Post pictures of your Motorcycle!
Discussion in 'Motorcycles' started by blckout, Sep 21, 2010.
  1. Aug 30, 2014 at 9:49 AM
    #3241
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    As long as its not rubbing or hitting anything through its stroke you should be fine
  2. Aug 31, 2014 at 7:23 PM
    #3242
    bigweb2001
    bigweb2001 Active Member
    Atlanta
    TRD 4x4 Double Cab
    FZ 09 checking in. here is a shot dropping it off to get new suspension at Traxxion. Now it is nicie nice!
  3. Aug 31, 2014 at 7:53 PM
    #3243
    adrenalnjunky
    adrenalnjunky Well-Known Member
    West Monroe, Louisiana
    07 PreRunner SR5 DCSB
    billie 5100's front @ .85"
    I really need to stop seeing pics of FZ09's.
  4. Aug 31, 2014 at 7:53 PM
    #3244
    DeltaSteve
    DeltaSteve Social Critic
    FW,TX near TCU
    '09 White TRD access
    KING 2.0" PERFORMANCE SERIES REMOTE RESERVOIR COILOVER SHOCK W COILOVERS, TC UCA, OME DAKAR SPRINGS, RELENTLESS PLATE R BUMPER and MORE :)
  5. Aug 31, 2014 at 8:47 PM
    #3245
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    The 07 looks like fun to me :D
  6. Aug 31, 2014 at 9:08 PM
    #3246
    jermoids
    jermoids Well-Known Member
    Jeremy
    Winnipeg, Manitoba, Canada
    2021 TRD Sport
    17x9 Fuel Mavericks +1 offset 265/65/17 duratracs NFAB Epyx step sides AVS hood protector Thule xsporter pro rack Weathertech floor liners Tacoma rubber bed mat
    my new'ish wheels, probably the most fun i have ever had ripping around in the city:D
  7. Sep 2, 2014 at 11:47 AM
    #3247
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    15 DC V6 4x4 TRD Magnetic Gray
    High-flow coconut smiley-face air freshener.
    Dirty bike :cheers:
  8. Sep 2, 2014 at 2:08 PM
    #3248
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    :drool:
  9. Sep 2, 2014 at 5:16 PM
    #3249
    jermoids
    Jeremy
    2021 TRD Sport
    sucks on the highway but sure is fun being a jackass in the city :)
  10. Sep 2, 2014 at 5:20 PM
    #3250
    PcBuilder14
    Brent
    Nor Cal
    Really? Why is that?
  11. Sep 2, 2014 at 5:37 PM
    #3251
    jermoids
    Jeremy
    2021 TRD Sport
    sucks on the highway because there is zero wind protection and the fuel range is brutally low. 130kms/80 miles in the city per tank, 180kms/111 miles on the highway per tank. and the highway miles were with riding with the gas light on for 40kms/25miles.
    you can buy a windscreen for it though which may help for highway riding, like on the hyperstrada.
  12. Sep 2, 2014 at 6:05 PM
    #3252
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    Here is my 2005 Ninja 500r. 6F996739-7682-4711-8C77-D37CCBC3BFB0_zps_dba9189017604e72b3e67e69e0573895e3b3b91d.jpg
    I've been having some trouble with it. It is my daily driver to class and was wondering if anyone can help with my two problems
    1) I recently changed the front brakes and up front there is grinding/ scooping noise about once a rotation. I don't believe it has anything to do with the rotor because if it was wouldn't it shake while braking? It's been about 3 weeks so they should be bedded right?
    2) Also there is a grinding in the back when I brake. I believe I need new brakes in the back and found some pads online for cheap. However I cannot get this bolt off for the life of me. I can get the top one off just fine but the bottom is stuck
    DBFFBFB8-E239-4D78-BE4A-B45C73106598_zps_13a58c3b2fc3e683c9b4c60b962fbb00ea67d72d.jpg
    I even twisted my hex key trying to get it off :eek:
    Have any ideas how to get it off? I wish I could use a socket wrench. I called the local motorcycle shop and they quoted me $100 for changing it :eek: so taking it somewhere is not really an option when I can do it for less than $15
    Any help would be great! Thanks!
  13. Sep 2, 2014 at 6:47 PM
    #3253
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Try riding in a getting the back brakes hot and maybe some pb blaster or something.
  14. Sep 2, 2014 at 6:51 PM
    #3254
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    Sounds like you're front rotor is a little warped. Don't worry my 3000 mile bike does it sometimes to.
    The rear rotor on your bike diff has grooves from grinding on worn out pads.
    You probably should invest in a set of socket drive Allen heads. The bolt probably has thread locker on it.
  15. Sep 2, 2014 at 7:07 PM
    #3255
    WildLand
    Josh
    NM
    16T4RSR54WD
    My bike has 16750 miles :D maybe I should replace it. I wish I could just take it to a shop and have it all fixed but I know it will be over priced BIG time and I dont have the money for that being a college student
    It's just really annoying because it makes me feel like I have a crappy bike that sounds like crap. It sounds like a big rattling piece of plastic most the time too (which I guess it is).
    I didn't even think of getting socket allen heads! Ill buy some soon.
  16. Sep 2, 2014 at 7:49 PM
    #3256
    adrenalnjunky
    No offense, but proper maintenance on a motorcycle is something that keeps you from using the ground as a very effective skin removal system.
    Motorcycle shop doesn't have to be who you take the bike to to get that one bolt out - but at least an auto mechanic will have more tools, a torch, impact tools etc. They'd probably charge you less than the motorcycle shop.
    As far as the maintenance goes - know there are some Kawi forums out there with plenty of people willing to help. And I've got twice your mileage - just gotta be willing to get in there and start wrenching :)
  17. Sep 2, 2014 at 8:09 PM
    #3257
    WildLand
    Josh
    NM
    16T4RSR54WD
    Thanks man. Yeah I know a motorcycle isn't something you can skip out and still be safe. I've tried a couple Kawi forums and no one has answered my questions or isn't nice about it like on here! So just thought I would start here.
  18. Sep 2, 2014 at 8:15 PM
    #3258
    PcBuilder14
    Brent
    Nor Cal
    Try Thumpertalk. I know on the section for my bike is very helpful.
    http://www.thumpertalk.com/forum/294-sport/
  19. Sep 2, 2014 at 8:59 PM
    #3259
    dwalden2
    dwalden2 HBTFD
    Derick
    Blue Ridge, Georgia
    '05 TRD Offroad V6 6 spd
    SCS Stealth 6 Wheels, 285/70/17 STT Pros, Demello Offroad front bumper, 20" LED Bar, LED Fogs, LED interior lights, Wet Okole Seat Covers, Body Armour Rear Bumper, Smittybilt 10K winch, 3" OME Lift
    Gonna get a new windscreen for the gixxer. Should I go with blue to match the bike, or dark smoke?
  20. Sep 2, 2014 at 9:23 PM
    #3260
    PcBuilder14
    Brent
    Nor Cal
    Dark smoke...
