Post your lifted tacos!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dman44, Nov 25, 2017.
  1. Nov 25, 2017 at 5:39 PM
    Dman44
    Dman44 [OP] Well-Known Member
    Dustin
    Pearl Ms
    2011 Toyota tacoma
    4 inch suspension lift wheels and tires “so far”
    What lifts do you guys have what size tires are you running?
  2. Nov 25, 2017 at 5:51 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    OME 887's on 5100's up front with JBA Standard High Caster UCA's. Rear is all ICON, 2.0 Shocks with the 3 Leaf Progressive AAL. Wheels ate gonna be 2017 4 Runner Trails with BF Goodrich KO2's in 265/70/17. Those wheels and tires on it now are sold.
  3. Nov 25, 2017 at 6:09 PM
    yota2011
    yota2011 Member
    Chico CA
    TIres,lift,HIDS headlights,sound system,long arms ,rims,tints,shocks
    1inch in front no lift in the back with 33 on it fox shocks coilovers and long arms
  4. Nov 25, 2017 at 6:16 PM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    2012 dcsb 2.75 lift up front currently on Bilsteins 5100s ome 885. Aal and cheap shocks out back. New set up is king's and tc ucas. Shock relocate kit and 14" billies out back and shackle flip.
    yota2011 likes this.
  5. Nov 25, 2017 at 6:16 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Icons coilovers, Dakars and icons in the back
    SPC UCAs 50BACFE3-D9BA-4799-B8D2-3F2811D26118.jpgE7FE1B5A-2CD1-4AAB-85EF-3C5B599245C4.jpg
  6. Nov 26, 2017 at 7:27 AM
    jdg
    jdg Well-Known Member
    David
    Texas Panhandle
    2015 Tacoma SR5, V6, automatic, 4x4, extended cab
    All the time!!!
    I've got a 3" lift, and I just run 265's on mine, and I put air lift on the back for weight to keep it level when I have my camper on it, or some other load. IMG_0442.jpg
    Pigpen and tacotrucktrd15 like this.
  7. Nov 26, 2017 at 7:37 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Up 6 inches with eibach coil springs turning 315-75-16
    1cleanFG, Dman44[OP], bluezzy and 2 others like this.
  8. Nov 26, 2017 at 8:11 AM
    Pigpen
    Dan
    Northwest Montana
    1" spacer or 1" lift? That's a lot of room in the wheel well for a 1" lift and 33s. Looks like my 3" lift and 33s.
    I'm lifted 3" front and rear. OME springs and Billstein shocks. SPC UCAs too
    Bebop likes this.
  9. Nov 26, 2017 at 9:31 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    Wheels:
    Pro Comp Series 7069, 17x9
    Tire Size:
    275/70R/17
    Cooper Discoverers
    1.5" spydertrax wheel spacers
    Lift:
    Pro Kit Rev Tek Lift
    3" front - 1.5" add a leaf Rear
    Firestone Ride-Rite Air bags
    Bebop, Deathray and nevadawolfe like this.
  10. Nov 26, 2017 at 9:38 AM
    Dman44
    Dustin
    Pearl Ms
    2011 Toyota tacoma
    That’s clean
  11. Nov 26, 2017 at 9:43 AM
    Dman44
    Dustin
    Pearl Ms
    2011 Toyota tacoma
    Bro can you take a pic from the front? I wanna see what your wheel spacing looks like I just changed wheels and tires and lost the stance that I had I just want an idea of what the 1.5 looks like as far as spacing
    Bebop likes this.
  12. Nov 26, 2017 at 9:45 AM
    bluezzy
    Monty
    Eugene, Oregon
    Might be the wheel spacers is what did it, I added the 1.5" spydertrax wheel spacers made all the difference.
  13. Nov 26, 2017 at 9:48 AM
    Dman44
    Dustin
    Pearl Ms
    2011 Toyota tacoma
    The rims had a different offset so it pulled my tires outside of the finders just a little bit when I changed them I lost that the wheels are tucked now I just don’t know it I wanna go with the 1.25 or the 1.5. Was just wondering what yours looked like down the side
  14. Nov 26, 2017 at 9:52 AM
    bluezzy
    Monty
    Eugene, Oregon
    Dman44[QUOTED][OP] and Bebop like this.
