Post your Lifted Double Cab Long Bed Tacoma's
Discussion in 'Suspension' started by Tacomzz09, Feb 22, 2010.
  1. Jan 20, 2022 at 2:10 PM
    #421
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Did you move up settings yet? Post a pic of truck. Stock dclb are 20” hub to fender some were under that when I measured at dealer
  2. Jan 20, 2022 at 2:14 PM
    #422
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    2013 DCLB
    Dobinsons IMS set at stock height
    JBA UCA's
    Dobinsons HD leafs
    5160 rear shocks
    33x10.5 Kenda Klever RT's
    Full skids and sliders
    Also have the medium duty Dobinsons leafs on the trailer :rofl:
  3. Jan 20, 2022 at 2:17 PM
    #423
    Tacolife5
    Tacolife5 Well-Known Member
    Durango, Colorado
    2017 TRD Off Road DCLB
    I have the 6112 up front on 6/5 setting's. Just took off my SPC UCA's and put stock back on. Somehow my lift went from 22.25" hub to fender both sides with SPC. Now with OEM it measures to 23". I have an aluminum front skid plate and sliders. for weight. Any idea why my lift increased with OEM UCA's? I made sure to tighten them up with weight of vehicle on them.
  4. Jan 20, 2022 at 2:21 PM
    #424
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Crazy bro. I’m at 22.25” with my SPC’s at 6/5 setting lost a little lift with sliders but I was right around 22.5. Did you drive truck around a little to cycle suspension? Not sure why it would increase?
  5. Jan 20, 2022 at 2:25 PM
    #425
    Tacolife5
    Durango, Colorado
    Well glad there is some consistency because I was at 22.5 and sliders dropped them to your same height. That was my only guess. I've smashed every g-out on my way to and from work for about 3 days and it hasn't dropped at all.
    So weird bro, I thought it may be less leverage with OEM UCA's or something? Not sure but the SPC looked like a longer distance from bushings to ball joint.
    71tattooguy[QUOTED] likes this.
  6. Jan 20, 2022 at 2:30 PM
    #426
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Yes at least we match up :thumbsup: I have about a litttle over an 1” of rake which I like. If and when I decide to get a front bumper I will switch to 650lb coils. For now I’m good truck drives amazing. Yes aftermarket UCA’s definitely put geometry back when lifted
    Tacolife5[QUOTED] likes this.
  7. Jan 20, 2022 at 2:42 PM
    #427
    Tacolife5
    Durango, Colorado
    I originally had the same thought with 650 coils when I add a bumper, but not sure I"ll need to now!
    Have your SPC's held up well? Mine were shot at 10k miles with proper install, maintenance, greasing, etc.
  8. Jan 20, 2022 at 2:48 PM
    #428
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Wow bro crazy. Mine are fine so far regular maintenance. Off-road about 1-2 times a month.
  9. Jan 20, 2022 at 2:52 PM
    #429
    Tacolife5
    Durango, Colorado
    Must be a bad batch. I kinda noticed some play in the steering and then went in for an alignment since I bought new tires and then really saw how bad it was. I do hit rough roads probably way to fast but it's not like I'm jumping the truck lol
  10. Jan 20, 2022 at 2:58 PM
    #430
    71tattooguy
    Dino
    Petaluma , Ca (707)
    LOL
  11. Jan 20, 2022 at 3:06 PM
    #431
    Montana_Actual
    Montana_Actual ;)
    Coolest trailer ever. Very nice truck too. :fistbump:
  12. Jan 20, 2022 at 3:19 PM
    #432
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Thanks. I get a laugh every time I pull it down the road. Someone has always pulled up beside me with a :thumbsup: or a honk :rofl:
  13. Jan 20, 2022 at 6:06 PM
    #433
    nemo2020
    nemo2020 Well-Known Member
    Rear is 38.5 to the ground and 23.75 to the center of the hub
    front is 37.75 to the ground and 23 to the hub.
  14. Jan 20, 2022 at 6:10 PM
    #434
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Maybe running 650 coils with no weight will give 1/2” more lift for bumper armor etc. Check coils for Bilstein number. Every truck is different as well
  15. Mar 2, 2022 at 11:17 AM
    #435
    Lukehugo19
    Lukehugo19 Active Member
    SK CAD
    21 TRD DCLB 1H5
    - Dobinson ext travel coilovers 240lb - Dobinson ext travel rear shocks - Dobinson 500lb leaf packs - Greasable shackle bolts - Dobinson UCA - Dobinson sway bar relocate - Energy ext bump stops - Prinsu rack with PPF - Diode dynamics ss3 fog lights - Fifteen52 turbomac HD classic - Spidertraxx 1.25” hub centric - Mickey Thompson baja ATZ 305’s - Alpharex Pro series headlights - Sequential mirror signal lights - Bed lighting - Plate lights - Tail Lights - Reverse lights - Bed mat - TRD pro grill - Full front end PPF - Black out badges - OK expedition full skid
    2021 Cement DCLB TRD sport premium
    • Dobinson ext travel coilovers 240lb
    • Dobinson ext travel rear shocks
    • Dobinson 500lb leaf packs
    • Greasable shackle bolts
    • Dobinson UCA
    • Dobinson sway bar relocate
    • Timbren bump stops
    • Prinsu rack with PPF
    • Diode dynamics ss3 fog lights
    • Fifteen52 turbomac HD classic
    • Spidertraxx 1.25” hub centric
    • Mickey Thompson baja ATZ 305’s
    • Alpharex Pro series headlights
    • Sequential mirror signal lights
    • Bed lighting
    • Plate lights
    • Tail Lights
    • Reverse lights
    • Bed mat
    • TRD pro grill
    • Full front end PPF
    • Black out badges
    • Trd decal removal
    • V6 Badge removed
  16. Mar 2, 2022 at 2:58 PM
    #436
    9mmMike
    9mmMike Well-Known Member
    Michael
    SE PA
    2019 TRD OR 4x4 DCLB - Cement
    Auto-like for cool dog in pic! And the wheels!
  17. Mar 2, 2022 at 3:26 PM
    #437
    Dreezy
    Dreezy Active Member
    East Bay
    2013 OR, 2020 OR
  18. Mar 5, 2022 at 2:03 PM
    #438
    Mallrat60
    Mallrat60 Not all of us in CA are libs.
    Nor-Cal, Sacramento area
    2015 Dbl cab L/B 4X4
    ADS 2.5 #700 springs, RCI metal fab full skids, JBS UCA, OME rear leaves, Fab Fours front, and rear bumpers, BAMF Rock Sliders and other stuff
    2015 DCLB V6 ADS 2.5 Coilovers 700lbs springs, ADS rear shocks, OME rear leaf springs, RCI full skids, Fab Fours front and rear bumpers, Warn 9.5 CTI winch. Custom dual exhaust.
  19. Mar 6, 2022 at 6:24 PM
    #439
    Rollo67
    Rollo67 Well-Known Member
    18 TRD OR LB. Front: Bilstein 6112 w/600 lb coils (clips 5/6), JBA UCA's. 3" lift. Rear: Bilstein 5160, Allpro Expedition 10 leaf pack, extended rear brake lines, Wheelers bump stops. 4" lift. Wheels: ProComp Extreme 16x7 0 offset. Tires: Cooper Disco AT3 265/75-16.
  20. Mar 6, 2022 at 6:25 PM
    #440
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Looking good :thumbsup:
    Rollo67[QUOTED] likes this.
