Post your 265/75 16s!
Discussion in 'Wheels & Tires' started by littlezav, May 29, 2017.
  1. Oct 17, 2024 at 5:02 PM
    #2081
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  2. Oct 18, 2024 at 10:23 AM
    #2082
    KOG89
    KOG89 Well-Known Member
    Castroville C.A
    09 DCSB 4x4 6spd manual
    Ome 2.5 lift front and rear, 886 coils on 9k nitrochargers with hd rear leaf springs. Ko2s on level 8 mk6 wheels. Prinsu roof rack , Bakflip tonneau cover
    Just got some new wheels and tires a few days ago. Still rocking the ko2s since the wild peaks were out of stock. Went with the white lettering on the outside this time.
    Polythemus, rb9228, 2001 4x4 and 3 others like this.
  3. Oct 21, 2024 at 2:58 PM
    #2083
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    265/75/16 BFG A/T's....
    It was time to try something different... went with 275/70/17 Toyo R/T Trail. Wanted to fill wheel wells a bit more/ more width/ but not large enough to require cmc, power loss, regear, etc. Had to do some minor plastic trmming/mud flap modification.
    2"/2.25" lift in above pictures: Icon Stage 8... coilovers at factory set height/ RXT leaf packs at option 2.
  4. Oct 21, 2024 at 4:32 PM
    #2084
    fortyeight
    fortyeight Member
    Canada
    So far so good. The first few days of having them it rained and rained and rained, lol. They are better with wet pavement no questioning that.
    Regards to road noise ahhh I really couldn't say truck has TRD exhaust and to be honest that is quite noisy, but when rolling not on the pedal very similar to KO2s. Not that bad as long as you are adamant on rotations every oil change maybe even before oil. And with these new oil interval changes maybe even more. I usually do it every 8000 km as I have been riding BFG KOs & KO2s for many years and probably close to half a million kilometers.
    This past weekend we burned a couple tanks of fuel on the highway and no real change in fuel consumption either. yes it less km per tank then those factory goodyears but not much and every trip depends on how hard a drive it. So fuel consumption is with the beholder of the pedal, every time, lol and it is a truck, its gonna burn fuel.
    The outside is a little more aggressive, the inner tread nice and tight similar to the KO2s with a little change. So should make a good every day tire as I have always used them. Snow will soon come and she how they behave then, but i am expecting a decent usable winter tire as before with the Ko2s. Not the best winter tire, but hey they are not winter tires, if you want winter tires ya best buy winter tires. I ride the BFG's cause i dont want to shag with that, i just want a tire that i can out on, rotate a lot and mile them out. BFG have always been good for that to me.
    The shop left them at 35psi when installed which i have recently dropped a couple psi. This is always a tricky setting. opinions vary, but if i am not towing i dont see the need. I find the 32 mark has been a sweet spot for me. from my experience running higher pressure if not towing leads to fast tire wear.
    Gezz that was a lot lol. hope it provides some useful feedback for ya
  5. Oct 25, 2024 at 11:43 AM
    #2085
    ChamoyNito
    ChamoyNito New Member
    Stock height
    265 70 r16
    I have just about 50k miles on this set almost time for some new tires definitely getting these again Goodyear Wrangler duratrac on TRD PRO wheels
    chunky_t0mmy, RCrumb and AK Dudeman like this.
  6. Oct 27, 2024 at 4:38 PM
    #2086
    chunky_t0mmy
    chunky_t0mmy New Member
    265/75R16 Kenda Klever R/Ts a 2018 SR5. Bilstein 5100s and OME leaf springs.
  7. Oct 28, 2024 at 5:40 PM
    #2087
    crawlerjamie1
    crawlerjamie1 Granite guru
    Was gonna do a 285 but didn’t really want to deal with rubbing on my daily so I went with these little guys. Falken at4w.
  8. Nov 8, 2024 at 4:59 PM
    #2088
    rctom
    rctom New Member
    2023 TRD Off Road
    I just got a set of Mickey Thompson Baja Boss A/T in size LT265/75R16 installed last week. Stock suspension.
  9. Nov 13, 2024 at 7:33 PM
    #2089
    Tacomek
    Tacomek Well-Known Member
    Tom
    17 TRD OR
    Yokohama geolander g015 265/75/16 with stock suspension.IMG_1502.jpg
    RCrumb likes this.
  10. Nov 13, 2024 at 7:55 PM
    #2090
    Black-capped chickadee
    Black-capped chickadee Active Member
    2020 Quicksand AC SR5
    Falken Wildpeak AT3Ws up front and Falken Wildpeak HT02s in the rear.
    EDIT - I’m an idiot. My tires are 265/70s
  11. Nov 27, 2024 at 2:47 PM
    #2091
    Hans_Gruber
    Hans_Gruber Well-Known Member
    Nick
    13 DCSB TX TRDOR 6MT
    All Stock
    265/75/16 BFG KO3s, mostly stock suspension. Fit great, no rubbing, look awesome!
  12. Dec 8, 2024 at 10:20 AM
    #2092
    Tacomek
    Tom
    17 TRD OR
  13. Dec 8, 2024 at 3:12 PM
    #2093
    dutyfreehutch
    dutyfreehutch Member
    Bend, OR
    2018 Off Road
    AT4s stock suspension
  14. Dec 8, 2024 at 3:42 PM
    #2094
    SoCali_Guy
    SoCali_Guy Well-Known Member
    California
    TRD OFF ROAD
    Still keeping up on this thread.. just replaced these Toyo AT3s w Nitto Grappler G3s
  15. Dec 8, 2024 at 3:47 PM
    #2095
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Any complaints with the E rated ATIIIs? I’m looking to switch to them soon.
    SoCali_Guy[QUOTED] likes this.
  16. Dec 8, 2024 at 4:28 PM
    #2096
    SoCali_Guy
    California
    TRD OFF ROAD
    Good all around.. EXCEPT wet rainy conditions.. these G3s are supposed to be improved in wet conditions
  17. Dec 8, 2024 at 4:33 PM
    #2097
    BLtheP
    Plano, TX
    Interested to see how that goes. Sadly the biggest downfall with the Toyo LTs is the wet traction and that’s exactly what you mentioned as well. Which is the biggest thing to keep me from getting them. However I may still do it anyways, I’m not sure. The SLs just wear out too quickly for me.
    The G3s are somewhat appealing, though I lean more towards Toyo usually. Curious if they do end up working better in the wet.
  18. Dec 8, 2024 at 6:34 PM
    #2098
    SoCali_Guy
    California
    TRD OFF ROAD
    Don’t get me wrong the AT3s are very nice looking, performed well except in rain.. that’s why I waited for the Nitto G3s to see how promising the wet conditions improved for this tire.. remember Nitto & Toyo are sister brands.. so do what’s best for you
    BLtheP[QUOTED] likes this.
  19. Dec 8, 2024 at 6:38 PM
    #2099
    Paul466
    Paul466 Well-Known Member
  20. Dec 9, 2024 at 1:19 PM
    #2100
    Polythemus
    Polythemus Well-Known Member
    B.C. Canada
    2023 MGM Tacoma Trail Edition
    Toyo Open Country 265 75 r16 tires FN Countersteer Type X, 16x8, 0 offset Front clip PPF, ceramic coated.
    265/75/r16 Toyo AT3, FN Countersteer wheels. stock trail edition suspension. no rubbing.
