Post your 265/75 16s!
Discussion in 'Wheels & Tires' started by littlezav, May 29, 2017.
  1. Jan 19, 2022 at 4:36 PM
    #1681
    taco.MARK
    taco.MARK Well-Known Member
    Mark
    Atlanta, GA
    16 T4R SR5 4WD
    same. just got mine mounted this evening (from stock 245/75s). my ride home felt so natural for the truck.
    Turbojaks[QUOTED] likes this.
  2. Jan 21, 2022 at 12:23 AM
    #1682
    taco.MARK
    Mark
    Atlanta, GA
    16 T4R SR5 4WD
    just got em mounted.
    Relaxinslax likes this.
  3. Jan 23, 2022 at 1:54 PM
    #1683
    RyanC24
    RyanC24 Active Member
    2019 Tacoma SR5
    None yet
    Like this setup! I want to do it on my SR5. Any rubbing?
    lift/level? Any spacers?
    sorry for the million questions but I’m about to pull the trigger on these same tires/wheels so I want to make sure they’ll fit on mine without rubbing. Thanks!
    Evostaco likes this.
  4. Jan 23, 2022 at 7:33 PM
    #1684
    RyanC24
    2019 Tacoma SR5
    None yet
    This looks so sick! Mind breaking down the cost that you paid for everything? Did you install yourself of have a shop do it? Thanks!
    I want my quicksand to look just like this!
  5. Jan 26, 2022 at 5:22 PM
    #1685
    TheSortaHawaiian
    TheSortaHawaiian Well-Known Member
    21 Lunar Rock TRD Pro
    Did you install the Westcott kit and still have your 265's? I got a 21 Pro and have the kit...thinking of AAL in the back vs the block and keeping the pro rims then going either 265s as to not worry about rub or possibly 285s. Was interested in how 265s might look with the westcott lift.
  6. Jan 26, 2022 at 8:22 PM
    #1686
    RyanC24
    2019 Tacoma SR5
    None yet
    I know this is an old post but what’s the offset on these wheels? How have they been holding up?
  7. Jan 26, 2022 at 8:38 PM
    #1687
    RyanC24
    2019 Tacoma SR5
    None yet
    I know this is old but I just saw it. Looks so sick! I have an SR5 and have been going back and forth on what I want to run without a lift. I think you made up my mind here. I was afraid of rubbing but it doesn’t seem like you had any issues. Still running good?
  8. Jan 28, 2022 at 10:04 AM
    #1688
    Llama_Taco23
    Llama_Taco23 Active Member
    2020 TRD OR DCSB
    40BB2162-4EFD-4678-BD84-CB1F91E91BC5.jpg Finally pulled the trigger on KO2s in the LT265/75R16. So far so good.
    Polaris425, texbaz and trailbound like this.
  9. Jan 28, 2022 at 11:45 AM
    #1689
    Doostur
    Doostur Well-Known Member
    Central East Coast, FL
    2020 TRD Pro w/ Mag SC & YotaWerx Tuned - 2003 DCSB & EXTCB
    265s looked too small after the Wescott kit. Even my wife pointed it out. Looked like I skipped leg day. First pic is 265s. I went to 285s - second pic. Much better. I snagged some icon progressive AALs for $190. You'll shell out a few hundred to get them installed but the ride will be like OEM or better. I only suggest AALs if you have a few hundred pounds of full time weight or less, otherwise look at a full leaf pack. I couldn't justify $800+ for a full pack. IMO 285s, Wescott Kit with AAL with 1 inch wheel spacers is the perfect setup. I run 1.5 inch wheel spacers and rubbed slightly on OEM flaps till i trimmed them.
  10. Jan 31, 2022 at 5:44 PM
    #1690
    Polaris425
    Polaris425 Well-Known Member
    2021 Tacoma TRD
    265-75r16 KO2’s. Stock everything.
  11. Jan 31, 2022 at 7:09 PM
    #1691
    FloridaTaco904
    FloridaTaco904 New Member
    Richard
    904
    2019 SR5
    Tint, Tires, wheels
    Toyo AT3s on vision Manx wheels
    trailbound and Evostaco like this.
  12. Feb 1, 2022 at 4:15 PM
    #1692
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    @Ad Astra KS this should help with some answers
  13. Feb 3, 2022 at 2:17 PM
    #1693
    Phenom3030
    Phenom3030 Well-Known Member
    Jon
    Colorado Springs, CO
    2021 Lunar Rock TRD Pro
    OEM+
    Goodyear Wrangler Duratracs on a stock Pro 359E5502-1A1D-4D29-A95F-080EE9D2DBD3.jpg
  14. Feb 3, 2022 at 4:45 PM
    #1694
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Have you had a chance to try them off-road?
  15. Feb 3, 2022 at 4:49 PM
    #1695
    Phenom3030
    Jon
    OEM+
    Not yet, just got them on today. I’ll report back after my next off-roading experience.
  16. Feb 3, 2022 at 6:05 PM
    #1696
    venkman781
    venkman781 Member
    2019 Black Double Cab Off Road LB
    I’m thinking about pulling the trigger on a set of 265/75/16 KO2s and method 701s to replace the stock wheels on my ‘19 Off Road. Discount Tire has the TPMS sensors as an add on. Should I include these or can I make use of the sensors I have with my OEM wheels/tires? This is honestly my first truck with TPMS so I have no clue.
  17. Feb 4, 2022 at 10:34 AM
    #1697
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    I plan on having them take my sensors out of my stock wheels. I’m also going to get them to switch over the valve stems to black ones to better match my new wheels.
  18. Feb 4, 2022 at 1:52 PM
    #1698
    VerbotenLime
    VerbotenLime Member
    SoCal
    16x8 0mm KMC TRAIL with Goodyear Wrangler DuraTracs
    Stock suspension with no rubbing
  19. Feb 6, 2022 at 10:16 PM
    #1699
    Praning275
    Praning275 New Member
    2021 Tacoma TRD Pro
    Stock
    Taco_Drew, rip ej1, JakNY and 7 others like this.
  20. Feb 7, 2022 at 3:59 AM
    #1700
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Is that the sl or the lt?
