Post TSB measurements way off.
Discussion in 'Suspension' started by csxblows, Feb 15, 2013.
  1. Feb 15, 2013 at 7:52 PM
    csxblows
    csxblows [OP] Active Member
    Kevin
    Indiana
    2016 MGM TRD Off-Road
    I recently took my Tacoma to the local Toyota dealer to have the rear spring TSB performed. After the service work was performed, the service rep. said they replaced the rear coils, rear shocks, new bump stops, and for some reason they also replaced the front springs and shocks. The problem is, the driver's side sits 3/4 inch lower on both front and rear. I measured several times with a wood ruler and the same location on both sides with a level, so my measurements are correct. The Measurements are. Driv. Front 34 5/8 Pass front 35 3/8
    Driv. rear 37 Pass rear 37 3/4
    I want to raise the pass front about 3/4" and the Driver front about 1 1/2" to make the truck level in the front. Any ideas would be greatly appreciated.:confused:
  2. Feb 15, 2013 at 7:57 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Search for "Taco Lean"
    Don't see why the dealer would replace the shocks, since your truck already came with the required Bilsteins from the factory, and the TSB explicitly said not to replace them (which means the dealer wouldn't be reimbursed by Toyota for the shocks).
  3. Feb 15, 2013 at 8:32 PM
    KenLyns
    Belly of the Beast
  4. Feb 16, 2013 at 4:15 PM
    blazer190
    blazer190 Active Member
    Walker Louisiana
    TRD offroad 4X4
    Tsb0359-10 does address the shocks as well the springs
  5. Feb 16, 2013 at 5:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Sounds like they installed the driver side on the passenger side, and vice versa.
