Possible to make my 265/75/r16 BFG KO2 Load E peppier?
Discussion in 'Wheels & Tires' started by OverlandShack, Jan 20, 2022.
  1. Jan 20, 2022 at 8:06 PM
    OverlandShack
    OverlandShack [OP] Member
    Micah
    2022 Black Tacoma SR 4x4 Double Cab
    Today I got some new load E BFG 265/75/16 KO2s put on my truck, after changing them I noticed a significant power and MPG hit (at 14 mpg with feather foot on interstate). I was definitely expecting an impact but just not as much as I am seeing. MPG isn’t a huge concern of mine just the only real stat I have to present.
    I currently have factory SR steelies on, which from what I read are around 30lbs per wheel. Was wondering how much dropping down to a 20lb wheel would help my power and MPG. If so any good recommendations for wheels? I have been looking at SCS.
    I also read somewhere that lighter wheels on heavier tires might even cause more power loss, is there any truth to this or will lighter help in my scenario?
  2. Jan 20, 2022 at 8:08 PM
    eurowner
    eurowner Duke Sky
    Scoty
    For sure a new Tune! That’s the best bang for the money.
    Getting lighter rotational mass is very important. Roughly 10lbs of wheel mass equates to 100lbs of chassis weight. There are a few aftermarket aluminum wheel companies making wheels 22-25lbs.
  3. Jan 20, 2022 at 8:15 PM
    OverlandShack
    Micah
    Yeah I’ve read quite a bit about unsprung weight and it’s impact - seeing it first hand has been eye opening though.
    Have any good wheel company recommendations?
  4. Jan 20, 2022 at 8:15 PM
    the.shelbysaurus
    the.shelbysaurus Well-Known Member
    Colorado Springs, CO
    2019 Cavalry Blue SR5 4x4 ACLB
    Ironman 4x4 Foam Cell Pro, SPC UCAs, 285/70/17 KO2s, 1.25" Spidertrax spacers
    Adding to the above, I’ve seen folx here say that adding that rotational mass further from the hub (as in the treads of the tire) makes it worse than closer in (wheel itself). Obviously you’re not gonna be getting. Anew set for a while now, but next time you might want to consider C loads to save some weight as well. Good luck!
    33yrsoftoys likes this.
  5. Jan 20, 2022 at 8:19 PM
    OverlandShack
    Micah
    For sure, main reason I went with E was for some reason, nobody makes C in 16 all terrains that I could find.
  6. Jan 20, 2022 at 9:05 PM
    the.shelbysaurus
    Oooh gotcha. I have heard that's an issue with 16s. Supposedly there are more C load options available for 17s, but if you're already gonna buy lighter 16s you may as well just stick with that. Hopefully lighter wheels will do the trick for you!
  7. Jan 21, 2022 at 6:49 AM
    eurowner
    eurowner Duke Sky
    Scoty
  8. Jan 21, 2022 at 8:24 AM
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    Enkei RPT1 16x8 are around 16-18lbs, and pretty affordable compared to other JDM wheels.
    I know Volks are similar in weight with the same size, but the price is more.
    I’m planning on running them with 265/75/16 SL load and I am hoping I will actually lose weight while increasing the tires size.
    eurowner likes this.
  9. Jan 21, 2022 at 9:45 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    That’s weird your mpg is so low, my mpg with 285 70 17 KO2s C load currently running is around 18 mpg combined. We have a 60mph speed limit.
    When I went from 265 70 17 KO2s E load to C load I only gained 1 mpg so not a big difference.
  10. Jan 21, 2022 at 12:58 PM
    eurowner
    eurowner Duke Sky
    Scoty
  11. Jan 21, 2022 at 2:18 PM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    Stock 2022 should have way better mpg than a 2nd Gen lifted with a canopy, winch. True I do have SCS wheels which are lighter but come on, you guys should be in the low 20s for mpg. Unless your doing 80 mph out there on your drive.
  12. Jan 21, 2022 at 2:32 PM
    OverlandShack
    Micah
    Yeah I should’ve mentioned, our speed limit is 70, so regularly do ~75 on the interstate. Before tires I was seeing 19-20 combined.
    I actually ended up going back to DiscountTire and am getting some SL Goodyear ultraterrain ATs put on, they allowed me to exchange my tires since I had only put a few miles on them.
    The ultraterrains looked pretty comparable to the Duratracks from what I have seen/read, they should be around ~12lb lighter per tire too which I assume will be a world of difference.
    MTB58 and DavesTaco68[QUOTED] like this.
  13. Jan 21, 2022 at 3:14 PM
    eurowner
    eurowner Duke Sky
    Scoty
    JackJoachim[QUOTED] likes this.
  14. Jan 21, 2022 at 4:35 PM
    OverlandShack
    Micah
    These look awesome but definitely on the pricier side of what I was hoping to spend. Hoping SCS will restock at some point.
  15. Jan 21, 2022 at 4:39 PM
    OverlandShack
    Micah
    Update on this, changed out for 265/75/r16 Goodyear Ultraterrain AT SL load, and the pep is back! The ~12lbs made a huge difference.
    in the future I would like to try out KO2s again but will have to jump up to 17 inch wheels to get the C load.
  16. Jan 21, 2022 at 4:39 PM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    Spot on. Larger rotational moment arm. I'm a big fan of C load tires for this very reason
