Possibly burning oil? Help
Discussion in '1st Gen. Tacomas' started by Az lowtacoma, Sep 26, 2012.
  1. Sep 26, 2012 at 8:08 PM
    Az lowtacoma
    Az lowtacoma [OP] Mini Truckin'
    Seth
    Arizona
    95.5 Lowered Tacoma
    k&n cold air intake 57 series, flowmaster 50 series delta flow, viper alarm, auto door locks, big three upgrade, kinetik hc1400r battery, 1/0 gauge wire, Pioneer 4500, Streetacos 3" tapered blocks, Belltech 3" drop leafs, Qa1 coil overs with 550lbs coils, ball joint flip, rear KYB Monomax shocks, 18x8 +40 Enkei Kojins, 225/40/18 Nittio Motivo tires, LCE drilled and slotted rotors, Hawk HPS brake pads, roll pan, 01+ taillights
    So when I leave from work at night start my truck up put it in reverse and back up and then a cloud of smoke come out from what appears to be my hood. So I don't know if my truck is burning oil or since I park under a tree and by a dirt lot if maybe I'm sturring up dust. I oly notice this at night and it has been going on for a while but I check my oil and its still at good levels. I did use a K&N oil filter this time too. Thoughts?
  2. Sep 26, 2012 at 8:15 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Phoenix
    2005 Tacoma 4.0L Acces Cab PreRunner
    Shortened antenna, ebay Intake, JBA long tube headers, 2nd set of cats cut out and straight piped, 14" Magnaflow muffler dumped before axle, relocated rear diff breather, Avid off road front bumper. Bilstein 5100's front and rear, OME 885x coils, Light Racing UCA's, 2" Toytec AAL, Hella 700ff lights, Falken Rocky Mountain AT/S 265/75/16 Load E 10ply, Blu Logic handsfree
    Do a compression test. That's the only way how to tell if your piston rings are worn or if you have scored cylinder walls thus allowing oil into the combustion chamber. You can rent compression tester at Autozone...
    It could also be bad head gasket. When head gasket goes bad, it allows coolant get to combustion chamber. When truck sits it seeps through the bad head gasket into the combustion chamber and pools in the cylinders, once you start it up, coolant starts to burn off making your truck smoke.
  3. Sep 26, 2012 at 8:18 PM
    Az lowtacoma
    Seth
    Arizona
    95.5 Lowered Tacoma
    Alright i will have to try that to see if thats the case. Thanks for the info
  4. Sep 26, 2012 at 8:21 PM
    05RedTaco
    Tony
    Phoenix
    Missed the part where you said smoke is coming from the hood...lol Thought you are talking about exhaust.
    Could be some fluid (not necessarily oil) leaking on a part under the hood which gets hot (like exhaust) and once you start it the fluid starts to burn off creating smoke...
  5. Sep 26, 2012 at 8:22 PM
    Az lowtacoma
    Seth
    Arizona
    95.5 Lowered Tacoma
    Hmm well I did add some coolant recently too but it seems to be at the same level as after i added it. If my cylinders are scored what can be done about it?
  6. Sep 26, 2012 at 8:24 PM
    Az lowtacoma
    Seth
    Arizona
    95.5 Lowered Tacoma
    I haven't seen any smoke coming out of my exhaust at all. Any thoughts about what could poaaibly be leaking cause i have checked under the hood quite a bit lately and havent noticed anything
  7. Sep 26, 2012 at 8:25 PM
    05RedTaco
    Tony
    Phoenix
    Engine would have to be pulled, long block taken to machine shop. Machine shop would bore the cylinders, then you would have to get appropriate size piston rings. How much it would have to be bored over that depends on how much damage there is to cylinder walls.
  8. Sep 26, 2012 at 8:26 PM
    05RedTaco
    Tony
    Phoenix
    Hard to say over the internet without seeing the truck in person...
  9. Sep 26, 2012 at 8:32 PM
    Az lowtacoma
    Seth
    Arizona
    95.5 Lowered Tacoma
    Yeah thats true haha well ill do some closer looking i suppose
  10. Sep 26, 2012 at 8:38 PM
    Az lowtacoma
    Seth
    Arizona
    95.5 Lowered Tacoma
    Good points there i will definatly try that as well thank you
  11. Sep 27, 2012 at 6:19 PM
    humtaco
    humtaco Well-Known Member
    Burning oil is extremely strong smelling. Put a few drops on a hot exhaust manifold and see how it smells.
  12. Sep 27, 2012 at 7:46 PM
    Az lowtacoma
    Seth
    Arizona
    95.5 Lowered Tacoma
    I didn't park under the tree today and there was no smoking at all
  13. Sep 28, 2012 at 9:20 PM
    Az lowtacoma
    Seth
    Arizona
    95.5 Lowered Tacoma
    Today i didnt park under the tree either and no smoke again. So i think it was just from dirt that was under/by the tree that was being blown around cause smoke/dust . However thanks again for all the info!
