Post your BLACK 3rd Gens
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Steves104x4, Sep 12, 2015.
  1. Jul 21, 2020 at 3:53 PM
    #5761
    Tacospike
    Two Trucks
    Nice
    not about the accident*
    Drewski05[QUOTED] likes this.
  2. Jul 21, 2020 at 3:53 PM
    #5762
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It happens.... Lost an Inferno SR5, got my black TRD Sport M/T
    Welcome to TW!
  3. Jul 21, 2020 at 4:00 PM
    #5763
    fred_on_dirt
    fred_on_dirt Well-Known Member
    2017 Black TRD 4x4 Off-Road
    Tepui, ext Kings, KM3s, CBI armor, Warn winch
    my black 3rd gen is for sale on the forum :). Only problem with black - scratches really show!
  4. Jul 21, 2020 at 4:29 PM
    #5764
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    those wheels and tires look sick
    nice job man
    love it
  5. Jul 21, 2020 at 5:57 PM
    #5765
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Oh man..... I like this truck. Can't justify/afford having another at the moment lol
    Junkhead likes this.
  6. Jul 23, 2020 at 3:41 PM
    #5766
    lukeoct8
    lukeoct8 Well-Known Member
    2017 TRD Sport Black
    Got a little salty.
    Blackbeard83, BOMBS, RockHed and 4 others like this.
  7. Jul 25, 2020 at 1:42 PM
    #5767
    bbahunter
    bbahunter Well-Known Member
    Ma.
    2020 Black Bearded Taco
    Finally painted my sr5 wheels black, and had 265/70/16 Goodyear’s mounted.
    I am satisfied, as I really don’t need bigger tires.
  8. Jul 25, 2020 at 2:01 PM
    #5768
    DarthPat1977
    DarthPat1977 Well-Known Member
    Patrick
    Alabama
    2016 Tacoma SR5 DCSB
    Had the truck about 3 months. Planning some more mods in the future. Started practical, like lighting, removed the air dam...
    Hopefully I'll be throwing some black steel OEM wheels on in the next few weeks.
  9. Jul 25, 2020 at 3:56 PM
    #5769
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Take lots of pictures while it's still clean.... :D
  10. Jul 25, 2020 at 4:03 PM
    #5770
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Favorite mod so far... OEM bedlight kit and switch.
    OEM foglights done too. So that takes care of all the functional lighting mods on my list.
    Blackbeard83, BOMBS, batfeet and 3 others like this.
  11. Jul 25, 2020 at 4:40 PM
    #5771
    pdxrado
    pdxrado Well-Known Member
    Portland, OR
    Black 19 DCSB Sport
    Santiam Pass near Detroit Lake, OR this morning. The 6 banger was working hard climbing a few thousand feet with the ac on blast & towing about 4K lbs.
    Also, I found a trailer hitch that can attach both bike rack & boat trailer.
  12. Jul 25, 2020 at 4:43 PM
    #5772
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Quite the workhorse
    Sammy's Taco likes this.
  13. Jul 27, 2020 at 8:20 AM
    #5773
    BadKitty
    BadKitty Well-Known Member
    Indianapolis
    2017 Black Tacoma TRD-offRoad 6spd
    TRD Intake, TRD exhaust
    City.jpg City 2.jpg Billstein 6112/5160 set on 3-2.
    All Suspension hardware Front and Rear was replaced with Titanium for lifetime, all-weather Endurance.
    2"inch Extension on the 6mt. TRD-PRO shift knob
    Experimented with the 2016 Tacoma TRD-PRO Center Caps which are a direct "drop-fit" to the TRD-Offroad wheels.
    -Personally, I found them a touch too "gaudy" for my tastes and ended doing no caps at all, but for anyone interested they are below
    2017 Toyota Tacoma TRD Off-Road 6mt.
    -TRD™ exhaust
    -TRD™ CAI
    -TRD™ Oil Cap
    -TRD™ Radiator Cap
    -TRD PRO™ Shift knob (+2inch extension)
    -Black Lug nuts
    -Black(gloss)"Bumpershellz™" covers
    Suspenion:Bilstein6112/5160 on setting 3/2
    Tires:Michelin Defender LTX: 265/70r/16
    Hardware: Titanium from Ti-64 -Deep blue@26.2v
    Torque Spec. information: https://www.ti64.com/v/vspfiles/assets/docs/fasteners 101 torque.pdf
    Nut & Bolt Sizes
    -Front Top Hat Nut: M10x1.25 (Qty.6)
    -Front Lower Strut Bolt&nut: M14x1.5x76 (qty 2)
    -Rear strut top Nut size: M10x1.5 (Qty.2
    -Rear lower strut bolt: M12x1.25x70
    -Rear Shackle bolt: M14x1.5 x 100mm long.
    -Front recovery hook: 12 x 1.25 x 60 mm grade 8.8 #90119-A0193
    -M12-1.25 (1.75)
    -front sway link m12
    -license plate bolt/washer M6x1x20mm
    -alignment cam m16
    Torque Spec (Toyota)
    Lug nuts: 83 ft-lbs
    FRONT:
    Brake caliper mounting bolts: 90 ft-lbs
    Brake caliper banjo bolt: 22 ft-lbs
    Steering knuckle to lower ball joint: 59 ft-lbs ~USE LOCTITE~
    Outer tie-rod to lower ball joint: 67 ft-lbs
    Lower control arm to frame (alignment cams): 96 ft-lbs
    Lower control arm to shock absorber: 101 ft-lbs (may vary with aftermarket equip)
    Lower control arm to swaybar end link: 51 ft-lbs
    Lower ball joint to lower control arm: 112 ft-lbs
    Upper ball joint to upper control arm: 80 ft-lbs
    Upper control arm to frame: 87 ft-lbs
    Shock absorber upper mount (3 bolts): 47 ft-lbs (may vary with aftermarket equip)
    Shock absorber center nut: 22 ft-lbs
    Swaybar to swaybar end link: 22 ft-lbs
    Swaybar brackets to frame: 19 ft-lbs
    REAR:
    Shock absorber to axle: 53 ft-lbs
    Shock absorber to frame: 53 ft-lbs
    Titanium Anodize Voltage:
    -Deep blue: 26.2v
    -Also clean in SimpleGreen first, that gets the oil off, that will bake into the metal.
    -suspend in solution with alum. wire
    -use distilled water
    -note solution, temp and TI source
    Toyota Part# for Factory Hardware:
    Strut bolt assembly
    -90105-A0113: bolt
    -90178-A0058: nut
    -91622-41400: washer
    Suspension/Control Arm/Alignment Cam
    -Upper Control Arm Nut 90080-17208 x2
    -Outer Tie Rod 45046-09340 x2
    -CV Dust Cap, Grease Cap 43514-28010 x2
    -Adjust Cam, RIGHT 48409-60020 x2
    -Adjust Cam, LEFT 48190-60020 x2
    -Adjust Cam, LEFT 48198-60011 x2
    -Bolt W Washer 90119-A0166 x2
    -Control Arm Nut 90178-A0001 x2
    -Front Strut Lower Bolt, Bolt Flange 90105-A0113 x2
    -Front Strut Lower Nut, Gear Assembly Nut 90178-A0058 x2
  14. Jul 27, 2020 at 8:39 AM
    #5774
    Sandy94
    Sandy94 Well-Known Member
    The Commonwealth
    Toyota Tacoma
    This. Is beautiful.
    CygnusX191 likes this.
  15. Jul 27, 2020 at 8:57 AM
    #5775
    mean_green
    mean_green Active Member
    2019 TRD Sport DCSB w/tech/prem package
    yes, beautiful. you've done a lot of good work with documentation for everyone to view...
  16. Jul 27, 2020 at 8:58 AM
    #5776
    BadKitty
    Indianapolis
    There were truly divine natural conditions that day. And Indiana in the summer is God's last Gift
  17. Jul 27, 2020 at 9:00 AM
    #5777
    mean_green
    that could easily be mistaken for Illinois, you know... :)
    TacoBuffet and CygnusX191 like this.
  18. Jul 27, 2020 at 9:26 AM
    #5778
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    How's that shifter extension working?
    Also, those center caps don't look too bad.... Lol
    Or Iowa, or Northern Missouri....
  19. Jul 27, 2020 at 9:27 AM
    #5779
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Don't have a whole lotta pics from the trail, had about 12 or so vehicles out, mostly Yotas
    Blackbeard83, Junkhead and BOMBS like this.
  20. Jul 27, 2020 at 9:38 AM
    #5780
    BadKitty
    Indianapolis
    The shift extension ended up being awesome. The added leverage of the height, With the shape of the TRD-PRO knob makes it throw lightly and easily into gear. Its hard to explain without feeling the difference between Factory and the extension, but it translates to a much lighter percieved 'row' from gear to gear, and a closer wheel-to-stick movement that I like.
    MOC221_ likes this.
