Post Up Pictures Of Your Stereo Upgrades!!
Discussion in 'Audio & Video' started by 07speedwayblue, Dec 26, 2009.
  1. Mar 12, 2017 at 2:27 PM
    #461
    OldNeumanntapr
    OldNeumanntapr Well-Known Member
    Santa Maria, CA
    2011 Grey V6 PreRunner Access Cab TRD
    Yeah, it does. I'm pleased with the results. If it were just me I would have installed a bigger box with two 10" subs, but I couldn't use that much space. The wife would not have approved. ;)
    The only other thing I might do in the future is to replace the MTX 4500 (which has a 225 Watt RMS) with another 10" speaker that has a higher power rating.
    I'd also like to put a clear coat on the wood. That would finish it off nicely.
  2. Mar 15, 2017 at 12:42 AM
    #462
    SR5808
    SR5808 Well-Known Member
    J10
    Honolulu,Hi
    Black Prerunner SR5
    Tint/ weathertech visors/ truxedo tonneau cover/ color matched front emblem and door emblems/ Clazzio Leather seat covers/debaged tail gate/depo black tail lights/color matched front grill/led headlights/ Pioneer Avh-5800/ Alpine Type R Front and Rear speakers/ Alpine Pdr-v75/ JL audio 10tw3/ Mr. Marv Custom sub box/amp rack/ Stealth Custom Series Stealth 6 17x8.5/ 265/70/17 Nitto terra grapplers...
    So the metal brackets on the stock headunit fit on the pioneer/metra dash kit combo? I have a pioneer 5800 and used the Metra dash kit with the included plastic brackets and the fit is not that great.
  3. Mar 15, 2017 at 5:32 PM
    #463
    Evan1991
    Evan1991 Member
    yes the stock metal brackets fit much better then the plastic ones. I tried the plastic ones first and couldn't get the deck to line up at all
  4. Mar 16, 2017 at 8:11 AM
    #464
    SR5808
    J10
    Honolulu,Hi
    Black Prerunner SR5
    Good to know! I'm gonna try to refit the headunit with the metal brackets now. Any tips on how the metal brackets should line up with the pioneer? Thanks man.
  5. Mar 17, 2017 at 12:53 PM
    #465
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    So those running amps in back of seat were do you ground your amp ? I'm running Rockford Fosgate P500x1PD amp with 4 ga ground.
  6. Mar 18, 2017 at 9:11 AM
    #466
    killianeric
    killianeric Well-Known Member
    High Desert
    2007 Bass Model Tacoma
  7. Mar 18, 2017 at 11:34 AM
    #467
    lowriderharold
    lowriderharold Member
    2010 Base 2 Dr. Tacoma/ 2WD
    Very nice!
    Where did your bucket seats, come from?
    Would love to have a pair in my 2010 base cab.
  8. Mar 18, 2017 at 4:20 PM
    #468
    killianeric
    High Desert
    Thanks! There were from a totaled double cab that was being parted out, and then reupholstered. I believe the reference photo is from a Bentley
    bcole23 and CG87_ like this.
  9. Mar 18, 2017 at 5:08 PM
    #469
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Man, I love those seats. Sub in the center console?
  10. Mar 18, 2017 at 5:24 PM
    #470
    lowriderharold
    Couple more questions.
    Did you have to drill & tap for the holes to bolt it to the floor?
    And did you have to raise it up any to have the correct ride height?
    Really want to get a pair of these, seats, now.
    Thanks!
  11. Mar 18, 2017 at 9:40 PM
    #471
    OldNeumanntapr
    Santa Maria, CA
    When I mounted my Alpine 3400x1 mono sub amp under the passenger seat I used a screw that was holding down an access cover for the electrical wires as the grounding point. It worked fine. The installer had to drill into the floor for the Alpine 3552 under the driver's seat for the ground.
  12. Mar 18, 2017 at 10:18 PM
    #472
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Yea I ended up drilling floor by LR pass rocker panel. Thanks :thumbsup:
  13. Mar 18, 2017 at 10:33 PM
    #473
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    Question for the masses. Are there any adapters for first gen door speakers, going to 6.5" that add depth to clear the window? Or is it just the normal ones and some woodwork spacers required? Got some hertz' laying in a box and they need to go in. Missing a front speaker so sound is... Off. Thanks.
  14. Mar 19, 2017 at 7:27 AM
    #474
    rob feature
    rob feature Tacos!
    Colorado
    If you figure out how to squeeze a 6.5 in there I'd love to know how. I wanna stick a pair of SI TM65 MKIIs in there real bad.
    Here's what you have to work with
    My Flutes are 67mm deep and they just fit.
    Yeah, I coulda turned the ruler the other way, but the width of the factory mount is about 6 inches.
    The other potential problem with a 6.5. Lots of 6 inch woofers out there though. Many of them are 8 ohm, but maybe?
  15. Mar 19, 2017 at 11:32 AM
    #475
    killianeric
    High Desert
    Thanks! Two 12" Memphis Mojos, one behind each seat and ported through the center console
    I honestly don't remember, the only issue I recall was the harnesses for the air bags
    rob feature[QUOTED] likes this.
  16. Mar 19, 2017 at 12:21 PM
    #476
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    killa (neric) interior. Nice job....:thumbsup:
    killianeric likes this.
  17. Mar 19, 2017 at 1:23 PM
    #477
    rob feature
    rob feature Tacos!
    Colorado
    Very slick. Nicely done! :thumbsup:
  18. Mar 19, 2017 at 4:44 PM
    #478
    Misplaced Nebraskan
    Zach
    Austin
    Thanks for the pics! I've read a lot of 6.5 installs, most people use some MDF of sorts to build spacers to push them away from the window to get more depth. Some trimming is required on the back of the door panel to the lips around the grill. It's not visible once installed. And the 6.5 hertz are 4 ohm. most of the components I looked at are 4 ohm. I was just curious if there was a premade 6.5 adapter with the built in depth adder if you will. Sounds like MDF is the way to go though. I still don't have an amp but want to at least hear some music so I'm gonna install them for now and wire in an amp later. I'll see if I can dig up the thread about cutting them...
  19. Mar 19, 2017 at 4:48 PM
    #479
    Misplaced Nebraskan
    Zach
    Austin
  20. Mar 19, 2017 at 6:13 PM
    #480
    rob feature
    rob feature Tacos!
    Colorado
    I wonder if he actually got that thing in the door. The writeup just sort of died without going there. It didn't seem to me that there's enough room for that MDF ring...let alone both pieces. If memory serves correctly the factory speaker is pretty close to the door card grill. Looks like he had to trim the metal too - that's a deal-breaker. I'll get a refresher soon though - getting back in the doors to seal them up as soon as my SDS order comes to town! I'm going to poke around to see how much room is in the rear speaker pockets too - toying with the idea of subs back there if there's enough airspace.
