Post your '16 MPG
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tincan, Oct 3, 2015.
What is your Gen3 avg MPG
  1. 15-16 MPG
    89 vote(s)
    15.4%
  2. 17-18 MPG
    136 vote(s)
    23.5%
  3. 19-20 MPG
    182 vote(s)
    31.5%
  4. 21-22 MPG
    119 vote(s)
    20.6%
  5. 23-24 MPG
    52 vote(s)
    9.0%
  1. Oct 8, 2015 at 1:00 PM
    #181
    Toyfan84
    Toyfan84 Member
    Charles
    Greenville, SC
    2016 MGM TRD Sport 2x4
    Stock
    I would enjoy that :)
  2. Oct 8, 2015 at 1:01 PM
    #182
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    Yeah we got an 80 mph speed limit here in Wyoming in some sections. Nice and all but come winter a bunch of idiots think its okay to do 85 on black ice.
  3. Oct 8, 2015 at 2:46 PM
    #183
    Caseyb476
    Caseyb476 Active Member
    Casey
    2008 Access cab 2.7l 4x4
    I'm not sure that would be the case. I think most of the gains came from taller gearing and atkinson cycle. If you are flogging it, it'll downshift and go back to otto cycle, and you are effectively running the same drivetrain as a Gen2 (i.e. Otto cycle and shorter gearing).
    My Tundra could actually get better mpgs (up to 21) than my Tacoma (up to 20) if I set the cruise control on a flat highway at 65, simply from a taller 6th. But if you got on the throttle at all, forget it (Tundra = 15 vs Tacoma = 18).
  4. Oct 8, 2015 at 7:24 PM
    #184
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    Many* vehicles will show you "E" or Empty and still have a few gallons in reserve. It's about 2-3 Gal in my '99. So your calculation is incorrect because you assume 21.1 gallons, when it is probably...18.5 gal used.
    Edited: "Most" changed to "many" (not all) to be more correct-ish.
    smitty99 likes this.
  5. Oct 8, 2015 at 8:02 PM
    #185
    Psycho2
    Psycho2 Well-Known Member
    AZ
    '16 DC TRD Sport Barcelona
    TRD Sport, Prerunner, DCSB V6
    Just over 1000 miles logged, half at 70+ MPH - average 21.5 MPG.
    Made a similar trip with 80 MPH speeds for 200 miles of travel in my 2011 (same model style), and the MPG was about 1.2 lower than in the '16 (about a 5% increase). I'll have to see what things look like after a few "regular" tanks.
  6. Oct 8, 2015 at 8:04 PM
    #186
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    Math is hard
  7. Oct 9, 2015 at 1:58 AM
    #187
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    :der: Never would have seen this coming. It's still a truck, if you use and mod it like one, the variables are endless. But it's something to talk about. :rolleyes:
  8. Oct 9, 2015 at 5:52 AM
    #188
    Toyfan84
    Toyfan84 Member
    Charles
    Greenville, SC
    Stock
    Ok so I totally forgot to get you the figures yesterday, but here's what I have. I have driven 182 miles so far, averaging 19.6, with 234 miles to go and a bit more than half a tank left. (Truck's telemetry) Based on this reading I should get 416 miles out of this tank. And that's 90% city driving. Honestly I'm impressed.
    (Note: the truck had 92 miles on it when I got it so the 274 isn't all my driving.)
  9. Oct 9, 2015 at 6:48 AM
    #189
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    Gas turbines will never make it as a effective solution for car vehicles for one reason fuel economy. Gas turbine are great for horsepower to weight ratio, for the size and weight, they put out a hell of a lot of power but burn a Sh...t load of fuel doing so. Piston powered engine are be best at extracting power vs fuel burn.
    I fly Jet, Turbo Prop and Piston aircraft. The big airplanes use jet/turboprop engine because they are light weight and the the rest of the weight savings can be used for fuel capacity.
    The smaller aircraft use piston engine because they have the best fuel vs weight vs fuel burn capacity.
    The piston aircraft industry is in a real dilemma right now because the EPA (the agency that cut the testicles of out trucks) wants to outright ban 100LL aviation fuel. As a side note 100LL aviation fuel is not the same as unleaded auto fuel, in fact 100LL aviation fuel has twice the lead content that the old leaded "regular" auto gas had. Do not use that in a modern car engine.
    The problem is in smaller aircraft they haven't been able to develop a engine (jet/turboprop) that gets the same or better fuel economy vs power. So they are focusing on turbo diesel engines that run Jet A which is basically a very refined grade of diesel fuel. The issue they are having is that in the 300 H.P range is the weight of the engine is significantly higher than the avgas counter part which basically makes it a worthless option. They have tried light weight diesel engines only to have them tear apart do to the power pulses tearing the engines apart. They have been tring for 15 years and still are. They have had success in the 200 H.P and lower range.
    As for cars and trucks piston engines are hear to stay.
    The actual Toyota 4 and 6 cylinder engines can put out significantly more power than the ECU allows.
    In the motorcycle world, they have the same issues with neutered engines and terrible power output since they went all electronic fuel injection and ignition. But there is a bunch of add on Fuel mod systems and even ECU mods to regain the HP.
  10. Oct 9, 2015 at 7:05 AM
    #190
    2016_dbag
    2016 POSTURD
    So uh, what's your mpg?
  11. Oct 9, 2015 at 8:06 AM
    #191
    baron55
    MPG on the High and around town is getting into the 20's
  12. Oct 9, 2015 at 8:20 AM
    #192
    Chaboi
    Chaboi Well-Known Member
    I notice most of the people posting are from the southern part of the country where it is warmer. My guess is break in period plus AC use is creating a delta from EPA estimates. Keep in mind that Toyota probably tested these with the tonneau covers so if you don't have one please say so in your feedback.
  13. Oct 9, 2015 at 8:23 AM
    #193
    Quentin
    Quentin Well-Known Member
    Eleanor, WV
    2016 Toyota 4Runner Trail Edition, KDSS
    I've owned 3 Toyotas (2010 4Runner, 2012 Prius v, 2014 RAV4). All 4 of them still have the reserve tank remaining when they tick over to 0. In Toyotas, the range readout isn't how far you can go before you run out of gas. It is how far you can go before you should refill the tank. My 2007 VW GTI was basically dead empty if you let it get to zero. Just a different way of doing things.
  14. Oct 9, 2015 at 8:51 AM
    #194
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    My first gen has gotten 22mpg before
  15. Oct 9, 2015 at 10:32 AM
    #195
    jonnyozero3
    Dry places
    '99 TRD OR V6 M/T
    Yeah, so this is all anecdotal stuff. We can solve this in five seconds.
    Right from page 512 in the '16 Tacoma Owner's manual. 3.2 gallons of reserve fuel when the low fuel light illuminates:
    Quentin likes this.
  16. Oct 9, 2015 at 10:35 AM
    #196
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Tunnel Cover + Front Air Dam = +.5MPG
    Fake Hood Skewp creates parasitic drag, please subtract .25 MPG for hood skewp.
  17. Oct 9, 2015 at 10:45 AM
    #197
    2016_dbag
    2016 POSTURD
    But I like anecdotal stories. Facts suck.
  18. Oct 9, 2015 at 10:47 AM
    #198
    Caseyb476
    Casey
    I don't doubt it. The curb weight is about the same as a VW Golf, and their diminutive size makes them more aerodynamic.
    And they have a cassette player!
  19. Oct 9, 2015 at 10:47 AM
    #199
    jonnyozero3
    Dry places
    '99 TRD OR V6 M/T
    They can be so inconvenient for my worldview and maths!
    Edit: Boss, this snarky comment is not a shot at you btw. :) Just a shot at the way TW is overall.
    2016_dbag[QUOTED] likes this.
  20. Oct 9, 2015 at 10:55 AM
    #200
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Back on topic please
