Post your BLACK 3rd Gens
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Steves104x4, Sep 12, 2015.
  1. Sep 16, 2022 at 7:01 PM
    #7001
    Hockey71
    Hockey71 Well-Known Member
    Jacob
    Hockeytown, Detroit, Michigan
    2021 TRD Sport
    Thank you. This is a Cali Raised Led rack.
  2. Sep 22, 2022 at 5:16 AM
    #7002
    RobC2
    RobC2 Active Member
    2022 TRD Pro
    2022 TRD Pro arrived at dealer this week. Already have an OEM roof rack and 265/75/16 UltraTerrains ready to go on.
    PatRiot_R3d, H6G, Greene368 and 7 others like this.
  3. Sep 23, 2022 at 12:22 PM
    #7003
    ZooliganLo
    ZooliganLo Well-Known Member
    Carlo
    2020 sr5 4x4
    Still deciding on 285/265!!! Help
  4. Sep 23, 2022 at 1:07 PM
    #7004
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    285 = work
    If it were me I'd just stick with 265. However it really depends on what your actual needs are and how you plan on using your truck for the majority of its life.
    Mall crawler, weekend warrior, commuter, grocery getter....well 285s aren't really functionally better. You'll have the "look" and just waste gas.
    Getting off the beaten path, frequent trips to the trails or offroad park, in the mud a lot.... well 285s and a CMC might be a feasible option.... but honestly theres probably other upgrades you'll be making both before and after to roll those large heavy meats.
    If your SR5 is your daily driver, the 285 juice may not be worth the squeeze on several fronts... like I said.... for me..... I'd stick with 265.
  5. Sep 23, 2022 at 6:25 PM
    #7005
    ZooliganLo
    Carlo
    2020 sr5 4x4
  6. Sep 24, 2022 at 7:02 AM
    #7006
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Hey Carlo
    I have an access cab SR 4x4 4cyl, so basically I opted for the lightest base model (only the utility package is lower than mine). The 4 cyl has nothing on my first gen V6, it's a complete turd...so I knew loading up 85lbs per corner was gonna be NO BUENO.
    I chose a very lightweight 16" wheel (18lbs) and SL 265/75/16 tire (42 lbs) combo that still maintains an aggressive look. I dont need 10 ply, so I stuck with an SL AT tire to save weight. Next time I need tires I'm probably going to go get the new hankook Dynapro AT tires (aggressive 265s that weigh 39lbs). Negative offset caused some scrub radius rubbing on the drivers side front bumper and I'm pretty close to the cab mount on both sides.
    My truck is basically a commuter vehicle that has seen the trail and service roads on occasion. When I do make it off the beaten path it feels like the stock 245s could probably handle whatever I'm doing, so I really dont personally NEED large tires. They look better and are nice to have in the snow. I purchased my wheel tire combo for looks, but mainly for weight to maintain stock like driving mannerisms. I'm steadily getting 20-22 mpg for over 2 years, a bit better in the summer.
    I kept my setup light so my truck still felt spry and responsive. I know 285s on a 4cyl would probably need a regear in order to maintain daily driver mannerisms, especially in areas where there are hills --- not sure how the v6 would handle the bigger tires, but it would probably be better than the 4cyl turd. If you have the i4, I'd imagine you'll be gear hunting pretty bad on 285s.
    My wheels have -25mm offset so I'm sure I'm putting extra stress on my hub bearings, but at 40k miles I haven't had any problems. Again, I'm not offroad all that much and when I am it's not hardcore, so other than normal wear and tear I'm not breaking stuff.
    The way I see it is if this is a DD then 285s are out..... I bought this truck for the long haul and I'm no stranger to the tacoma reliability over 10-15-20 years, that was the reason for me buying another taco, it just ran.. and gave me zero issues. I'd set my rig up to be good for both your weekend trips and daily driving. It's up to you.. choose wisely
  7. Sep 24, 2022 at 7:06 AM
    #7007
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    did you do a cab mount chop? any rubbing? looks really good.
  8. Sep 24, 2022 at 8:06 AM
    #7008
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    @ZooliganLo ....
    I made my argument against 285s.
    Heres a pretty good argument for GETTING 285s...
    Just saying... choices, choices, choices
  9. Sep 26, 2022 at 7:09 AM
    #7009
    Kefka
    Kefka Well-Known Member
    01001010 01101111 01101000 01101110
    2019 MBM TRD PRO
    @PuyallupJon Yes, sir! I may have been able to fit them by manipulating alignment specs to fit but opted for the CMC because I'm lazy.
  10. Sep 27, 2022 at 4:49 PM
    #7010
    4x4Taco2012
    4x4Taco2012 Well-Known Member
    Tim
    Huntingdon Valley, PA
    2022 DCSB Limited 4x4
    TRD lift, TRD SEMA wheels, TRD skid plate, TRD Pro fog lights, TRD Heritage Grill, OEM bed cover, LT275/70/17 Falken Wildpeak AT3Ws, OEM bed lights, OEM all weather floor mats, OEM door skid plates, OEM mud guards, OEM bed mat, Black lug nuts
    I went 275-70-17 but obviously had to change the wheel size. I considered 285s but didn't want to deal with rubbing or CMC and other trimming and felt like 265s would look too small. I'm loving the 275-70-17, feels like the perfect size for a 2/1 lift.
  11. Sep 27, 2022 at 9:03 PM
    #7011
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Picked her up brand new February 2021. Loved every second of it so far.
  12. Oct 2, 2022 at 8:26 AM
    #7012
    Dwreck1
    Dwreck1 Member
    2022 Tacoma TRD PRO
  13. Oct 2, 2022 at 8:41 AM
    #7013
    Tacospike
    Two Trucks
    Nice!
    2k2, Dwreck1[QUOTED] and kona25 like this.
  14. Oct 2, 2022 at 10:53 AM
    #7014
    Skim Taco
    Skim Taco Member
    Brett
    Exit Zero NJ
    2019 Tacoma TRD Sport
    Might have changed my mind with this one! Any other modifications needed beside a 2/1" lift to fit the 275s? I would use the same SEMA wheels as well.
    Looks amazing!
    4x4Taco2012[QUOTED] likes this.
  15. Oct 4, 2022 at 9:06 AM
    #7015
    4x4Taco2012
    Tim
    Thanks. I'm loving this set up and would do it again with no hesitation. No other modifications needed. The 275s definitely feel heavier when you're behind the wheel, but nothing major. I'm still averaging 17 in town and 19-20 on the highway.
  16. Oct 5, 2022 at 8:56 AM
    #7016
    Kalalau
    Kalalau Member
    Lisle, IL
    2021 Black Tacoma TRD Premium
    Toyota TRD Lift, Bakflip MX4, Black RIno Overland wheels, BF Goodrich KO2 tires, Tinted windows
    Same size tires, my Milage is the opposite, 18-19 city 16-17 highway. But I live in the Chicagoland suburban area where the average highway speed is around 80.
    4x4Taco2012[QUOTED] and kona25 like this.
  17. Oct 7, 2022 at 10:38 AM
    #7017
    StricklandJN
    StricklandJN Well-Known Member
    Jonathan
    Upstate, SC
    2017 TRDOR DCSB, 2017 RAV4 XLE
    CF6707E7-1082-4676-A3C7-67E9461CBBA1.jpg I found a trail near my work today
  18. Oct 8, 2022 at 12:01 PM
    #7018
    RobC2
    RobC2 Active Member
    2022 TRD Pro
    New TRD Pro just back from the detailer after paint correction and Modesta BC-04 coating. I had him remove the exterior emblems as well. The 265/75/16 UltraTerrains are on, still need to install roof rack and get the windows tinted.
  19. Oct 8, 2022 at 12:22 PM
    #7019
    H6G
    H6G Well-Known Member
    Far from home...
    ‘18 Blk. Pro/ ‘17 GT350
    '22 Pro suspension/ Custom Deaver springs/ ECGS and...
    Best color choice... Congrats!
  20. Oct 8, 2022 at 2:20 PM
    #7020
    72rtchallenger
    72rtchallenger Member
    terry
    ky
    2013 TRD Sport Tacoma
    TRD Bronze Wheels OEM 16"
