Possible transmission problem. Any advice?
Discussion in 'Technical Chat' started by Thrashbash, Dec 11, 2011.
  1. Dec 11, 2011 at 6:58 PM
    Thrashbash
    Thrashbash [OP] New Member
    Philadelphia
    1993 SR5 Pickup
    So I changed my oil two days ago. A couple hours after I changed it I took the truck out to the store. When I started it a bunch of smoke came out of the exhaust. Then it was having trouble accelerating after a complete stop. It felt like the transmission was slipping. Also when I am at a complete stop the truck start "bucking". It wants to accelerate. Any ideas on what the problem could be?
  2. Dec 11, 2011 at 7:13 PM
    crainholio
    crainholio Well-Known Member
    If you're like a certain other poster here, you probably drained your transmission instead of the crankcase. And then dumped another 5 qts of oil into the crank case, doubling up on the oil fill.
  3. Dec 11, 2011 at 7:47 PM
    Thrashbash
    Philadelphia
    1993 SR5 Pickup
    Ok, well if that's the case where would I go from there?
  4. Dec 11, 2011 at 7:57 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Check your transmission dipstick, to check your fluid level. Also check your oil dipstick to see if you over filled it. Then replace the amount of ATF you drained, then drain the OIL PAN, check to make sure you have the right drain plug before you remove the drain plug.
  5. Dec 11, 2011 at 8:00 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  6. Dec 11, 2011 at 8:10 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    cough cough Krazie cough
  7. Dec 12, 2011 at 4:40 AM
    crainholio
    Pull the engine dipstick and take a reading. That means remove the dipstick, wipe it clean with a shop rag or paper towel, reinsert it, remove it again and note the oil level against the marked indicator.
    Let us know what you find, we've had about all the fun there is from Krazie's thread and need new material.
  8. Dec 12, 2011 at 4:47 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    when replacing transmission fluid DO NOT MIX IT WITH THE COOLANT
  9. Dec 12, 2011 at 4:54 AM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    Navigation, 10" sub, ome881 on billies 3" all-pro leaf springs with billies, taneau cover, k&n intake,axle swap with a E locker. 31" BFG A/T on premium wheels, hoola girl air freshener and a broadie knob!
    Holy smokes I didn't think someone could make that mistake lol but than again anything is possible. I wonder if that's what he actually did. I didn't think you could fit another 5 quarts in the engine anyway!
  10. Dec 12, 2011 at 4:58 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    it happens to the best of us
    but krazie's was funny as hell!
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/33318-halp.html
  11. Dec 12, 2011 at 5:51 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
  12. Dec 12, 2011 at 7:51 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    I hope you have had it towed to the nearest stealership to get the transmission re-filled.
  13. Dec 12, 2011 at 7:52 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    he has a pre-taco, he can fill through the dipstick
  14. Dec 12, 2011 at 7:54 AM
    ImpulseRed008
    Susan
    SC
    :facepalm: I saw that, but it didn't register :anonymous:
  15. Dec 12, 2011 at 3:02 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    So wait, you can't fill a transmission on a Tacoma on your own at home?
  16. Dec 12, 2011 at 3:06 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    On a second gen, kind of. It has no dipstick and needs pumped in. There's a procedure for it.
  17. Dec 14, 2011 at 4:11 AM
    Stout890
    Palmdale ca
    99 prerunner sr5
    Oh I see good thing I have a first gen than in case I ever change my tranny fluid. it's likely I never will though, to many miles and PO had no idea if it had ever been done...lame though I love fresh fluid in my truck lol
  18. Dec 14, 2011 at 4:17 AM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
  19. Dec 14, 2011 at 4:25 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    I believe that's why it's coming out of the exhaust. It might be passing the seals.
  20. Dec 14, 2011 at 4:48 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Yea. Overfilling causes extreme crankcase pressure and will drive oil into the PCV and past the rings. It will also cause foaming of the oil and premature bearing failure; the air in the oil prevents it from protecting the crank and rod bearings.
    STOP DRIVING it before you check the fluids. Draining the engine oil will fix the problem. Make sure you run the drained oil through a fine sieve to look for metal shavings. Small particles are fine, but shavings mean major damage.
