Possible to run a 4 prong harness with a shell’s 3rd brake light?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Jun 13, 2019.
  1. Jun 13, 2019 at 7:38 PM
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
  2. Jun 14, 2019 at 9:43 AM
    Cutter_
  3. Jun 14, 2019 at 4:18 PM
    02-5Lug
    02-5Lug Active Member
    Christian
    Gainesville, GA
    2002 xtra cab 2RZFE 5sp
    I would hook up the 5 wire to four wire adapter for the trailer and use a separate plug hooked straight to the truck’s brake light circuit for the third brake light on the camper shell.
    Cutter_[OP] likes this.
  4. Jun 14, 2019 at 4:27 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Both are for American cars sharing stop light bulbs with blinkers. Tacoma has separate Blinker and Stop light bulb. So both harnesses are useless (or overkill).
    Like @02-5Lug wrote, juts splice the wire in the trailer adapter going to your left (or right) stop light bulb and connect it directly to the third brake light. Third brake light designed for camper shells is usually LED so it takes minimal current. Will not overload fuses (trailer is the separate story).
  5. Jun 14, 2019 at 4:36 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    02-5Lug likes this.
  6. Jun 14, 2019 at 5:20 PM
    02-5Lug
    Christian
    Gainesville, GA
    The red wire on the upstream side of the 5 to 4 is the brake light, tap into it right there for the third brake light
  7. Jun 14, 2019 at 5:21 PM
    02-5Lug
    Christian
    Gainesville, GA
    Bingo
