Post-lift Uneven Tire Wire - 2nd Gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WilsonTheDog, Jan 9, 2012.
  1. Jan 9, 2012 at 2:49 PM
    WilsonTheDog
    WilsonTheDog [OP] Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
  2. Jan 12, 2012 at 6:43 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
  3. Jan 12, 2012 at 6:44 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Camber looks okay but your caster is way low. That wouldn't cause tire wear though.
    Have you brought it somewhere else to see if that spec readout sheet is even accurate? The wear you describe would be due to camber being out of whack, not caster
  4. Jan 12, 2012 at 6:46 PM
    Spike8844
    Spike8844 Active Member
    Spike
    Minot, North Dakota
    04 SR5 4X4 TRD
    Topper, Bedliner, Bedlining the Rocker panels next.
    Did you get your vehicle in for an alignment after you lifted your vehicle?
  5. Jan 12, 2012 at 6:47 PM
    TexasTacoma37
    And btw did you just link me to another thread, which linked me to yet another thread with your alignment specs? pretty sure that's what just happened.
  6. Jan 12, 2012 at 6:53 PM
    danimal92sport
    danimal92sport Well-Known Member
    dcab, 4WD, TRD O/R
    So many threads...
  7. Jan 12, 2012 at 7:00 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    X2
  8. Jan 12, 2012 at 7:04 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    what size lift do you have? look at the tires from the front and look at the footprint, does it look like the outter edge is in more contact?
  9. Jan 13, 2012 at 11:01 AM
    mountainwolfpup
    Vancouver, WA
    Oh that part is in another thread of course, here.
    I'll reprint it here for easy reference:
    "I'm wondering why so many others who have the 2.5" Bilstein lift don't seem to have this issue." - WilsonTheDog
  10. Jan 13, 2012 at 11:05 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    looks like your toe is whacked and your caster is crazy low.....
    time for an alingmnet
  11. Jan 13, 2012 at 11:56 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    All right. Will bring in again. Thing is, I don't think much has changed in regard to the specs. I believe it's been that way since the post-lift alignment. Bottom line, I'm getting new tires shortly and can't leave it as is. If have to lower it a notch to get it right, so be it.
    And good luck getting an answer in the Suspension forum. Not happening.
