Post your '16 MPG
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tincan, Oct 3, 2015.
What is your Gen3 avg MPG
  1. 15-16 MPG
    89 vote(s)
    15.4%
  2. 17-18 MPG
    136 vote(s)
    23.5%
  3. 19-20 MPG
    182 vote(s)
    31.5%
  4. 21-22 MPG
    119 vote(s)
    20.6%
  5. 23-24 MPG
    52 vote(s)
    9.0%
  1. Oct 26, 2015 at 2:32 PM
    #421
    Derek G
    Derek G Well-Known Member
    Silverton CO
    2016 TRD OR DC
    Ask any trucker or trucking company. It's simple math and more accurate than what the computer calculates. Miles traveled/fuel consumed= mpg. Much more accurate than what the computer calculates.
    0uTkAsT likes this.
  2. Oct 26, 2015 at 3:43 PM
    #422
    Tharris242
    Tharris242 Technically
    Houston, TX
    2017 TRDOR DCSB 4X4 A/T FP TO BL
    Solid Fold 2.0, Air Dam
    In Texas, pump needs to be accurate to 6 cubic inches per 5 gallons (~0.52%) to pass inspection.
    Over the long term the 'manual method' error in the amount of fuel used in TX is ~0.5% plus the difference in the fill level of the first tank and the last tank. If the fill level differs by one gallon it would only take about 13 fill-ups of 15 gallons to reach ~0.5% error. Who knows what the Tacomas computer fuel error is?
    The speedometer needs to be accurate to 2%. How can the computer be accurate if it doesn't know how fast it is going? If someone calibrates their MPH they will be more accurate than the computer over the long term.
    What other errors are there?
    Edit: actually speedo/odo errors can be worse than 2%; but, I can't find a simple answer.
  3. Oct 26, 2015 at 3:58 PM
    #423
    Derek G
    Silverton CO
    2016 TRD OR DC
    I could care less between the two also, I just know some would be interested in the difference between what the computer comes up with and manual calculations. That little difference is thousands of dollars a year to someone who drives a truck. I don't but know some people have a habit of wanting to know the difference between the two.
  4. Oct 26, 2015 at 4:05 PM
    #424
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    if the speedometer is inaccurate, then the trip indicator is inaccurate. Manual calculations use the trip indicator to calculate the mpg.
    0uTkAsT likes this.
  5. Oct 26, 2015 at 4:11 PM
    #425
    Tharris242
    Houston, TX
    So, manual can be more accurate long term.
  6. Oct 26, 2015 at 4:29 PM
    #426
    Z50king
    Eric
    Southern California
    Stock and loving it
    the computer also receives calibrated information, making the computer indication more accurate
    I'm just using logic here.
  7. Oct 26, 2015 at 4:54 PM
    #427
    Derek G
    Silverton CO
    2016 TRD OR DC
    Not if you're using GPS.
  8. Oct 26, 2015 at 4:57 PM
    #428
    Z50king
    Eric
    Southern California
    Stock and loving it
    Why would anyone do this?
  9. Oct 26, 2015 at 5:19 PM
    #429
    ScTuna
    ScTuna Well-Known Member
    Texas
    2016 Tacoma
    Feel better about 2016 guys.
    My 2014 AC 4 bangher got 380 miles per tank.
    My new 2016 DCLB 4x4 6 bangher first tank net 360 miles
    TacoJonn and 0uTkAsT like this.
  10. Oct 26, 2015 at 5:44 PM
    #430
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Not true. Generally odometers are very accurate and speedometers a little optimistic. Though the signal may originate from the same sensor, the resultant information does not depend on each other.
  11. Oct 26, 2015 at 5:45 PM
    #431
    swimmer
    Tucson
    2016 TRDORAC4WD
    Your logic is flawed.
    0uTkAsT likes this.
  12. Oct 26, 2015 at 6:01 PM
    #432
    hamiltonuh60
    hamiltonuh60 Well-Known Member
    Texas
    2016 DCSB TRD OR 4WD
    Frontrunner, CVT RTT, Foxwing, Switch Pros, OGE, Fox, ADS, TC UCA, Dakar, Superbumps, U bolt flip, blah blah blah
    So I picked my new taco up last night and have already put 500 miles on it due to me traveling a far distance to find a good deal. Anyway after burning thru the first 1/4 of gas I took the pic below and was pretty happy with the results given I had accelerated up numerous freeway onramps and the freeway had some shallow inclines. Yes I agree that the engine does have to downshift for almost every incline to keep pace on the freeway but overall not bad at all.
    TacoJonn likes this.
  13. Oct 26, 2015 at 6:27 PM
    #433
    Derek G
    Silverton CO
    2016 TRD OR DC
  14. Oct 26, 2015 at 6:31 PM
    #434
    Z50king
    Eric
    Southern California
    Stock and loving it
    but they originate from the same signal, and the computer processes them based on the same input signal. There seems to be a calibration feature on this new system.
  15. Oct 26, 2015 at 6:32 PM
    #435
    Z50king
    Eric
    Southern California
    Stock and loving it
  16. Oct 26, 2015 at 6:35 PM
    #436
    Derek G
    Silverton CO
    2016 TRD OR DC
    Regardless if that's true or not there is no flow meter on the injection system or fuel pump. The computer calculates load, rpm, throttle position, etc to "estimate" fuel economy. It will never be more accurate than just the simple math of miles traveled divided by fuel consumed.
  17. Oct 26, 2015 at 6:35 PM
    #437
    swimmer
    Tucson
    2016 TRDORAC4WD
  18. Oct 26, 2015 at 6:36 PM
    #438
    Derek G
    Silverton CO
    2016 TRD OR DC
    My '16 reads about 1/2 mpg lower than actual.
  19. Oct 26, 2015 at 7:14 PM
    #439
    Shipwreck
    Shipwreck Well-Known Member
    Johan
    Centennial CO
    2016 TRD Off Road Tacoma
    Stock
    My 2016 Tacoma reads within 0.5 miles from what I get when I do the math.
  20. Oct 26, 2015 at 9:15 PM
    #440
    Z50king
    Eric
    Southern California
    Stock and loving it
    You think the computer doesn't know how much fuel is going into the injectors?
