Post your mpg
Discussion in '3rd Gen. Tacomas (2016-2023)' started by paramud, Sep 14, 2015.
  1. Sep 23, 2015 at 3:49 AM
    #101
    Frank_Zuccarini
    Frank_Zuccarini Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    Z50king, sir, I think that we can all agree with you that most people can accurately divide gallons into miles.
    But I fundamentally disagree that the ECU calculated mileage is inherently more accurate than manually recording accumulated miles and gas required top off the tank.
    With the manual method, the odometer reading is a possible source of error, but that is true for the ECU method as well, so we can ignore it as a difference between methods. Every pump with an automatic fill option cuts off the flow at a somewhat different level of fill. But this error will disappear entirely in subsequent fill-ups, as long as the fill-ups are done consecutively. The third source of error is the accuracy of the gas pump itself, but these pumps must be calibrated to government mandated standards. We are obliged to live with this, and at the risk of monetary penalties to the gas companies, I trust the accuracy of the pumps.
    The vehicle's ECU, on the other hand, while using the same odometer reading (no difference in error from the manual method), is constantly CALCULATING fuel usage from the frequency and duration of fuel injector pulses. The fuel consumed is inferred, not measured. And this method of calculating fuel consumption is dependent upon the fuel injectors being accurate (no federal or state standards), and the accuracy of the injectors remaining unchanged over time (a rash assumption, given the tendency to foul and restrict flow as time passes). Now, all modern vehicles also have a Fuel/Air Ratio sensor which gives feedback to the ECU, and the injector frequency and duration of fueling will be altered to maintain the desired AFR, so the vehicle runs well, but MPG calculation is not compensated for this.
    For these reasons, I believe that manual measuring and calculation is the better method, especially over time.
    Frank
    Dr.Lou, smitty99 and PackCon like this.
  2. Sep 23, 2015 at 7:02 PM
    #102
    paramud
    paramud [OP] Well-Known Member
    So Cal
    2016 White Tacoma Sport DCLB 2WD
    Ok the hand calculations match the computer to +-.1 looks good to me!
    TacoJonn likes this.
  3. Sep 23, 2015 at 7:09 PM
    #103
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Also, there must be some sampling rate for the computer to gather info and put that into the averaging scheme. Depending on the frequency of this sampling rate many transient states of consumption will be missed.
  4. Sep 23, 2015 at 8:46 PM
    #104
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Whoa! Hell no! They do NOT base fuel mileage on the gas gauge!
    Quit trying to troll us
  5. Sep 23, 2015 at 9:08 PM
    #105
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    Shouldn't you guys be out driving and having fun?
  6. Sep 23, 2015 at 9:11 PM
    #106
    Z50king
    Eric
    Southern California
    Stock and loving it
    I have no Tacoma to go have fun in
  7. Sep 23, 2015 at 9:12 PM
    #107
    ThomasMore66
    Lurking?
  8. Sep 23, 2015 at 9:17 PM
    #108
    Z50king
    Eric
    Southern California
    Stock and loving it
    Researching for future purchase
  9. Sep 24, 2015 at 1:22 PM
    #109
    Tj0hn
    Tj0hn Well-Known Member
    Arkansas
    Stock TRD Sport 4x4
    Edit:
    Just saw this is for 3rd Gen's. Enjoy anyway.
    2012 DCSB 4x4, stock everything.
    I got 16.8 mpg on the last tank. Yellow light to yellow light. All highway miles.
    Pretty shitty if you ask me, but there is probably about ~4k ft of elevation change (up and down) from my house to work.
  10. Sep 24, 2015 at 7:39 PM
    #110
    JasonTsunami
    JasonTsunami Well-Known Member
    Katy tx
    16 Tacoma DC SB tss
    None
    Just picked up my truck. 4x2 ACLB Sr5 V6 with tow package and sr5 app and silly floor mats. Drove it home which was a mix of city and highway. image.jpg
    filthytaco and shr133 like this.
  11. Sep 24, 2015 at 7:45 PM
    #111
    Z50king
    Eric
    Southern California
    Stock and loving it
    Wowz. Once it breaks in, you'll really be in the mpg
  12. Sep 24, 2015 at 7:57 PM
    #112
    Eric NJ
    Eric NJ Well-Known Member
    New Jersey
    If I get 24+ MPG on the 2016 Limited, I will be extremely happy. Right now, with the truck I am driving... I have to drive it like an old lady on the highway to squeeze out 18mpg. I probably avg 16. Going to 24 would improve it by 50% for me.
  13. Sep 24, 2015 at 8:01 PM
    #113
    JasonTsunami
    Katy tx
    16 Tacoma DC SB tss
    None
    I'm going to put up a review tomorrow on the truck with a few pics. I did drive conservative. As well as having ect turned off. But to your point. This is the reason why I bought the 2016 over the 15. Even getting a discounted 15 I would make up the gas difference if I kept the truck more than 4 years with the mileage I drive.
  14. Sep 24, 2015 at 8:47 PM
    #114
    ThomasMore66
    So, if you could add a supercharger...oh, you can't... I got 10 mpg once on a boosted 100 mph jaunt. I felt good about it.
    the.sight.picture likes this.
  15. Sep 24, 2015 at 9:26 PM
    #115
    paramud
    So Cal
    Why would I even want to add a supercharger? The truck takes me to do funner stuff than going 100mph on the freeway.
  16. Sep 24, 2015 at 10:47 PM
    #116
    Tacoma Dave
    Tacoma Dave Long time lurker
    David
    Oakley, CA
    04 xtra cab trd
    2004 trd off road 4X4, 265 75 r16 bfg at, bilstein 5100 all around front at 1in, rear firestone ride rite air bags
    I normally go less than 70. Probably average 65ish.
  17. Sep 25, 2015 at 4:57 AM
    #117
    JasonTsunami
    Katy tx
    16 Tacoma DC SB tss
    None
    100 in your truck... Kinda like all these people wanting to save the world buying Prius then driving 100 on the highway.... Just dumb lmao :facepalm:
  18. Dec 9, 2015 at 10:43 PM
    #118
    visualfaith
    visualfaith Member
    Juve
    2016 Tacoma TRD S
    Hi Everyone, Just joined the group.
    Got the 2016 4x4 Tacoma. Have had it for about 1 month.
    I have been getting ~15mpg. I have been light on the truck. I am wondering if there is too high for that truck. Have anyone see it this high?
    There is now about 3000 km on the truck now.
  19. Dec 10, 2015 at 2:15 PM
    #119
    Bigmikelakers
    Bigmikelakers Well-Known Member
    Los Angeles
    '16 DCSB OR
    Right. If I drive 60-65 for 35 miles (my commute to work) and keep the RPM's constantly under 2000, I am able to squeeze 21-23 MPG's. Driving that slow on LA freeways is funny because even in the right lane's people are riding my ass and passing me pissed off. If I do 75-80 (the way I usually drive), I get 18-19 MPG's. This truck is making me change my driving habits to get the MPG's I want though. On the city streets, I get 13-16 MPG's if I'm lucky. All these red lights and accelerating from dead stops really drains my tank.
    I wonder where and how these EPA numbers are measured? Is it in a lab? Like in a controlled environment? 19 city seems unrealistic. 24 hwy seems obtainable maybe. I had a 2014 Accord Sport 4 banger that said 26 city and 35 Hwy. It was a mission to crack 30 mpg on the highway in that thing. City, I would be lucky to get 21-22 mpg's.
  20. Dec 10, 2015 at 5:23 PM
    #120
    Eric NJ
    New Jersey
    They came up with the numbers while driving down hill.
    Dr.Lou and Bigmikelakers like this.
