Possible to Haul a 4x4 Taco with Tow Dolly?
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, May 15, 2012.
  1. May 15, 2012 at 12:51 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    My 4wd selector switch lights up... Admit it, you're :jellydance:
  2. May 15, 2012 at 12:51 PM
    knucklehead
    knucklehead Well-Known Member
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    Why do you need the 4wd switch lit up? It only has three positions, left, middle, and right.
  3. May 15, 2012 at 1:00 PM
    Pugga
    Massachusetts
    Because I'm easily confused...
    It doesn't need to be lit up, but it's kind of stupid that it doesn't lit up with the rest of the dash. What's even weirder is they made the switch so it could be illuminated, then made a decision to NOT put lights in with the rest of the dash.
  4. May 15, 2012 at 1:03 PM
    x2468
    x2468 [OP] Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    As it so happens, budget is who we went with. thanks for that info, makes me feel better.
  5. May 15, 2012 at 2:04 PM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    Couldn't tell you that since I don't even have one. You do a lot of ATRAC'ing at night? :eek:
  6. May 15, 2012 at 2:06 PM
    Pugga
    Massachusetts
    Probably not because he can't find his 4wd switch... :laugh:
  7. May 15, 2012 at 2:14 PM
    FailRated
    FailRated RTO
    Evan
    Maryland
    03 Double Cab TRD
    5100's w/ Eibachs, Front sway bar in trash mod, Diff drop, 265/75-16 Duratracs or 33x10.50 KM2's on 15x8 wheelers steels, ARB front bumper, Warn VR8000 winch, Trailgear sliders, Allpro rear bumper, Sky Offroad E-Locker guard, Sky Offroad weld on differential guard, Savage skid plates w/ Budbuilt cross member, e-locker rear, ARB air locker front, 4.56 gears, bought it from my mom who bought it new :-D
    You don't have to completely remove the drive shaft. Just unbolt it from the pinion yoke and tie the driveshaft up with a bungie or rachet strap. No need to unbolt the center bearing or unbolt from the transfer case yoke.
  8. May 15, 2012 at 3:08 PM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    This are the answers. When I moved from Tampa FL to Ventura, CA this is what I did. The rear tires get some miles, but not the odo! Of course I was towing a Miata, not a 4X4, but the principle is the same.
  9. May 15, 2012 at 3:40 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    I would get a trailer, not a dolly. But it totally depends on cost for you, etc.
  10. May 15, 2012 at 3:50 PM
    CliffordBRD
    CliffordBRD Well-Known Member
    Cliff
    Tampa, FL
    09 DCLB 4x4 Pyrite Mica
    I work for Penske and when I tried to see if mine was capable of being towed on a car carrier (lifts all four off the ground) it said it was. Being a 4x4 and such I didn't think it would. I'm telling you right now, moving and such can be a hassle, I deal with it everyday. If their is an easier route, take it, besides it puts less wear and tear on your vehicle and our carriers have anti lock brakes on the trailer.
    Just my 0.02 for you.
    PM me your number and I will see if I can help you out if you want to go through Penske Truck Rental.
  11. May 15, 2012 at 3:54 PM
    The Driver
    Raph
    But trailers are HEAVIER! That adds to the complexity of the driving dynamics involved.
    Hey Cliff, I see you are in Tampa, exactly where? I grew up in Odessa and New Tampa. I miss my home! :(
  12. May 15, 2012 at 4:00 PM
    CliffordBRD
    Cliff
    Tampa, FL
    haha I grew up in Odessa too! Small world, actually just moved to Washington DC a couple weeks ago.
    I see the OP already moved, sorry for the late response :)
  13. May 18, 2012 at 11:31 AM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    I need to retract what I previously said in this thread. It is, in fact, NOT safe to flat or RW tow an R15x transmission in neutral. Further studying of the FSM showed that the counter shaft is fixed to the INPUT shaft rather than the output shaft. That means that there will be no lubrication except for 5th gear. The only safe way to flat tow in neutral is to flood the transmission with oil up to the level of the output shaft.
  14. Oct 17, 2012 at 8:09 AM
    Rebel Taco Man
    Rebel Taco Man Well-Known Member
    Tyler
    Western Kentucky
    2002 Manual TRD SR5 4x4
    Bilsteins front and rear, Eibachs up front, 2" Toytec AAL in rear, Diff Drop, Grey Wire Mod
    Get over it, just get a pair of sticks to play with, then you dont have to have those wimpy buttons! :D
