Post Frame Swap - how about that
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shockinyall, Feb 1, 2016.
  1. Feb 1, 2016 at 9:50 AM
    shockinyall
    shockinyall [OP] White Lightning Enthusiast
    West Virginia
    '06 SR5 DCSB SUPER WHITE
    Traded to '17 Tundra
    Ok so the frame swap is done. Somebody help me out here because I can't remember, do the lights under the gear position in the automatics light up with your headlights? (the black plate next to the shifter). Mine is not, but honestly I can't remember if it did beforehand.
    Second, and all I can figure here is the new bushings and alignment, but my front end is sitting higher than it did before the swap. I have 5100's with Eibach that were on the truck before the new frame and now my hub to fender measurements are about 3/8's of an inch higher. I am not going to complain as it means less rake from my Dakars...
    Other than that, frame looks great, especially considering once they took it in the shop they completed the swap in about 20 hours. Haven't found any other issues yet...
  2. Feb 1, 2016 at 9:56 AM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Yes, the gear lights should light up when you turn the headlights on.
    As for the ride height difference, I'm not sure.
  3. Feb 1, 2016 at 2:43 PM
    byrd
    byrd Unknown
    David
    Kansas
    '06 Access SR5 4x4 6 speed
    Ride height could be the coil hasn't seated in the upper perch yet, mine did about a week after the frame job. You'll hear a pop when it does, similar to when disengaging 4wd.
  4. Feb 10, 2016 at 4:54 AM
    shockinyall
    West Virginia
    thanks for the help, I have some wiring to figure out then.
    I will take a look to see if this is what is going on with mine, but still haven't noticed anything yet. Going on 4 weeks. Thanks.
  5. Feb 10, 2016 at 5:11 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    It uses a #74 bulb for the indicator light. I'm betting your just noticing it now due to the fact you had your frame replaced and are super observant of any changes.
  6. Feb 10, 2016 at 5:30 AM
    shockinyall
    West Virginia
    Probably true, wouldn't have paid attention to it before. Thanks for the bulb, that may come in handy.
  7. Feb 10, 2016 at 3:29 PM
    byrd
    byrd Unknown
    David
    Kansas
    I believe it was my driver side that popped. Felt like someone hit my floorboard with a hammer. I was backing out of an inclined driveway and the driver side front was the last off the curb and onto the street, bounced and then the pop. Checked and everything looked normal. Nothing since. Level on both sides. I had called the dealer about it and that was what they told me. Been 3 weeks since I got her back. No other issues.
