Post your 1st gen retrofit (01-04 only)
Discussion in 'Lighting' started by JasonLee, Feb 2, 2015.
  1. Jul 24, 2020 at 8:11 AM
    #241
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    These were D2S 3.0. They now have the 5.0s which are way better. It was an Apollo 3.0 with a front 80mm RGB halo. You can add 110mm to the rear as well
  2. Jul 24, 2020 at 8:15 AM
    #242
    MoneyB86
    MoneyB86 Well-Known Member
    Reagan Country, CA
    2019 MGM Tacoma Double Cab
    BFE5C8D2-0D03-4769-A5E7-CAAA60A2144C.jpg Blackout. Acme Super Mini H1
  3. Jul 24, 2020 at 11:15 AM
    #243
    Rldanie
    Rldanie Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    Awesome
    Thank you!
    what panamera shroud is that? It looks great!
    Also do I order the 9000 for harness?
  4. Jul 24, 2020 at 1:02 PM
    #244
    Rldanie
    Rldanie Punisher78
    Colorado
    Looks like you can only do these halos in White or amber? Yes?
  5. Jul 24, 2020 at 1:32 PM
    #245
    LSC15
    Logan
    2008 TRD D-Cab
    Below is Panamera. You need H4/9003
  6. Jul 24, 2020 at 2:16 PM
    #246
    Rldanie
    Rldanie Punisher78
    Colorado
    Did you put that TRD on there with acid?
    Are all the halos color changing?
  7. Jul 24, 2020 at 2:42 PM
    #247
    LSC15
    Logan
    2008 TRD D-Cab
    Laser etch. I have switchback and color changing
  8. Jul 24, 2020 at 7:19 PM
    #248
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    I’m halfway through my retrofit; I kept the chrome bowl and used a black Apollo 3.0 shroud.
    I'm using:
    LumaWerx™ H4/9003 Switching Ground Polarity Module
    MotoControl H4
    M-LED 2.0
    TYC headlights
    Rldanie likes this.
  9. Jul 24, 2020 at 7:24 PM
    #249
    1997tacomav6
    Denver
    I have read that if you keep the chrome bowl and don’t paint it black there will be some light that will bounce off the chrome.
    Because of that I painted mine flat black.
    Maybe true, maybe not, but it makes sense
  10. Jul 24, 2020 at 7:58 PM
    #250
    mattvivsound
    Southern MD
    I just fired them up again to double check, there is a little light leakage, but it's much less than what an HID pushes out. It looks like there is alot of upper wash in the garage, but with the drywall paper/white walls it looks brighter than it really is.
  11. Nov 9, 2020 at 4:05 PM
    #251
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Did you have to trim those shrouds at all? I just got a new set of lights delivered and I was thinking of going with the Apollo 3.0 in black instead of the mini gatling gun like I used last time.
  12. Nov 22, 2020 at 4:44 PM
    #252
    mattvivsound
    Southern MD
    Yes, I had to trim them on the bottom side. I took out about 2" x 1" piece of plastic for them to sit flat.
    ffirg[QUOTED] likes this.
  13. Dec 10, 2020 at 5:30 PM
    #253
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    @LSC15 or anybody else. I have miramoto H1s (they screw in and no cutting is needed). My question is, i cant adjust these right? I have had them open as i was waiting for my truck to get out of the shop so i can adjust. Then i realized there is no room for adjustments. Am i right? Lol
  14. Dec 11, 2020 at 6:35 AM
    #254
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You mean using the stock adjusting screw on the housing?
    1997tacomav6 likes this.
  15. Dec 11, 2020 at 7:44 AM
    #255
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    No. I mean actually adjusting the projector it self. Someone answered my question in the 1st gen thread. Thank you.
  16. Dec 11, 2020 at 8:24 PM
    #256
    ffirg
    mike
    Anchorage, Alaska
    6159DC31-3036-4BDB-B283-66DAA73071BE.jpg BCD73C45-61D7-4B2B-95F8-2030F69E24EC.jpg Anyone ever have the silicone washer not uniform in size throughout? I’m installing a mini H1 8.0 kit right now and one of the washers is quite a bit thicker one one side. The other washer for the other projector is even in thickness.
  17. Dec 12, 2020 at 6:00 AM
    #257
    1997tacomav6
    Denver
    Defective washer, should be even both of them should be thecsame
  18. Dec 12, 2020 at 7:02 AM
    #258
    Rldanie
    Rldanie Punisher78
    Colorado
    If I get halos and demon eyes, do I have to buy 2 RGB controllers?
    What if I want the demon eyes and halos the same color? Can I get away with one controller?
    what if I want them different colors? Do I need two controllers?
    UPDATE: Found the answer
    Look like you can control up to 6 lights, 3 at a time with one controller
    https://youtu.be/Sw270XAt9ns
  19. Dec 12, 2020 at 9:42 AM
    #259
    ffirg
    mike
    Anchorage, Alaska
    @TRSAndrew
    Thats what I was thinking...man this whole install has been kind of a let down. It was also missing a seal on one of the solenoid wires and one lens has a few small scratches in it. They’re barely noticeable but still...I guess the quality control has gone downhill at TRS or the Black Friday sale just killed them.
    1997tacomav6[QUOTED] likes this.
  20. Dec 12, 2020 at 11:43 AM
    #260
    1997tacomav6
    Denver
    They get killed every year on black Friday.
    But they are excellent on the warranty stuff if u call and exchange the parts, but a r to have to deal with returning parts
