Post your 1st gen retrofit (01-04 only)
Discussion in 'Lighting' started by JasonLee, Feb 2, 2015.
  1. Jan 23, 2017 at 12:38 PM
    #141
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    That would be great.
    Also, how is a passive demon eye done?
  2. Jan 23, 2017 at 1:44 PM
    #142
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Taking apart the projector and painting inside pieces
  3. Jan 23, 2017 at 1:47 PM
    #143
    LSC15
    Logan
    2008 TRD D-Cab
    Here you go Monte. Got two different sets, first ones you will prolly like but second ones not so much cuz halos and stuff
    QMEDJoe and Blackdawg like this.
  4. Jan 23, 2017 at 1:53 PM
    #144
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Do it. You won't. Putting everything back to stock?
  5. Jan 23, 2017 at 1:59 PM
    #145
    LSC15
    Logan
    2008 TRD D-Cab
    I think I'm gonna keep bumper for now lol
  6. Jan 23, 2017 at 2:03 PM
    #146
    TashcomerTexas
    Yeah I don't think I could part with all that given you got a couple of mods on.
  7. Jan 23, 2017 at 2:23 PM
    #147
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nice!
    I like it. Think i'll go this route. I actually like halos. I think i'll be wiring in a DTRL/Switchback one in the rear of the Apollo 3.0s.
    Thanks for the photos!
    And what parts do you paint for the demon eye? not sold on this yet. but wouldn't mind it. Thought about active too.
  8. Jan 23, 2017 at 2:29 PM
    #148
    LSC15
    Logan
    2008 TRD D-Cab
    Yea just a couple lol
    It's nice man. The cutoff shield and surrounding parts
  9. Jan 23, 2017 at 2:30 PM
    #149
    Blackdawg
    Monte
    Wyoming/St. Louis
    hmm..odd.
  10. Jan 27, 2017 at 11:41 AM
    #150
    Blackdawg
    Monte
    Wyoming/St. Louis
    Any tips on housings to use that are nice quality?
  11. Jan 27, 2017 at 1:13 PM
    #151
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    What the fuck is going on here. Did I get the wrong something else too? Hate electrical
    Green circle: Attached to the Acme bulbs. Two wires that plug into something on one side and a connector on the other.
    Yellow circle: Come from the projector.
    High beam connector is empty on the bottom. :notsure:
  12. Jan 27, 2017 at 1:16 PM
    #152
    Blackdawg
    Monte
    Wyoming/St. Louis
  13. Jan 27, 2017 at 1:20 PM
    #153
    WildLand
    Josh
    NM
    16T4RSR54WD
    Here is what I was given:
    Wire harness: MOTOCONTROL BI-XENON: H4/9003\
    Projector: i-xenon: ACME Standard Version (H1)
    Ballast: 35W: ACME SpeedyStart Ballast
    Bulbs: H1: ACME 5000K
  14. Jan 27, 2017 at 1:24 PM
    #154
    Blackdawg
    Monte
    Wyoming/St. Louis
    The yellow circle is from you projector as is its the shield wiring or the halo? If its the halo, you put that where ever you want. Most splice it into the marker lights. If its a switch back it'll have a controller and you'll splice the controller into the markers and the blinkers.
    If its the shield it should go into the controller for the ballasts.
  15. Jan 27, 2017 at 1:28 PM
    #155
    SlipperyTaco
    SlipperyTaco Slippery when Wet
    Chandler, AZ
    04 Tacoma 4x4 & 2014 4Runner Trail Premium
    FOX 2.5 C/O, CAMBURG UCA, FOX 2.0 REAR, SMP CUSTOM FRONT BUMPER, BAMF LCA SKIDS, SCS RAY 10 MATTE GREY WHEELS, 305/70/16 BFG KO2, ALL PRO STANDARD LEAF PACK, ALL PRO SLIDERS, U-BOLT FLIP KIT, MARLIN CRAWLER REAR BUMPER, TIMBREN REAR BUMPSTOPS, WHEELERS SS BRAKE LINE F/R, D-BADGED, GIBSON CAT BACK, K&N CAI, LINE-X , GREY WIRE MOD, APOLLO 3.0 SHROUDS, D2S XB 5500K HID BULBS, LED HALOS, LED DEMON EYES, TRS LED BULBS, BHLM, IGGY PODS, CALI RAISED PODS, 30" CALI RAISED 4D LIGHT BAR, BESTOP SUPERTOP, TRASHAROO , WET OKOLE SEAT COVERS. 4 RUNNER- 2014 TRAIL PREMIUM W/KDSS KINGS FRONT AND REAR DIRT KING BALL JOINT UCA METAL TECH LONG TRAVEL SPRINGS METAL TECH UPPER/LOWER LINKS SONORAN STEEL KDSS TRACK BAR URD EXHAUST URD Y PIPE URD MAF CALIBRATOR PEDAL COMMANDER PRINSU ROOF RACK RIGID ADAPT LIGHT BAR SCS SR8 17" GUNMETAL 285/70/17 FALKEN WILDPEAKS TRS FOG LIGHTS TRS HID KIT SS OFFROAD SLIMLINE WITH SIDE PROTECTION COASTAL REAR SWINGOUT HEFTY FAB SKIDS
    Its hard to explain without being there .. So you have no demon eyes and no halos correct?
  16. Jan 27, 2017 at 1:54 PM
    #156
    WildLand
    Josh
    NM
    16T4RSR54WD
    The yellow I believe is the shield wiring as my halo wiring is out of the picture.
    There is no other place on the harness for a plug. As you can see in the bottom right of the picture - one side of the ballast goes to the bulb and the other side (top rightish) is connected to the wire harness so that's where my confusion is from
    I do. But not in this picture and not worrying about those yet.
    Following this I guess I shouldn't worry about the wires in the green circle. My yellow circle goes into the high beam output in the picture
    Edit: I was just worried because last night I did this wiring and when I tried my high beams my headlight went dark. Maybe because I was only trying one headlight? I dunno
  17. Jan 27, 2017 at 2:09 PM
    #157
    WildLand
    Josh
    NM
    16T4RSR54WD
    :annoyed:
    Just tried same set up as above and just tried plugged bulbs in. Nothing turns on. No fuses are blown, everything is grounded. Did something get fried when I tried the high beams last night? I dunno what if I followed the wiring instructions just like that last night :notsure:
  18. Jan 27, 2017 at 2:25 PM
    #158
    SlipperyTaco
    Chandler, AZ
    Nothing should get fried from that. Wish i could be more helpful i did mine had similiar issues as u and just some trial and error got it done.
    Maybe @LSC15 can chime in
  19. Jan 27, 2017 at 2:27 PM
    #159
    WildLand
    Josh
    NM
    16T4RSR54WD
    No problem! I figured but it was just weird that when I tried the highs the bulbs turned off and now they don't work (I know those aren't fried because I have one that was new that didn't work as well today) I'll just keep trying!
  20. Jan 27, 2017 at 2:44 PM
    #160
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Unplug the the ballast from the harness connector and plug it back in. Also make sure your grounds are metal to metal with no paint.
    The green circled wire is for custom wiring to a ballast and factory harness. Not needed.
