Possible Transmission Trouble? (2015 TSS Off-Road)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AlohaSnackbar, Mar 29, 2022.
  1. Mar 29, 2022 at 11:22 AM
    AlohaSnackbar
    AlohaSnackbar [OP] Member
    Ethan
    2015 Toyota Tacoma TSS Off-Road 4WD
    I apologize if this is a dumb question, I would never claim to be a mechanic and I know the least about transmissions.
    About a year ago I traded in my 06 SR5 for a 2015 TSS Off-Road. Up until last month everything has been great, was very happy with the upgrade. Maybe three weeks ago I started to feel my transmission slipping a little when shifting to lower gears (automatic transmission) and immediately took it in before I caused any damage. Mechanic said there was definitely some slipping going on, fluid looked old, changed fluid, slipping stopped.
    Last night, however, I was on my way home and came to a stop sign. The second I let off the brake and started to accelerate, my truck came to a complete stop following an audible clunk. After letting off the gas and accelerating again it drove fine the rest of the way home. Following day (today) I drove to work just fine, as well as the errands I've ran during the day, no issues.
    Again, I apologize if this has been asked, couldn't really find anything for my specific issue. Might be a simple problem but I'd rather be safe than sorry and cause unnecessary damage that can be avoided.
  2. Mar 29, 2022 at 11:25 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Find the DIY transmission fluid flush for 2nd gens and do the fluid level check, its highly possible you are low on fluid.
    TnShooter and AlohaSnackbar[OP] like this.
  3. Mar 29, 2022 at 11:32 AM
    AlohaSnackbar
    Ethan
    I'll look into that, thanks.
  4. Mar 29, 2022 at 11:45 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    AlohaSnackbar[OP] likes this.
  5. Mar 29, 2022 at 12:10 PM
    AlohaSnackbar
    Ethan
    TnShooter[QUOTED] likes this.
  6. Mar 30, 2022 at 5:20 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Sub’d, I’d like to know either how much fluid it’s low or how much comes out if you decide to drain and fill.
  7. Apr 2, 2022 at 5:53 AM
    AlohaSnackbar
    Ethan
    Just a little update, finally got a chance to look at my transmission fluid.
    Followed the steps to check my transmission fluid level and, as the linked post said, there was a small trickle coming from the overflow port. I was kind of hoping to see that it was a little low (to explain why my truck acted that way), however I haven't had any issues with my transmission since that day. Been driving a good bit and everything is shifting normally.
  8. Apr 2, 2022 at 6:01 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    At least good to know you have the correct amount of fluid. And now you know how to check level properly, so you can do a drain and fill should you choose to.
