possible transmission/brakes prob.
Discussion in 'Technical Chat' started by james08taco, May 4, 2011.
  1. May 4, 2011 at 3:27 PM
    james08taco
    james08taco [OP] Active Member
    richmond va
    08 V6 Prerunner SR5
    Bilstein w/ eibachs, rear Bilstein w/ 1.5 leaf, light racing uca's, are shell w/ Yakima rack, hella 1000 black magics, spidertrax 1.5 spacers
    I have a 2008 v6 automatic prerunner. The last week or so i've noticed that when at a stop (at a red light/ stop sign) sometimes my truck will jerk forward, like i got softly rear-ended. It doesn't do it every time but enough to notice a common re-occurrence. Does anyone know what this might be?
  2. May 4, 2011 at 3:28 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    Is your vent selector set to defrost, mix or is the a/c on?
  3. May 4, 2011 at 3:32 PM
    Jester243
    Dan
    Spokane, WA
    you are feeling the pump cycling on and off. It will do this if your vent selecor is set to the the defrost setting, or if the a/c is on. Nothing much to worry about, just change it to the floor or vents and see if it continues. There is also something about the truck downshifing all the way.
  4. May 4, 2011 at 3:33 PM
    james08taco
    richmond va
    08 V6 Prerunner SR5
    vent selected to head, a/c- happens both on and off
  5. May 4, 2011 at 3:36 PM
    james08taco
    richmond va
    08 V6 Prerunner SR5
    Ok, cool. thanks, i was starting to get worried. Also just searched tacoma lurch and this seems to be common.
  6. May 4, 2011 at 3:42 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    It the A/C compressor kinking in. When it engages, the computer slightly revs the engine (all vehicles do it) to compensate for the load.
    The v6 has so much low end torque, that when it revs slightly it overpowers the brakes.
    I kinda like it. It reminds me how much power this little engine has!
  7. May 7, 2011 at 7:42 AM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2003 Tacoma Dbl Cab 4X4
    Kinda sounds like axle wrap to me.:confused: Had the same thing happen to my truck. Changed out my rear springs and no problems so far.
  8. May 12, 2011 at 12:46 AM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    Navigation, 10" sub, ome881 on billies 3" all-pro leaf springs with billies, taneau cover, k&n intake,axle swap with a E locker. 31" BFG A/T on premium wheels, hoola girl air freshener and a broadie knob!
    whats axle wrap? my truck does this too, and lurches forward when i put it in drive also, even with ac and fans off. my rear leafs look tweaked on one side. im interested in this idea.
  9. May 13, 2011 at 10:13 PM
    monoman
    Dave
