Post your 265/75 16s!
Discussion in 'Wheels & Tires' started by littlezav, May 29, 2017.
  1. May 4, 2023 at 7:08 PM
    #1941
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    That was with a 2” rough country level in the front.
    Now I have Bilstein 5100’s all around. Set to the 5th perch in the front, with factory springs. Rear is the Icon AAL with a 1/2” shim for an additional 1/2” of height. This is how it looks currently:
  2. May 4, 2023 at 7:40 PM
    #1942
    bryanatc
    bryanatc Active Member
    Bryan
    2020 TRD Off Road
    Thanks, Looks great!
    I currently have Bilstein 6112/5160 with front set to level with the rear. Been back and forth on 265 vs 285. Just ordered 265/75 Ridge Grapplers to mount on some new to me TE37s.
    Road_Warrior[QUOTED] likes this.
  3. May 5, 2023 at 5:30 AM
    #1943
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Haha that’s so ironic, I currently have 265/75/16 General Grabbers and I’m pretty set on going up to 285’s next. The Ridge Grapplers are at the top of my list and I’ve been doing a ton of tire research.
    I’d love to hear your thoughts on them.
    I previously had 285 Yokohama g003 mud terrains but the MPGs and acceleration/braking took too much of a hit for my liking because I do a ton of highway driving in addition to off roading.
    I’ve been eyeing hybrid tires as a middle ground between the two. I figure I’ve run ATs and MTs so it’s time to give the RTs a try and people seem to love the ridge grapplers.
  4. May 5, 2023 at 6:27 AM
    #1944
    bryanatc
    Bryan
    2020 TRD Off Road
    I don’t have any experience with the ridge grapplers on the Tacoma specifically, or 285s vs 265s. I’ve only run 265s for similar reasons you stated and I haven’t wanted to cut too much. I see stock Tacomas and I think, damn that’s a good look. Then I catch myself down the rabbit hole if 265 vs 285 etc.
    I have run Nitto Trail Grapplers, the MT, on my 2004 silverado. I got 80,000+ miles out of them. Absolutely zero complaints. I replaced the Trail Grapplers with Ridge Grapplers and got 70,000+ miles out of the first set. I replaced those with another set it Ridge Grapplers. The ridge grapplers have great performance on and off road. Road noise is minimal. Truly can’t say enough good things about them.
    I run 265/70/17 Falken Wildpeak AT3Ws on my Tacoma now and they have been great. I would say comparable to my experience with ridge grapplers. I’ve only done about 20,000 miles on these, still have lots of life left. The Wildpeaks were a bang for the buck back when I purchased them and now since COVID, they’re priced with the big name tires so that’s my reason for going ridge grapplers on my next set. I’ll have them mounted up on Tuesday.
    Photo of my silverado. (I recently sold to a friend after 12 years of ownership. It was a sad day.)
  5. May 5, 2023 at 8:21 AM
    #1945
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Yeah the 265’s do everything I need, it’s just with my 2” lift I feel like they look too small now.
    That’s a great write up on the Ridge Grapplers, I really appreciate the info. That is all I needed to know to be sure they’ll be a good choice. I need something I can get a lot of mileage out of because I’ll be taking them across the country at least a few times.
  6. May 8, 2023 at 9:18 AM
    #1946
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Looking for a little advice: I am just starting out in off-roading - kind of. I have a 2018 Subaru Outback that is lifted with bigger AT tires that I have taken on the beach quite a bit and on some gravel roads but not "real" off roading. I got the Tacoma because I want to do a little more adventurous off roading. I live in North Carolina so I want to try the Uwarrie Forest trails and of course on the NC beach. I really don't want to lift this truck unless I absolutely have to but would like to go up to 265/75R16 tires. Are E rated tires a must for off roading ? Has anyone tried these tires and found them good or not so good?
    Pirelli Scorpion All Terrain Plus All-Terrain Radial Tire - LT265/75R16 120S
  7. May 8, 2023 at 9:28 AM
    #1947
    deaps
    deaps Well-Known Member
    2023 TRD OR
    I see shots like this and wish there were a longbed next to my shortbed when I purchased my shortbed.
  8. May 8, 2023 at 9:43 AM
    #1948
    vanhalo
    vanhalo Well-Known Member
  9. May 8, 2023 at 10:04 AM
    #1949
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    You can run that size without a lift and No you dont need E rated for off road but a 2" lift helps a lot. I ran C and SL for 12 years on my Tacoma and only puntured a tire once and I did quite a bit of rock crawling. Actually 20+ years if I count my 1st gen
    vanhalo likes this.
  10. May 9, 2023 at 11:43 AM
    #1950
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Any update on these? I've been eyeballing the maxxis pretty hard
  11. May 9, 2023 at 1:35 PM
    #1951
    TrdTaco20
    TrdTaco20 Well-Known Member
    CenCal
    2020 trd off road cement
    Front Fox 2.5 coilover dsc, rear chevy 63 fox 2.5 12inch shocks
    Oh sorry i should have posted install date, i been running them since march, so far so good. I drive daily to work 90miles one way, all freeway though. Tread looks real aggressive, I thought it was gona be a bad daily tire. As of now I would recomend them price is cheap and pretty good name brand. I got em on sale ebay like 600.00..oh my bad they are 265 70 16s not 75...so price for the 75s may differ.
    Dr. Doom Says and Evostaco like this.
  12. May 13, 2023 at 10:32 PM
    #1952
    Shayaanahmedd_
    Shayaanahmedd_ Well-Known Member
    Shayaan
    2006 dark blue Tacoma TRD sport
    Anyone running MT tires in that size, 2.5 inch liftz 2nd gen, specially before 2011 face-lift would be nice?
    As too what I've heard is that cuz of MT big thread usually they are bigger then like some at
  13. May 15, 2023 at 1:05 PM
    #1953
    bnv
    bnv Boy I say, use CRAWL to sneak up on that dawg!
    Bruce
    San Diego
    2016 Access Cab TRD Off Road 4X4 Quick Sand
    Kings adj, TC UCA, Zeon 10s, PB bumper, BD 30" light bar, BD cornering lights, Line-X Grill, Wheels, Tires Duratracs, tint, gate lettering, glove box lettering, ARB compressor
    May 15
    I asked Discount Tire about KO3 tire release:
    “The BFGoodrich K03 tires are currently not available for aftermarket replacement at this time. There is a possible availability some time in August, however this may just be on the 285 /70 R17 size and available only to dealerships. That is the current situation with the 275 65 R20 size.
    Unfortunately there is no release date at this time for aftermarket replacement for either size and no other sizes have any type of release date.”
    Discount Tire
    Customer Care Agent
  14. May 27, 2023 at 11:21 AM
    #1954
    TACO-TY
    TACO-TY Not so well-known member
    Tyler
    Eastern WA
    '24 SR6-MT DCSB
    Just order this same set in Matte Black. Can you send me some pics of the poke?
  15. Jun 23, 2023 at 6:19 AM
    #1955
    Always running
    Always running Still trying to figure it out
    Bill
    Austin Texas
    2023 SR5 4x4 SX
    RCrumb and Concrete_taco like this.
  16. Jun 25, 2023 at 6:32 PM
    #1956
    JBDCO.CT
    JBDCO.CT Member
    2020 White Tacoma SR5
    265/75/16 wildpeaks with a 2/1 level kit on my 2020 SR5
  17. Jun 26, 2023 at 3:42 PM
    #1957
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
  18. Jun 30, 2023 at 4:17 PM
    #1958
    MGM 22
    MGM 22 Well-Known Member
    23 MGM Pro
    Here is mine with Goodyear Ultraterrain AT 265 75 16 that I got today at discount tire. I am very impressed with these tires but even more with discount tire. First time there but not IMG_20230630_190721258_HDR.jpgIMG_20230630_185509567_HDR.jpg my last, I am now on the hook for a set for my son's truck after I pulled in this Eve! Lol , Thanks @Discount Tire for all your help!
    JBDCO.CT, Evostaco, Fast1 and 3 others like this.
  19. Jun 30, 2023 at 10:38 PM
    #1959
    Jonos Urikan
    Jonos Urikan New Member
    2021 SRUP
    Is this pic with a lift?
  20. Jul 1, 2023 at 12:16 AM
    #1960
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I've ran BFG's and Goodyear. Will never run Goodyear again. IMO. JUNK!
    This time around, after extensive review, I chose Yokohama Geolandar X-AT's because they're supposedly better than bfg in snow. They're also a cross between AT and mud. For the guy that doesn't OR a lot but can if ya want to.
    I chose 75's because of the lift. Speedometer barely changed (maybe 1 mph off at speeds above 55) and they provide a softer ride.
    265/75r16. 2.5" lift and
    1.25" Spidertrax wheel spacers on stock wheels.
