possible to run welder off stock power outlet in bed?
Discussion in 'Technical Chat' started by bigburrito, Dec 17, 2009.
  1. Dec 17, 2009 at 10:15 AM
    bigburrito
    bigburrito [OP] Local Man
    DuPage County
    '09 TRD OR
    Demello sliders, fog lights anytime, 265/75R16 Duratracs, 60" HiLift, VIAIR OBA 2.5 gallon tank, FM Super 44, TSB springs, 5100s at .85, bent tailgate
    after doing some searching, ive come to the conclusion that this will almost certainly not work. the stock power inverter at 400 watts is apparently the weak sauce, and running hh 140 welder would require more juice than is available.
    can somebody say for sure if im totally off base here? what kind of power would i need to run the welder (that i have not purchased yet)
  2. Dec 17, 2009 at 10:16 AM
    betz.steven
    betz.steven Well-Known Member
    Southern NJ
    2011 TE 4Runner
    yeah a welder is a no. i couldent even get a microwave to cook anything through the outlet
  3. Dec 17, 2009 at 10:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What He said ^^^^
  4. Dec 17, 2009 at 10:17 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Maybe if you're welding gumwrappers together. :D
  5. Dec 17, 2009 at 10:21 AM
    kmac1036
    kmac1036 Active Member
    KC
    Iowa
  6. Dec 17, 2009 at 10:26 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Volts x Amps = Watts. Given that the output voltage is regulated to 115V. Then the only variable is Amps and the wattage rating indicates that.
    So if the welder uses 15A x 115V = 1725W. FAR more than the inverter can handle.
  7. Dec 17, 2009 at 10:39 AM
    bigburrito
    DuPage County
    '09 TRD OR
    wow its worse than i thought.
    at least it can power rope lights for a winter camping mini-bar. id be really depressed if there wasnt enough light to pour up rum and cokes
  8. Dec 17, 2009 at 10:41 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
  9. Dec 17, 2009 at 11:22 AM
    kmac1036
    KC
    Iowa
    ***Digs out Physics book***
    Thx for the refresher, feel stupid for forgetting that!
    on this stuff when it's rated is usually a peak draw for a set period of time. a lot of times it's very short timespan & much higher than what your constant flow would be. plus, the quality of the product can vary from one batch to the other. I'm speaking in general terms... not saying toyota's offering is terrible (just not for a welder).
    to deliver 1800W continuous power, you're def looking at a decent generator setup.
  10. Dec 17, 2009 at 11:34 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Off topic, but you're gonna love that Hobart box. I'd never welded in my life before buying the 140 and have been practicing on everything from scrap metal to fenders on my trailer to whatever. Easy machine to learn on, and from everything I've read it's a solid performer in skilled hands.
    Great choice, and now back to your regularly scheduled thread... :)
  11. Dec 17, 2009 at 3:15 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    welder No....
    Soldering gun...Yes
  12. Dec 17, 2009 at 3:28 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    How 'bout a hair dryer? :anonymous: :smack: ;)
  13. Dec 17, 2009 at 3:32 PM
    cntstan
    cntstan Well-Known Member
    Chuck
    Wisconsin now, North Carolina will always be HOME
    08 DC SR5 4X4 ; 94 Ford Bronco
    3" Toytec coilovers, rear AAL,satoshi'd grill,ARE topper,TRD exhaust, All Pro winch bumper, Warn winch, All Pro skid, Pro comp 7089's, Supersprings, Wet Okole seat covers
    It can run my circular saw at about 20 rpm...........just enough to cut through wet toilet paper :D.
  14. Dec 17, 2009 at 4:09 PM
    HBMurphy
    Paul
    So California Coast
    None
    I use it to run some halogen lights like this when working on my truck...
    I hope I don't have to hook it up to this afterward!
  15. Dec 17, 2009 at 6:31 PM
    Voos
    Voos Well-Known Member
    Eric
    Albuquerque, NM
    Dbl Cab SB TRD Off Road
    Icon CO's, Total Chaos UCA's All-Pro 3" leaf packs w/ U bolt flip +Timbren, Rear Bilstein 5100's, Dick Cepek DC1's Black, 285/70R17 BFG ATko, ProDryS drop in, Dynomax Super Turbo
    Welder!? I wish... But it will run a margarita maker(blender) and a Coffee pot.. even a hair dryer to keep the girlfriend happy after she washes her hair in a river ;)
  16. Dec 18, 2009 at 6:01 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Arrgh , you beat me to it lol!
  17. Dec 18, 2009 at 6:18 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    When I am away for extended periods of time I like to plug a battery charger in it and charge my truck battery. I works really well.
