Post your 265/75 16s!
Discussion in 'Wheels & Tires' started by littlezav, May 29, 2017.
  1. Jan 8, 2022 at 5:54 PM
    #1661
    Low Tide
    Low Tide Active Member
    2015 4WD SR5 DCLB
    265 / 75 R16s, Method 305 NV (16”), anti-tailgate theft, tonneau cover, tailgate lock.
    Posting updated photos with my 265/75R16s since I got new wheels.
  2. Jan 8, 2022 at 8:45 PM
    #1662
    BmTaco91
    BmTaco91 Well-Known Member
    Alberta Canada
    2021 AC TRD OR 6MT
    P265/75/16 wildpeaks on Method 305NV s
    Coolerman, Samuel and trailbound like this.
  3. Jan 13, 2022 at 10:38 AM
    #1663
    Old&fat
    Old&fat Well-Known Member
    21 TRD offroad
    Curious how accurate everyone's speedo/mpg/odometer has been after moving up to 265/75/16. I'm guessing it's little to no difference. Thinking about KO2s for my 2021 offroad with stock wheels.
  4. Jan 13, 2022 at 10:40 AM
    #1664
    WeishaarKC
    WeishaarKC Well-Known Member
    BFG 265/75R16's02.jpg
    trailbound likes this.
  5. Jan 13, 2022 at 11:23 AM
    #1665
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Did you add a tune or regear or anything? Those being 10ply I'm curious how power and mileage got affected? Great looking truck
  6. Jan 13, 2022 at 11:28 AM
    #1666
    Turbojaks
    Turbojaks Well-Known Member
    2007 Radiant Red Tacoma TRD Off Road Double Cab Shortbed 4.0L V6 AT
    Depo blackout lights, hood deflector, level kit, 265/75, wheel spacers, electric train horn
    My speedo seems to be more accurate with the bump up in size.
    taco.MARK and Old&fat[QUOTED] like this.
  7. Jan 13, 2022 at 11:35 AM
    #1667
    Samuel
    Samuel Well-Known Member
    Samuel
    Johnson City, Tennessee
    2022 TRDOR, 2024 RAV4, and 2024 Corolla Hatch
    Nothing major yet.
    I don’t have 265/75r16’s on my 2022 yet, but I believe it’s just a 2-3% difference which isn’t really significant. At 70 you would probably be doing around 72, but from factory the speedometer is rumored to be a little off in the opposite direction, so it might be more true than stock.
    Old&fat[QUOTED] and Turbojaks like this.
  8. Jan 13, 2022 at 11:38 AM
    #1668
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Duratracs saved me from some deep soft clay that day
  9. Jan 13, 2022 at 12:03 PM
    #1669
    WeishaarKC
    Thanks! Nope I didn’t do a thing. It’s my daily driver. Drives great and it’ll run 80 on the interstate at an acceptable RPM. So acceptable I don’t even know what it is because it feels good at that speed. Mileage isn’t great but it’s not horrible. With the lift and the rack I kind of gave up on caring about mileage a while ago.
    Evostaco[QUOTED] likes this.
  10. Jan 15, 2022 at 8:23 AM
    #1670
    Waxifari
    Waxifari Well-Known Member
    Denver/Boulder Metro
    2021 Pro
    I would trust the tire calc math on the forum tool before I would put value in anecdotal feedback.
    That said, just swapped my stockies for the wildpeaks in 265 75 R16 and cant notice a difference but likely am running slightly faster than Spedo as per the calc
    tirecalc
  11. Jan 15, 2022 at 8:53 AM
    #1671
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    ???????????? I wouldn't trust that tire size and resulting numbers.
    Further, if you think every 265/75-16 tire from all manufactures will have identical specs, you are in for a big surprise.
    With my 265/75-16 Michelin tires and a Garmin XT GPS I've found the speedometer reading is now accurately depicting the speed of travel.
    In addition, over several 100 mile tests, I found that the actual distance
    traveled is 2.9% further than what the odometer displays. 100 mile displayed on odometer and GPS indicated 102.9 miles.
    The MPG function will be off also. If you calculate the MPG based on gallons used and actual distance traveled, the MPG will be better than the MPG function has displayed.
    Road_Warrior likes this.
  12. Jan 15, 2022 at 9:02 AM
    #1672
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    When I went to 265/75/16 it corrected my speedo. When I drive by the radar activated roadside indicators its on the money now. Before they would show about 2 to 3mph lower then what my speedo said. Typical for OEM speedos in my experience with different cars.
    taco.MARK and Turbojaks like this.
  13. Jan 15, 2022 at 9:09 AM
    #1673
    HB Taco
    Curt
    Awesome! Where is that first picture at?
  14. Jan 15, 2022 at 9:18 AM
    #1674
    Waxifari
    2021 Pro
    Pretty obvious typo but I suspect you already knew that before you used it as a reason to get on your soap box.
    I also checked via my garmin and surprise .... the math is accurate in the tool.
  15. Jan 15, 2022 at 11:53 AM
    #1675
    Fast1
    Minneapolis, MN
    Somewhere enroute from highway 550 towards Lake City via the San Juan Jeep Trails. If I remember correctly it was at the top of CorkScrew gulch headed towards Cinnamon Pass.
    Here are a few more of the drive, all the route was done with Michelin Defender LTX tires aired down to 14 psi.
  16. Jan 15, 2022 at 12:01 PM
    #1676
    Fast1
    Minneapolis, MN
    I'll step back up on the soap box you left and ask how much was your odometer off?
    Again, my point was that not all 265/75-16 tires have the same specs and the generic chart you reference is not representative of every 265/75-16 nor 265/70-16. Every manufacture
    has slightly different specs. Some run wider, taller, weigh more, have less rolling resistance and after 75% wear measure differently than new.
    And why did you not just post your Garmin GPS results for all the speeds and odometer results if you really used it like I did when I posted my results?
    Also, with my Garmin XT, my Taco speedometer reads exactly the same result as the GPS for 70 mph. This is not what your chart shows that you posted nor what your so-called GPS comparison produced. Maybe the tires we are comparing, although both sized at 265/75-16, have different results?
  17. Jan 15, 2022 at 6:43 PM
    #1677
    NW_4x4
    NW_4x4 Member
    Northern California
    2020 TRD OR
    Any reason you run 265/75's vs 70's?
  18. Jan 15, 2022 at 7:07 PM
    #1678
    Evostaco
    Nebraska
  19. Jan 15, 2022 at 10:08 PM
    #1679
    Fast1
    Minneapolis, MN
    Wanted to go up one size above stock size that would look a bit better with a suspension lift.
  20. Jan 16, 2022 at 3:57 PM
    #1680
    Old&fat
    21 TRD offroad
    I trust that tool, I just prefer to back up the math with some real world experience. This seems to be a good place for that.
    Fast1 likes this.
