Post lift alignment specs.
Discussion in 'Suspension' started by 6spdtaco, Aug 19, 2010.
  1. Aug 19, 2010 at 9:30 AM
    6spdtaco
    6spdtaco [OP] Well-Known Member
    Nate
    East Wallingford, VT
    Taco
    Tom Woods driveshaft. TRD short throw shift kit. TRD exhaust. AFE Stage II intake. CBI Bumpers front and rear. Warn 8000i winch/ synthetic line. OME 3" lift w/ dakar springs and 886 coils. ATO Front skid. ARE MX cap. Trail Team FJ wheels. Cooper Discoverer ST 265/75-16 C tires. Diff breather relocation mod.
    Recently installed an OME lift, no UCA's. Got my truck back from alignment. It feels fine while driving. Just looking to get some opinions on these numbers because to be honest I don't know what to look for.
    Toe: .05 left and right
    Camber: .8 left, .5 right
    CASTER: .4 left, .8 right.
    Now I have read that ideal caster is 2.5? So from my understanding I am WAY off?
  2. Aug 19, 2010 at 9:33 AM
    wilsonpj
    wilsonpj Well-Known Member
    Pete
    Boulder, CO
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    From what I've learned, this is just about perfect.....
    0 Camber 0 Toe 2.4-3.1Caster
  3. Aug 19, 2010 at 9:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Camber should be closer to 0*, and Caster needs to be at least 1.8*
  4. Aug 19, 2010 at 9:34 AM
    betz.steven
    betz.steven Well-Known Member
    Southern NJ
    2011 TE 4Runner
    it should be IDEALLY
    Toe - 0*
    Camber - 0*
    Caster 2.5* as you stated
    how much did you lift the truck?
  5. Aug 19, 2010 at 9:37 AM
    6spdtaco
    Nate
    Taco
    about 3". I used the 886 coils, which in retrospect was a bad choice. Even with the winch and bumper, the coils are too stiff.
    What damage/issues can I expect from the misalignment?
  6. Aug 19, 2010 at 3:46 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    The truck will wander at high speeds due to low caster.
    Caster doesn't effect tire wear - just the way it drives.
