Post your 265/75 16s!
Discussion in 'Wheels & Tires' started by littlezav, May 29, 2017.
  1. Feb 9, 2021 at 10:20 PM
    #1361
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Honestly i didnt see a change in mpg switching to c load duratracs (265/7516)
    They dont weigh much more than stock.
    My rock sliders dinged my mpg though for sure
    SoCali_Guy likes this.
  2. Feb 9, 2021 at 10:26 PM
    #1362
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
  3. Feb 10, 2021 at 3:47 AM
    #1363
    JustinfromCanada
    JustinfromCanada Member
    Justin
    2020 Tacoma TRD Pro
    none yet!
    that is a beauty truck...is it lifted? What are K02's (newwwww guyyyyy)! lol
  4. Feb 10, 2021 at 4:12 AM
    #1364
    TwinTaco31719
    Eric
    Glenbrook, NV
    Thanks man! Welcome to Tacomaworld!
    It’s stock TRD offroad suspension on 265-75-16 BFG all terrain KO2 tires. The camper shell gives a little height leveling action too lol
  5. Feb 10, 2021 at 8:04 AM
    #1365
    mryan_884
    mryan_884 Well-Known Member
    Michael
    Camano Island, WA
    2017 Tacoma TRD OR
    18216A42-1D0D-4800-B349-BFB4AD2395FD.jpg 265/75/16 KO2’s on trd pro wheels
  6. Feb 10, 2021 at 9:09 AM
    #1366
    JustinfromCanada
    Justin
    2020 Tacoma TRD Pro
    none yet!
  7. Feb 10, 2021 at 1:27 PM
    #1367
    Silvertexastaco
    Silvertexastaco Silver Texas Taco
    Silver 2017 Access Cab
    Sir...when I bought my truck, it came with Goodyear 265/70r16s, which don't look bad. However, I wanted 3 things: a more aggressive look, a little more height and my wheel well filled in. The BFG ALL TERRAIN KO2S did all three without rubbing or changing my gas mileage!!
  8. Feb 10, 2021 at 2:01 PM
    #1368
    JustinfromCanada
    Justin
    2020 Tacoma TRD Pro
    none yet!
    Brother- thank you for the response... did you stick with the 16" rims? The boys at work want me to upgrade to the 17" PRO rims, I am just worried it will be too much tire??
  9. Feb 10, 2021 at 2:26 PM
    #1369
    Silvertexastaco
    20210210_162433.jpg Yep...16 inch rims with no rubbing. Yes.. you can upgrade to a 17, but the larger tire and rim size (17 inch rim) may cause rubbing to mud flaps/tire wall and your gas mileage will decrease due to larger and heavier tire.
    Black Market Shaman likes this.
  10. Feb 10, 2021 at 2:27 PM
    #1370
    MarcM
    MarcM Well-Known Member
    Marc
    Northern Los Angeles County
    You will have more choices in tire load range with a 17 inch rim. There are load range LT, C, and E tires in in a 17 inch rim size. 16 inch rims give you a choice of LT load, which is not as heavy and good for light off road and on road driving. The other load range in a 16 is E. Those are a heavier tire and are better suited for more heavy off road use. They are also usually more aggressive tread patterns, and will use a little more fuel. E range tires are also a stiffer ride when on the pavement. They should last a long time, too.
  11. Feb 10, 2021 at 2:45 PM
    #1371
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    What size and load range did you install on the 16s?
  12. Feb 10, 2021 at 3:38 PM
    #1372
    JustinfromCanada
    Justin
    2020 Tacoma TRD Pro
    none yet!
    wow- you know your stuff! I priced out the PRO rims in 17" today- not cheap. So, if I stay with 16", I think I may go with the BFG. I do about 100Km (60 miles) of highway driving to work each day... The other tire I was told to look at was the Nitto... Thanks for all your info, I appreciate it! I am totally thinking BFG KO2
  13. Feb 10, 2021 at 3:40 PM
    #1373
    JustinfromCanada
    Justin
    2020 Tacoma TRD Pro
    none yet!
    do you have an opinion on the "stance" of the PRO? I think it sits a bit different than your truck- will that effect the look of the 16" tire? should I look at the 17"??
  14. Feb 10, 2021 at 4:35 PM
    #1374
    Silvertexastaco
    It does sit a little different. I added a 2 inch level to the front of mine to get rid of the rake...but trust me- your truck will look GREAT with the BFG KO2S!! HUNDREDS OF GUYS on this site have used and loved them- including myself.
  15. Feb 10, 2021 at 4:38 PM
    #1375
    JustinfromCanada
    Justin
    2020 Tacoma TRD Pro
    none yet!
    should I do the 16" ? or bite the bullet and buy the 17" rims and tires? Thanks for helping me brother
  16. Feb 10, 2021 at 4:50 PM
    #1376
    Silvertexastaco
    It really boils down to preference. You can't go wrong either way. Just make sure that if you go with the 17s, you check for wheel well clearance (rubbing).
  17. Feb 10, 2021 at 4:57 PM
    #1377
    JustinfromCanada
    Justin
    2020 Tacoma TRD Pro
    none yet!
    thanks for all the info brother- hope you are all keeping safe in the US. COVID is everywhere here in Canada- BUT, we seem to be trending down... fingers crossed
  18. Feb 10, 2021 at 10:01 PM
    #1378
    bmxtaco
    bmxtaco Well-Known Member
    Planet Florida
    2021 TRD OR 6MT
    You HAVE pro wheels. Keep them. They’re strong and light and way cheaper than buying a set of 17” 4runner Pro wheels.
    If you really want new tires you’ll have plenty of options in the 265/75r16 size. Toyo at3, falken wildpeak, K02s. Keep those wheels though, your truck is a beast as is.
    Silvertexastaco and Fast1 like this.
  19. Feb 11, 2021 at 6:23 AM
    #1379
    JustinfromCanada
    Justin
    2020 Tacoma TRD Pro
    none yet!
    Did you have to remove the mud flaps? I am struggling between the 265 and the 275....
    Silvertexastaco likes this.
  20. Feb 11, 2021 at 6:24 AM
    #1380
    JustinfromCanada
    Justin
    2020 Tacoma TRD Pro
    none yet!
    what a beautiful truck... why did you remove the mud flaps?
    cheers from Canada
