Post lift alignment numbers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by powereng, Sep 25, 2013.
  1. Sep 25, 2013 at 7:28 PM
    powereng
    powereng [OP] Member
    MI
    '09 Dbl Cab 4x4
    3" OME lift, Brute Force Fab front & rear bumpers, Toyo OC AT 3's
    Finished installing my OME lift and just picked my truck up from the alignment shop. I'm no expert on alignments so I wanted to run my post lift alignment numbers past some of you guys to see what you think.
    For the front I installed 885 springs with no spacers other than the trim packer on the drivers side for 2.5" of lift. For the rear I had a local shop that specializes in custom springs and suspensions make me a set of custom rear leafs to give me about 1/2" of rake on the truck. I will get official numbers tomorrow in the daylight. I was planning on changing out the UCA, but before I dropped $400 I wanted to see how the alignment turn out. Coming home I did not notice any shakes or vibrations and it seamed stable at highway speeds. Let me know if you see anything that stands out.
    Front Toe
    Left +1/32"
    Right 0"
    Total +1/32"
    Front Camber
    Left +1/4"
    Right -3/8"
    Side to Side +5/8"
    Front Caster
    Left -1/8"
    Right +5/8"
    Side to Side -3/4"
    Kpi
    Left +13 3/4"
    Right +15 3/4"
