Post your 265/75 16s!
Discussion in 'Wheels & Tires' started by littlezav, May 29, 2017.
  1. May 29, 2017 at 10:11 AM
    #41
    trdprocement
    trdprocement Well-Known Member
    Michael
    Huntsville Alabama
    2017 Cement TRD Pro 4x4
    265/75/R16 BFG KO2's
    You can go up to a 285 like some people have on the TRD Pro 3rd gen's but turning the steering wheel lock to lock you are going to have minimal rubbing, which you could just do some light trimming and fix, I went with the 265/75/r16 BFG just becuase it is about an inch taller than the stock tire but isn't close at all to rubbing. Definitely get a more aggressive look with the KO2 but without having to trim on a brand new truck in my opinion.
  2. May 29, 2017 at 10:34 AM
    #42
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Truck looked bad with 265s. I would have gone 255/85 but the 285s were really cheap.
    And bigger/more tread and traction for off roading
    9TRDTCO[QUOTED] likes this.
  3. May 29, 2017 at 10:44 AM
    #43
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    klein tools 11 in 1, best screw driver I ever bought for service and lighting. linesmen and that screw driver are often all you need to carry to fix 95% of the service calls I need to do at work haha.
    Dnolie, Heyst, 91859706 and 2 others like this.
  4. May 29, 2017 at 10:46 AM
    #44
    Joe23
    the BFG may fit but I had to remove my front fender flares for the duratracs. At full lock they were rubbing under suspension compression. basically any time I pulled out of my driveway, becaause of the bump at the end of the driveway and being at full lock.
  5. May 29, 2017 at 11:02 AM
    #45
    SilverTacomaGuy
    SilverTacomaGuy Well-Known Member
    Cody
    Central Oregon
    2016 TRD OFF-ROAD
    Little tree air fresheners. Clazzio black leather seat covers.
    Cooper STT Pro's. 265 75 16.
    Coming from being a BFG guy my whole life, I absolutely love the PRO's! Can't say I'll go back to BFG anytime soon.
  6. May 29, 2017 at 11:10 AM
    #46
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Same.
  7. May 29, 2017 at 11:22 AM
    #47
    offthewallsurfer
    offthewallsurfer Well-Known Member
    Looks good! Stock or lift?
  8. May 29, 2017 at 1:44 PM
    #48
    SilverTacomaGuy
    Cody
    Central Oregon
    2016 TRD OFF-ROAD
    Stock
  9. May 29, 2017 at 1:56 PM
    #49
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    Yes, but you can adjust pressures to make it almost negligible.
    Look at a tire that is unmounted (easier to see on a motorcycle or bicycle tire). The 2 beads are naturally pretty close together. To get them to seat on the wheel bead lip you have to blast them with a pretty substantial burst of air. that's why tire shops don't put a valve stem core in when they inflate them to pop the bead on. The narrower the rim, the closer it is to the tires natural state. As you inflate the tire, it pushes the 2 beads away from each other and against the rim seat.
    Friend of mine used to run 34x9 pizza cutters on stock Jeep 7" wheels with no issues. Then he got some 8" wheels with outer bead locks for the same tires. He blew off an inner bead every time out. He switched back to the stock wheels and no more issues. Later he got some 35x12 tires and used the bead lock wheels without ever losing a bead. In his case, the height of the tire exacerbated the issue... but makes for a good example.
    Around here a few years ago, it was thing for the "Bros" to get 12.5" wide mud terrains for their full sized Broncos and put them on 12" wide rims. It made the tires mount up much shorter, but wider, and sometimes it even looked like the tires were wider at the rim than the actual contact patch. I'm sure they never aired those down as they would have popped off on a slight side hill LOL.
  10. May 29, 2017 at 2:03 PM
    #50
    littlezav
    littlezav [OP] Well-Known Member
    Leon
    Brooklyn, NY
    that was a great explanation, thank you
  11. May 29, 2017 at 2:24 PM
    #51
    3rdGenDCOR
    3rdGenDCOR Well-Known Member
    TX
    16 OR DCSB
    That looks great - any chance you could post some more pictures from different angles of the STTs on stock setup? I didn't want to do tires now... but this might push that common sense option out the window.
  12. May 29, 2017 at 2:31 PM
    #52
    TRD-OffRoad_Ben
    TRD-OffRoad_Ben Well-Known Member
    Ben
    2016 TRD OffRoad LB
    Slugra, MTB58, KingZee and 7 others like this.
  13. May 29, 2017 at 3:13 PM
    #53
    wfochris
    wfochris Well-Known Member
    That pictures nails it down for me.
    Got a good vendor you would recommend?
  14. May 29, 2017 at 3:17 PM
    #54
    SR5 BRI
    SR5 BRI Brian Good Sport
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    Toyo ATs 265/75/16s on SCS Ray10s20170527_115132.jpg
    DRob and SilverII like this.
  15. May 29, 2017 at 3:27 PM
    #55
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    265x75r16 nitto trail grapplers. bilstien 5100's set at zero with 885's coils. 2"aal in the rear.IMG_1239.jpgIMG_1240.jpg
    JRE, Malinosan and ZekeH20 like this.
  16. May 29, 2017 at 4:02 PM
    #56
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    How do you like those tires?
    Have you had kbro2s to compare them to?
  17. May 29, 2017 at 5:10 PM
    #57
    SilverTacomaGuy
    Cody
    Central Oregon
    2016 TRD OFF-ROAD
    My dad's friend owns a tire shoo, so I got them for cost.
  18. May 29, 2017 at 5:14 PM
    #58
    SilverTacomaGuy
    Cody
    Central Oregon
    2016 TRD OFF-ROAD
    Here's a couple more I have.
  19. May 29, 2017 at 6:06 PM
    #59
    dot_tom
    dot_tom It's a 4Runner
    Tom
    2017 4Runner TRD OR
    Should have gone 285.
    785FEE11-C6D2-46F1-B250-52C39D84DB9F_zps_7db1cde65cf05184b1697ee7e8cbdda6e95cc8b8.jpg
    5BFA738C-5FB8-4ED9-93A0-1185ACC0E436_zps_65bdc7d78ee9ad5a30709b10fadfc2e029e3dbd9.jpg
    RCrumb, SURFRATT, BTH1 and 19 others like this.
  20. May 29, 2017 at 6:25 PM
    #60
    littlezav
    Leon
    Brooklyn, NY
    i think that looks good! how much lift did you get
    TaCosmere likes this.
