Possibly doing 5100's on my 05. Anything else I need?
Discussion in 'Suspension' started by TacomaPrime, Sep 18, 2014.
  1. Sep 18, 2014 at 6:09 PM
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    If I do bilstein 5100's all around, is there anything else I need? I thought I read somewhere that I need new bushings or something like that, but can't seem to find anything.
    If someone could help me out, I'm kind of new to this whole suspension thing. Can someone tell me what else I need and tell me where to get it? I'm just going to stick with the factory springs for now FYI.
    Thanks a ton!
  2. Sep 19, 2014 at 9:04 AM
    TacomaPrime
    Gregory
    Illinois
    bumpizzle
  3. Sep 19, 2014 at 9:06 AM
    zacharypaul89
    zacharypaul89 Eat right, be fit, die anyway
    Zach
    Georgia
    2019 Quicksand Trd Offroad
    A spring compressor to put the stock coils on the new shock. You can rent them at AutoZone. That should be all you need. If your bushings aren't worn out, you can re-use them.
  4. Sep 19, 2014 at 9:08 AM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    What setting are you putting the bilsteins at? Anything over 2.5" it's recommended to get upper control arms to get your alignment back in spec. Although, some didn't get any and had no problems while others did have problems. If your keeping factory coils then I would put them at the 1.75" setting. For the rear, I don't believe these shocks ad lift so you may want to get a AAL or something. Where are you getting the shocks from?
  5. Sep 19, 2014 at 9:09 AM
    Fiend13
    Chad
    This. Or you can do what I did and take the shocks and coils to a goodyear or something and have them assemble them off the books. I paid the tech $20 to do mine. I had the ratchet style compressor and the new coils were to too beefy for them to work.
  6. Sep 19, 2014 at 9:11 AM
    TacomaPrime
    Gregory
    Illinois
    Oh cool. My bushings are still good that I know. I'm getting the frame replaced under the recall, so I was hoping that instead of putting my factory shocks back in, they would put the bilsteins on since they have to take them off anyway.
  7. Sep 19, 2014 at 9:13 AM
    zacharypaul89
    Zach
    Georgia
    Just don't let them screw you. They're called the stealership for a reason. I would be as close by as possible to watch. Make sure they're on the correct setting. They might even go as far as to tell you that Bilstein 5100's aren't compatible or something stupid like that. I hate dealerships lol
  8. Sep 19, 2014 at 9:25 AM
    TacomaPrime
    Gregory
    Illinois
    lol. oh I would. I am also looking at buying someones used shocks and sport coils since I do NO off roading in my TRD offroad. lol.
  9. Sep 19, 2014 at 9:32 AM
    Fiend13
    Chad
    Are the TRD Sport coils different from the TRD Off-Road coils? I thought the suspension was the same on both just the Sport came with LSD and color matched parts and scooped hood whereas the Off-Road just had e-lockers and chrome grill and bumper
  10. Sep 19, 2014 at 9:35 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    yeah u dont wanna preload the OR coils over the 1.75 setting, but u could do this and get a full 2.5" and the back with the aal for a good deal since it comes with new coils for $620 with no diff drop, and u shouldnt need uca's for that https://bilsteinlifts.com/shop/05-and-up-tacoma/bilstein-adjustable-lift-kit-with-5100-shocks/ u might can find that kit a bit cheaper somewhere else also but something to consider if ur gonna buy sport coils and preload them to 2.5, just to weigh ur options
  11. Sep 19, 2014 at 9:35 AM
    yota243
    E.J.
    north Alabama
    OR coils are progressive and sports are linear like the base coils
  12. Sep 19, 2014 at 9:36 AM
    TacomaPrime
    Gregory
    Illinois
    the highest I would put the 5100's is either 0 or .85. Not looking to lift.
  13. Sep 19, 2014 at 9:42 AM
    Fiend13
    Chad
    If you're not looking to lift then I'd go with the .85 to level it out and since your not gonna be offroading at all then go with the sport coils if you can find some
