Post timing belt noises
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yota4Life89, Sep 16, 2020.
  1. Sep 27, 2020 at 12:21 PM
    Yota4Life89
    Yota4Life89 [OP] Well-Known Member
    David
    Houston
    00 Tacoma Extra Cab 5spd 3.4 4WD
    01-04 mirrors, tint
    Here are the videos with the TB cover off. I would suggest using headphones. My guess would be the green idler bearing at this point.
    Overall I do notice quieter operation after the fan bracket was replaced so maybe it was noise from that in addition to what it is being heard currently?
    If no one hears anything out of the ordinary then I will stop worrying about it for now until something changes.
    Thank you
    https://youtu.be/ksCLPX_PO98
    https://youtu.be/O21XIH-_d-o
    https://youtu.be/Q2FR7Y-R5Sk
    Black97v6MT likes this.
  2. Sep 27, 2020 at 12:33 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You could check the idler pulley - there’s ways to reuse the tensioner so all it would do is cost you time.
  3. Sep 27, 2020 at 12:55 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I just really can't say yours sounds any worse than mine.
    A bad timing belt tensioner is usually pretty obvious and the timing belt flaps when you rev it.
    It's also a mostly Honda problem unless you use a Chinese knock off...which brings us to "Where did you get your timing belt parts from?"
    Counterfeit or China, bad. Toyota OEM, good.
    Black97v6MT and Yota4Life89[OP] like this.
  4. Sep 28, 2020 at 7:39 AM
    Glamisman
    Glamisman Well-Known Member
    with a long ratchet extension or a bit of a broomstick, anything that can transmit sound, put it on the bolt that holds the idler bearings on and put your ear up to it. It will be obvious which one(s) are the problem.
    Yota4Life89[OP] likes this.
  5. Sep 28, 2020 at 8:12 AM
    Yota4Life89
    David
    Houston
    01-04 mirrors, tint
    @cruxofthebisquit I got the kit from Amazon. I previously got one from ebay that claimed to be oem but both idler pulkeys were black which were suspect of being chinese knocks off and the thermostat did not have the Japanese Toyota stamp. So I returned it and got the amazon one 2 days later.
    @Glamisman I've been using a stethoscope to try and pin point it. The upper green idler bearing was checked and it sounded normal. Nothing unusual. The lower idler puller I did not have access too unless I took the belts and fan bracket off.
    Also checked the waterpump and it sounded fine. Pin hole on the top was clean so no indications of leaking.
    Thanks to all that provided input. At this point I put everything back and will keep an eye for anything that changes.
  6. Sep 19, 2024 at 2:08 PM
    yarb71
    yarb71 Well-Known Member
    did you ever get this sorted out and figure out what it was?
