Post Hub & Bearing replacement issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Freeheelbillie, Nov 2, 2019.
  1. Nov 2, 2019 at 3:13 PM
    Freeheelbillie
    Freeheelbillie [OP] Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    Replaced both hubs and bearings, the other day and all went well. @05Taco4x4 Everything was properly torqued.
    Turned on on 4x4 for the first time this afternoon while I was out getting a load of wood. The ABS and Brake light came on. o_O 4x4 appears to be working fine though...I assume this is a wheel speed sensor issue. What do you guys think??
  2. Nov 2, 2019 at 3:56 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Wheel speed sensor gone bad?
    whatstcp likes this.
  3. Nov 2, 2019 at 3:59 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    That's my first guess. I cleaned all the gunk out of there really well...figured it would fail after getting some attention. Lol
  4. Nov 2, 2019 at 4:24 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Try plugging in a code reader to confirm.
    Freeheelbillie[OP] likes this.
  5. Nov 2, 2019 at 4:47 PM
    Muddinfun
    Muddinfun Well-Known Member
    Jump pins 4 and 13 on the OBD2 connector, turn the key on and read the blinking light codes.
    69L46Vert likes this.
  6. Nov 2, 2019 at 4:51 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Will that process tell me something different than a standard scan would?
  7. Nov 2, 2019 at 4:52 PM
    Bishop84
    Bishop84 Well-Known Member
    The magnetic tone rings may be defective on the new bearings. Or damaged from the press.
  8. Nov 2, 2019 at 4:54 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    That would suck...I doubt :fingerscrossed: that's the case though.
    Got them from @05Taco4x4 his work is awesome.
  9. Nov 2, 2019 at 5:38 PM
    Muddinfun
    They don't have tone rings. It reads the bearing.
    A scan tool will read the codes too. If you have one use it.
  10. Nov 2, 2019 at 5:40 PM
    Bishop84
    On the magnetic tone ring on the inside of the race.
  11. Nov 2, 2019 at 5:45 PM
    Muddinfun
    There's nothing you can see. If there's anything special, it's inside the bearing. It's one of those unexplained magic things.
  12. Nov 2, 2019 at 5:50 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Lets hope it's a sensor...
  13. Nov 2, 2019 at 7:00 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Not sure why your brake light came on, that wouldn't have anything to do with the bearing rings. I've had the ABS light come on while going very slow in 4x4, read it a few times here, but it goes out once pick up speed. Your sensor may not be out, possible got grease on the ring or sensor and throwing things off (that was culprit for one guy iirc)
  14. Nov 2, 2019 at 7:24 PM
    Bishop84
    You can actually install the bearings upside down, the brown tone ring is visible from the inside. If its chrome its backwards.
  15. Nov 2, 2019 at 7:54 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    I'll pull the codes in the morning and see what the dilly is.
    Strange that the dummy lights didn't come on until I cycled the 4x4.
    My bet is a sensor.
  16. Nov 2, 2019 at 8:03 PM
    Muddinfun
    So, I was curious about the whole tone ring thing. I popped what looked like a seal on a sealed bearing out of the inner side of a junk bearing. Turns out it's not really a seal. It's just a shield. However, the junk bearing had ridges of gook about every 1/8" all the way around. The shield on the good bearing was smooth. Still curious, I touched the junk bearing against the good bearing and ridges of gook (apparently containing iron dust) appeared on the good bearing. So, here's the conclusion. What looks like a bearing seal is really a shield with a lot of magnetic "poles" imbedded in the rubber.
  17. Nov 2, 2019 at 9:17 PM
    Willyummk
    Willyummk Well-Known Member
    Will
    HA TO CA
    2011 DCSB TRD Sport
    Happen to me, cleaned the sensor and it went away? Didn’t get the ABS light tho. Anyone have trouble with the driver side for the life of me I cannot get the axle but off even with my Milwaukee impact wrench? Did the passenger already.
  18. Nov 3, 2019 at 2:45 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Hit it with MAP gas (which is hotter and faster heat than propane) and heat it up good, but not red hot. Then a large breaker bar, should do the trick. My passenger side was a pain to get off too.
    Willyummk[QUOTED] likes this.
  19. Nov 3, 2019 at 6:47 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
    I went to pull the codes this morning and both the ABS and Brake lights were off. Guess the Gremlins fixed it last night :anonymous:
    Must have been some gunk in there that came loose...
  20. Dec 8, 2019 at 10:14 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Just an update and a word of advice to those that are tackling this repair.
    Do yourself a favor and replace the Wheel Speed Sensors while you have everything broke down. If the sensor busts off inside the spindle due to rust it will be an easy job to get it out if the hub is off...not so much if it's all back together. :censored:
    Muddinfun likes this.
