Post your 265/75 16s!
Discussion in 'Wheels & Tires' started by littlezav, May 29, 2017.
  1. Aug 27, 2020 at 9:40 AM
    #1141
    JBD81
    JBD81 Member
    Jamey
    Albuquerque, NM
    2018 Tacoma OR MT
    HID headlights, LED backup lights, DIY Rock Sliders, Clutch ADM, 265/75/16 Pirelli Scorpion AT Plus, Drivers seat mod, LED interior lights,
    Pirelli Scorpion All Terrain Plus 265/75/16. 2018 TRD OR Stock suspension.
  2. Aug 27, 2020 at 11:55 AM
    #1142
    treyfive
    treyfive Well-Known Member
    Brandon
    New York
    2017 PEARL BLUE TACOMA TRD OFF ROAD
  3. Aug 27, 2020 at 12:04 PM
    #1143
    treyfive
    Brandon
    New York
    How do you like this set up? E load tire change performance / the ride stiffness much? Thanks!
  4. Aug 27, 2020 at 12:26 PM
    #1144
    TNFishyTaco
    TNFishyTaco Well-Known Member
    Cory
    Is anyone running this tire size with -25mm offset on a 2nd gen?
  5. Aug 27, 2020 at 12:39 PM
    #1145
    treyfive
    Brandon
    New York
    Looks sweet which tires are these?
  6. Aug 27, 2020 at 12:45 PM
    #1146
    treyfive
    Brandon
    New York
    any rubbing?
  7. Aug 27, 2020 at 12:56 PM
    #1147
    treyfive
    Brandon
    New York
    any rub? stock suspension? gonna get these I think
  8. Aug 27, 2020 at 1:06 PM
    #1148
    treyfive
    Brandon
    New York
    I love it...what's your offset / backspacing? any rub? C load?
  9. Aug 27, 2020 at 1:08 PM
    #1149
    treyfive
    Brandon
    New York
    what tire?
  10. Aug 27, 2020 at 1:09 PM
    #1150
    treyfive
    Brandon
    New York
    any rub?
  11. Aug 27, 2020 at 1:13 PM
    #1151
    mcgov303
    mcgov303 I'd rather be in the mountains
    Denver
    2015 BRM TRD Off Road 4x4
    Toytec 3" w/ AAL, Leer 100R, 16" SCS F5s, 265/75 KO2s, pro grille, cmc
    I am. Will rub on stock suspension
  12. Aug 27, 2020 at 1:19 PM
    #1152
    Pirate1975
    Pirate1975 “What do you do with a drunken sailor...?”
    Steven
    Statesville, NC
    2017 Silver TRD Off-road
    3rd bedrail.32”duratrac tires.CaliRaised bed stiffeners,rear ditch bracket for cb antenna .SOS Concepts sliders,3skids,bedrails.curtis rack.cobra 75 cb.HAM license.887 coils,Bilstein 5100’s,medium Dakar leaf pack,extended rear brake lines,wheeler’s superbumps bumpstops.carrier bearing drop bracket.sway bar delete
    I’ve since moved on..lol..
    There was no rub with the 265/75r16’s.
    If you go larger I would say just do the cab mount and you may have to trim a little plastic..
    I am on 255/85r16 bfg km3’s now..
  13. Aug 27, 2020 at 1:29 PM
    #1153
    TRD-OffRoad_Ben
    TRD-OffRoad_Ben Well-Known Member
    Ben
    2016 TRD OffRoad LB
    I have since picked up a pair of Forerunner TRD Pro Wheels in 17" and am running 265/70/17 KO2 tires in C load. The difference between the 17" c load tires and the 16" e load tires was very noticeable. The C load tires are lighter so acceleration is a bit better, you don't feel the road seams and pavement imperfections as much with the C load tires and they feel like they hold the road a little better than the E load tires (especially when wet). Off road the C load tires are way more plush. The e load may be a bit more rugged than the C's on paper but after logging thousands of miles off road with both I'm happy to report I've never had a flat with either tire. If I was to go back to a 16" wheel and 265/75/16 tires I'd probably give Duratrac tires a try in C load.
  14. Aug 27, 2020 at 3:17 PM
    #1154
    TNFishyTaco
    Cory
    Are those heavier than ko2s and bigger than the other tires? Or just wider
  15. Aug 27, 2020 at 4:39 PM
    #1155
    treyfive
    Brandon
    New York
    thanks so much for the awesome response. This pretty much makes my decision~ Duratrac! I’ll Post pictures once everything is mounted.
    This is why I love TacomaWorld. Thanks again !!
  16. Aug 28, 2020 at 9:09 AM
    #1156
    Pirate1975
    Steven
    Statesville, NC
    33” class.
    Skinny..basically same height as 285/75r16 but narrower..
    These are E loads..will be lighter than E load 285’s.
    C loads are lighter as less ply’s..
  17. Aug 28, 2020 at 12:12 PM
    #1157
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    How did you gain 1.25" of height with 265/75/16 tires?
  18. Aug 28, 2020 at 1:45 PM
    #1158
    Detn8r-Red2
    Detn8r-Red2 Well-Known Member
    NH
    2016 Tacoma SR5 DCSB
    265/75/16 Wildpeak AT3Ws, Softopper, TRD Pro Grille, Prinsu Cab Rack, bed rack, RC 2" front struts and N3 rear shocks, Supreme Suspension AAL
    Wildpeak AT3Ws with 2” lift front and rear.
    Brownie_Man likes this.
  19. Aug 28, 2020 at 5:09 PM
    #1159
    TKitchTaco
    TKitchTaco Subs for work tacos for play
    Trent
    Jersey shore
    2020 AC SR SX super white
    Desert Does it Seat jackers LasFit LED headlight/taillight kit Plastidipped wheel emblems tailgate inserts
    Difference in diameter of a 245 vs a 265 is a little less than 1.25 inches meaning the truck sits higher.
  20. Aug 28, 2020 at 8:10 PM
    #1160
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    True, but your math is incorrect. The tire is 1.25” inches taller. But your truck sits .625” higher because half the tire is above the center of the wheel.
