Post your mpg
Discussion in '3rd Gen. Tacomas (2016-2023)' started by paramud, Sep 14, 2015.
  1. Apr 23, 2017 at 8:06 AM
    #1481
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    2016 sr 5 v-6 access cab 17" toyo's. 18,309 on the clock. avg right now is 25.3 and has been plus or minus 2 mpg depending on how many signals i encounter. oh, yes, i forgot it's an auto trans.
    MidCitiesMildMan likes this.
  2. Apr 26, 2017 at 8:56 PM
    #1482
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    This is a 2wd 2017 Tacoma Limited.
    This was from Chouteau, Oklahoma (Amish Cheese Store, amazing) to somewhere around mile marker 112 on I44 in Missouri. Went at or under the speed limit the whole way (might have accidentally went 2 over), but some of that was 75 mph on the Will Rogers Turnpike. I drove by foot, letting it slow down going up hills, speeding back up to the limit on the down hill. Average speed was 61 IIRC, but there are some stop lights and a toll booth along the way. This was without a/c.
    The next tank was 24.2 mpg, and was through southern Missouri into St. Louis city, all Interstate until the last miles. With the a/c on running the cruise control at the speed limit.
  3. Apr 27, 2017 at 8:13 AM
    #1483
    Taco280AI
    Taco280AI Well-Known Member
    COS
    2017 TRD OR DCSB 4x4
    Dafuk??? I actually got 24.15 on my last full tank, less than half was freeway at 70. The other driving was my normal commute
  4. Apr 27, 2017 at 8:20 AM
    #1484
    nchastings
    nchastings Well-Known Member
    Noel
    2016 Tacoma TRD Off Road
    Average 15MPG in town, city driving, hard on the pedal - Best highway 18MPG even with cruise control around 68MPH. Was better when I bought it, consistently dropped and seems to be leveling off at these fabulous numbers. What is great though is the massive low end torque I get in exchange for crappy mileage :-\ My 2002 4Runner was getting better than this.
    oldschoolczar likes this.
  5. Apr 27, 2017 at 10:00 AM
    #1485
    MidCitiesMildMan
    I get better overall average with mixed driving, at lower speeds. These trucks aren't very aerodynamic.
  6. May 18, 2017 at 9:21 AM
    #1486
    pc3coyote
    pc3coyote www.pc3coyote.com
    Paul
    SoCal
    17 BBP Sport DCSB 4x4
    2017 DCSB 4x4 V6 with with front spoiler / air dam removed and BFG LT265/70R17 load range C All-Terrain T/A KO2 tires
    Averaging 19.3 MPG after 7201 miles which is a little lower than it actually since I don't have my speedometer recalibrated for the larger than stock tires (likely 3% off - going 62mph when it's reading 60mph)
  7. May 18, 2017 at 9:27 AM
    #1487
    nchastings
    Noel
    I only started using this app recently but this reflects my entire time with the truck. Honestly it got better mileage when brand new and has gradually declined to this.
  8. May 18, 2017 at 10:21 AM
    #1488
    docsg
    docsg Well-Known Member
    South Alabama
    2020 White TRD OR SBDC
    Raptor 4" oval rails, OEM door sill protectors, totally debadged, OEM mud guards, OEM bed mat, OEM S/S tail pipe extension, BDT tailgate letters, Weather Tech sun screen.
    Usually get between 23-25 hwy and 17-19 city (small town lots of start/stop driving) and probably a 20-21 average. Beats the hell of the mpg I use to get with my 12' Tundra and it only had the 4.6L V8 (basically was under-powered for that size truck).
  9. May 18, 2017 at 10:26 AM
    #1489
    imdav2u
    imdav2u Well-Known Member
    St. Louis
    2016 TRD Offroad DCSB 4X4
    I'm averaging 20.5 with mixed in town driving and 10 miles to work on a hilly highway.
  10. May 18, 2017 at 1:48 PM
    #1490
    pepelconde
    pepelconde Well-Known Member
    2016 Trd Sports Silver
    Added oem running boards,sil protectors,trd shifter,tailgate raised inserts, Toyota exhaust tip,husky liners front and rear lund soft trifold tonneau cover,US Army Soldier for Life rear slider glass decal
    3rd gen dcsb trd sport 4x2,w/factory airdam,tonneau cover,running boards,factory wheels and tires no mods.Cruising the west coast in Puerto Rico.This was back in 2016 when truck was purchasedIMG_0279.jpg
  11. May 18, 2017 at 4:23 PM
    #1491
    SBC
    SBC Active Member
    Stock 2016 TRD 4x4 Sport Access Cab MT with a shortened air dam. MPG reset every time I fill the tank.
    Probably 35%town/65%highway on average. I can easily get 17-20mpg driving in town if I keep the rpm low.
  12. May 18, 2017 at 5:04 PM
    #1492
    Hiker46
    Hiker46 Well-Known Member
    Tim
    Colorado
    2023 OR 4X4 Access Cab, Auto Trans,
    OVRLND Camper.
    I've averaged 22.4 over 15K mi. About 95% secondary and highways. Very little stop-n-go city driving. It's very happy from 40-65 mph and using 4WD doesn't change the tank mpg more than 1-2 mpg. The max speed I do is 65 even if the posted limit is 80 (I-70 in UT). Accelerate slowly and glide to stops. The best tank was 27 going from Silverthorne on I-70 over Vail Pass and all the way downhill to Grand Junction. No problems running 85 octane above 4,000 ft elevation, 87 when lower, which is pretty rare. Stock AT AC OR except for RCI aluminum skid and ARE MX cap. I'm happy.
  13. May 18, 2017 at 5:12 PM
    #1493
    oldschoolczar
    oldschoolczar Well-Known Member
    '16 DCSB TRD OR
    Can you elaborate on why you change octane levels at higher elevations?
  14. May 18, 2017 at 5:19 PM
    #1494
    Hiker46
    Tim
    Colorado
    OVRLND Camper.
    My understanding is higher octane retards the firing in the pistons. Given the lower O2 levels at higher elevations the firing is already retarded so 85 works OK. I hear that 85 at lower elevations results in pinging. Not so once you go above 5,000 ft or so. I'm sure someone will chime in with a more-coherent explanation. 87 was the lowest octane I encountered when I lived in New York State. Here in CO and UT 85 octane is pretty common.
  15. May 18, 2017 at 5:29 PM
    #1495
    TurnLeft
    TurnLeft Well-Known Member
    2017 MGM DCSB SR5 V6
    This mpg has always sucked.
    That 4th segment from 23APR was a 1,400mile road trip on all highway and hardly got 15mpg.
  16. May 18, 2017 at 10:27 PM
    #1496
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    You have it backward. Higher octane can allow for more ignition "advance", and more power. If you use lower octane and the system detects knocking it will then "retard" the timing to try to eliminate the knock.
    At altitude, the cylinder pressure is lower already because of lower atmospheric pressure and it won't knock even with 85 octane.
  17. May 26, 2017 at 9:03 PM
    #1497
    kroogdizzle
    kroogdizzle Member
    Wildwood
    2017 MAGNETIC TRDOR DCSB
    TRD Exhaust // TRD Air Filter // Tint // Tonneau
    Only been watching mpg for the past few weeks but this was my best trip mixed city/hwy daily commute. Basically stock '17 TRDOR DCSB. Considering lift and wheel/tire upgrade but don't want to lose this mpg!
  18. May 26, 2017 at 9:27 PM
    #1498
    Krucen 01
    Krucen 01 Well-Known Member
    Andy
    2016 Silver Tacoma DCSB OR TRD
    On a recent 350 mile trip, including some in town driving, I averaged 23.7 miles to the gallon. 75 mph 90% of the trip. Divided number of gallons to top off tank into total miles traveled. MPG seems to keep improving! My 16 Taco takes a licking and keeps on trucking!
    Nedrolls likes this.
  19. May 26, 2017 at 9:29 PM
    #1499
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    I beat all y'all
  20. May 28, 2017 at 8:04 AM
    #1500
    Taco280AI
    COS
    Road trip time, 21.4 and 21.7 averaging 70mph. Pretty lame
