Possible to remove hub bearings after 6 months?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tenui, Aug 17, 2023.
  1. Aug 17, 2023 at 11:44 AM
    tenui
    tenui [OP] Well-Known Member
    (I think sometimes we should have a "Support Group / Self-Help" Sticky Thread that people can post their "While I am at it..." thoughts and be talked back down to reality.)
    So, when I had my swiss cheese frame replaced in February (under warranty), I gave the dealer some parts to install in place of the originals that were disintegrating. (Rear Shocks, Rear Trailer Hitch/Cross Member, and two front hub assemblies).
    I was an idiot and did not pay the small fee of $120 for 2 new front dust shields since the hubs were being replaced. I need to replace the front brakes this weekend and will be including 2 new calipers since one is hanging up.
    So my question, is there any possible way (like that scene in Marvel's End Game where Dr. Strange checks 1 million different possibilities/realities) that I would be able to remove the hub bearings that have been installed for 6 months without destroying them? I know the dust shields don't do "much" but they do something right? Or do I just do the brakes, rotors, and calipers and ignore the crumbling dust shields?
    3JOH22A likes this.
  2. Aug 17, 2023 at 3:29 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    The dust shields do "something"... at least on my 1st gen, after pulling them off I learned they help keep hot rotors from melting the outer TRE boot, followed by grease melting onto the rotor.
    The hubs should come out relatively easy, especially since they haven't even gone through a winter yet from the sounds of it. Tip: hammer blows to the bolt ears (obviously need a punch/drift in this case) or even better an air chisel & blunt bit... try to rotate it, just to break it free, then you can pull it out. Unfortunately with the bolts from the outside, you can't use Tip B, which is to put a socket on the head of one of the mount bolts that's only threaded in a couple turns & whack that with a hammer to push the hub out.
  3. Aug 17, 2023 at 3:43 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    They should come out easy. There's an O-ring that keeps water out of the interface. Toyota trucks are the only ones done this way I think.
  4. Aug 17, 2023 at 5:33 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    cut the dust shield in half and install around the bearing
  5. Aug 17, 2023 at 5:58 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Absolutely possible.
    You’ll need a 35mm socket, a 17mm wrench, and a 10mm socket.
    35mm for the axle nut
    17mm for the hub bolts.
    I also used Blue lock-title for the hub bolts.
  6. Aug 17, 2023 at 8:02 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    It should be easy as the hub is only held on with 4 bolts, and 1 cv axle nut if you have a 4x4. If you do have a 4x4 make sure to remove the ABS sensor before you remove them.
  7. Aug 18, 2023 at 7:42 AM
    greenEFSI
    greenEFSI TacoSupreme____
    Gio
    West Covina, SoCal
    '15 TRD Pro Super White
    TnShooter likes this.
  8. Aug 18, 2023 at 8:29 AM
    Alealexi
    Houston, TX
    If you do it yourself I would and have some trouble keeping the dust plate in place just use a bit of gasket maker to keep it in place while you place the bearing assembly in place.
