Post your 1st gen retrofit (01-04 only)
Discussion in 'Lighting' started by JasonLee, Feb 2, 2015.
  1. Jul 20, 2017 at 2:15 PM
    #201
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    @TRSAndrew
    tymeson[QUOTED] likes this.
  2. Jul 22, 2017 at 10:38 PM
    #202
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    I like the second set of pic's, is everything you mention used to make it like the second set of pic's?
  3. Jul 22, 2017 at 11:49 PM
    #203
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Yessir. But I highly discourage you from using the one piece housings. They're garbage. Not sure how the effect would look on the regular 2 piece units.. Plus, not sure if you're into the backglow effect. But if so, I used ccfls(for a more subtle "glow"), which trs no longer offers. Led halos may be too bright. You could probly achieve the same look with some resistors on the led halos though(which I have no experience with).
    Rldanie and tymeson[QUOTED] like this.
  4. Jul 26, 2017 at 12:27 PM
    #204
    tony2018
    tony2018 Well-Known Member
    How does one separate the DRL signal from the headlights?
  5. Jul 26, 2017 at 12:39 PM
    #205
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    There's a control box underneath the steering wheel, just cut the wire.
  6. Jul 26, 2017 at 12:40 PM
    #206
    tony2018
    Can those 2 wires be routed to the halo's or LED DRL's?
  7. Jul 26, 2017 at 12:57 PM
    #207
    TashcomerTexas
    I'm not sure if you're getting DRL (daytime running lights) confused with the parking lights or not...
    The DRL function keeps the headlights themselves on low beams during the day - people typically find this useless in most scenarios so we disable the function.
    The parking lights are your corner lights that come on when switched on the 1st option of the turn signal stalk.
    Are you trying to go for like a Beamer/audi look? Cause this is how my halos are set up through the parking lights:
    UncleShrek likes this.
  8. Jul 26, 2017 at 1:01 PM
    #208
    tony2018
    No, I'm talking about the DRL's. I wanted to see if they can be separated from the headlights so I can either use the halos as DRL's and HID for the main headlights.
  9. Jul 26, 2017 at 1:07 PM
    #209
    TashcomerTexas
    In a perfect world we could have that. However that would be too much wiring.
    You're better off tapping into the parking lights. It'll work the same as I pictured above ^
    In addition you can also choose if you want to turn the halos on/off on the fly.
    I start my truck with the parking lights on therefore the halos by themselves automatically come on without the headlights. When it's nighttime switch it one more to turn the headlights on - however the halos will still be on.
  10. Jul 26, 2017 at 1:12 PM
    #210
    tony2018
    I'll probably end up doing that. Thanks.
  11. Jul 26, 2017 at 1:14 PM
    #211
    TashcomerTexas
    Let me know if you need help or pics! Very simple.
  12. Jul 26, 2017 at 1:29 PM
    #212
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I wired my dual switchback halos to a switch so I could turn them on or off and that way I wouldn't have to worry about them being on all the time when the marker lights were on or the projectors. Works great. Then they're also wired to the blinkers and both halos blink whenever I turn.
    In the past, on my other set of retrofits, the RGB Halos were wired to the marker lights but those halos had a remote that you could turn them on & off with too. So they didn't depend on just the marker lights either, but you could still get your 12v power from them.
  13. Jul 26, 2017 at 1:31 PM
    #213
    TashcomerTexas
    Also a good idea to keep in mind!
    Personally I just hate adding more switches. I have dual halos with switchbacks in the rear wired to both the parking and turn signals. And the front halos are just parking lights.
  14. Jul 26, 2017 at 1:35 PM
    #214
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I just used the Rigid brand switch I already had mounted for my 42" light bar above my windshield I took off and sold along with the Eazy company Toyota mounts.
  15. Jul 26, 2017 at 1:41 PM
    #215
    tony2018
    I just downloaded the fsm, I think I know what to do. Will take time though.
  16. Jul 26, 2017 at 1:52 PM
    #216
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    Why didn't you like the one piece housing? Installation or quality of the product?
  17. Oct 2, 2017 at 10:14 PM
    #217
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    Could anyone tell me the difference between the fog light hid system and the lo beam hid system?? I've tried searching but can't find anything
  18. Oct 8, 2017 at 3:15 AM
    #218
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    Do you have pictures where your lights are actually on and not just the evil eye?
  19. Oct 8, 2017 at 12:43 PM
    #219
    TashcomerTexas
    This was recently, not the best pic but I could get one shortly.
    From a distance the projectors are too powerful to show the halos, if you're not in its intended angle you can see the rear halo that I use as a turn signal.
  20. Oct 29, 2017 at 6:31 PM
    #220
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
