Post lift vibes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CrustyComa, Feb 24, 2020.
  1. Feb 24, 2020 at 5:07 AM
    CrustyComa
    CrustyComa [OP] Well-Known Member
    Michigan
    2020 SR SX TRD Sport love child
    So I installed medium duty dakars and eibach pro lift kit yesterday for about 2" lift all around. Have not got aligned yet. Driving to work today while on the freeway I was getting a random pulsing vibration at about 65 mpg or over. Not constant vibe, it would come and go in quick bursts. Putting it in 4 wheel drive didn't seem to make a difference but again it was kind of hard to tell due to the intermittent nature of this vibe. I've ordered a carrier bearing drop kit, could that be the issue? I'm taking it in for an alignment tonight. It couldn't be an alignment issue could it? I will try 4 high again on the way home to see try to see if it is the needle bearing.
    Thanks
  2. Feb 24, 2020 at 5:09 AM
    CrustyComa
    Michigan
    Forgot to mention, I have on the stock wheels and tires that were problem free pre-lift, so that is not the issue.
  3. Feb 24, 2020 at 5:12 AM
    Masshole_And_His_Taco
    Masshole_And_His_Taco RIP Rick
    Northish South Shore MA
    Two-seater Curb-eater
    Little bit of stuff.
    I'd venture a guess to say it's either the carrier bearing angle or the pinion angle on the rear diff. I've chased those before. If carrier bearing isn't the issue then get some leaf spring shims to adjust the pinion angle.
    Lt. Dangle likes this.
