Another advantage that 1st gens have over the 2nd gens and the electronic transfer switch...
    I'd recommend you go to a dealer and buy an owners manual.
  7. May 15, 2012 at 11:13 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Auto transmissions should not be towed with their wheels on the ground, even in neutral. The driveshaft drives the output shaft, which creates heat. With the engine off, the pump won't circulate trans fluid to cool itself. Eventually, the trans will grenade.
    Pulling the driveshaft is easy. Mark the ends so you put it back exactly how it came out.
    Anton338 likes this.
  8. May 15, 2012 at 11:26 AM
    x2468
    But isn't the transfer case between the auto trans and the rear diff? So if the t-case was manually put into neutral, wouldn't that cut the auto trans out of the equation? Now, if there is some type of lubricating issue with the t-case, then i could understand that being an issue.
    Well, my family ended up finding a good deal on a flat bed trailer from budget. I just felt bad and wanted to save them as much coin as possible, but they liked the piece of mind. But I'm still curious, just to fully understand the mechanical workings of the trucks, and in case i need to do this on a tight budget in the future. Also could be useful for other members who have the same question in the future.
  9. May 15, 2012 at 11:54 AM
    knucklehead
    knucklehead Well-Known Member
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    Anyone suggesting that you can tow with the transfer case in neutral, is giving bad information. The xfer case oil pump is driven by the *input* shaft, not the output shaft. In neutral, the input shaft doesn't turn, hence no oil. It is probably fine for *short* distances, but that is all.
  10. May 15, 2012 at 12:24 PM
    Swimmerboy2112
    Swimmerboy2112 Well-Known Member
    Brian
    Walnutport, PA
    02 TRD V6 5 Speed X-Cab
    Borla exhaust, K&N intake, ARB bumper, 16x8 Konig Countersteer Offroad wheels, 20% Tint
    You must remove the drive shaft and put the trans in neutral with the transfer case in high.
    I have towed many Toyota 4x4's this way. Some new some old.
    I've towed as far as 600mi.
  11. May 15, 2012 at 12:24 PM
    x2468
    Interesting. Before you edited your post I was also looking at the FSM, but realized I had no idea what I was looking for lol.
    Thanks for the info.
    Kinda has me wondering, is there any use for the neutral setting on the transfer case?
  12. May 15, 2012 at 12:29 PM
    Jdevine80
    Jdevine80 Member
    Josh
    Fort Collins, CO
    '11 V6 DC TRD Sport 6 Speed
    I've moved across country several times and used both. Regardless of the situation with the vehicle, the flat bed is way better than the dolly as far as loading, unloading and generally feeling like it's something solid you are pulling behind the truck.
  13. May 15, 2012 at 12:31 PM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    X2468: there must be a disconnect between high and low because the gears otherwise would bind.
    Whippersnapper02: sure, as long as you don't bind blowing up your xfer case...
  14. May 15, 2012 at 12:31 PM
    x2468
    read 3 posts up from your post
  15. May 15, 2012 at 12:35 PM
    Pugga
    Massachusetts
    If you remove the drive shaft, why does it matter what the X-fer case and transmission are set at? Without the rear drive shaft, you could have the transmission in reverse, the transfer case in lo range and it wouldn't make a damn bit of difference since there's nothing connecting them to the spinning rear diff... :confused:
  16. May 15, 2012 at 12:38 PM
    TacoBran
    TacoBran You're Unique, Just Like Everyone Else
    Brandon
    Peoria, AZ
    2023 Double Cab Trail Edition; 03 Double Cab 4x4 TRD SOLD
    2023 Bone stock... 2003 - Icon coilovers, TC UCA, icon shocks w/resi's, deaver leafs - 4x4 swap in progress
    Rent from u-haul
  17. May 15, 2012 at 12:39 PM
    ODICA
    ODICA 06 TACOMA 4X4
    Earl
    Beaumont, CA
    06 4X4 SR5
    I would recommend Budget's car carrier, I relocated a year ago and when I did my research it was only Budget's car carrier was longest trailer that I could safely put my truck on. In addition it was only Budget car carrier that has the ability to carry more than 5k pounds on their trailers. Penske, U-Haul car carriers were shorter than Budget's. My truck is a double cab short bed with stock 265/70/17's on it and I only had about half an inch on each side and about 1ft in the rear wheels to the end of the trailer. It's really tight, but I had to go with it because I did not want to put it in a dolly. So if you have a long bed with wider tires it would not fit on Budget's car carrier, I had my truck in the back and drove coast to coast from North Carolina to California and never had issues during my trip. I wanted to post pics but sorry could not find it.
  18. May 15, 2012 at 12:40 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I see no reason to put the trans and transfer case in neutral with the drive shaft removed and the front wheels on the dolly.
  19. May 15, 2012 at 12:42 PM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    Whip: I've explained the neutral position. And toyota agrees that it is otherwise useless -- why do you think 2nd gens don't have access to it?
  20. May 15, 2012 at 12:50 PM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    I suppose the problem with driving it off the output shaft is that it won't pump as high a volume in low. Though I suppose that pumping zero in neutral could be worse...
