Post your poverty spec !!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by PROseur, Nov 16, 2016.
  1. Dec 11, 2016 at 7:17 PM
    #301
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Automatic differential disconnect. It is what 2001-Present 4X4 Tacomas have instead of manual hubs.
  2. Dec 11, 2016 at 7:26 PM
    #302
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    JPinFL likes this.
  3. Dec 11, 2016 at 7:43 PM
    #303
    PROseur
    PROseur [OP] Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Holy moly that is like porn!!!!!!
    Just ordered some Akebono pads for her. Little much for poverty spec, but decided to splurge :D
    ToxicTwin likes this.
  4. Dec 11, 2016 at 7:43 PM
    #304
    PROseur
    Pussy
    I see.
    2wd here. No such fun
  5. Dec 11, 2016 at 7:46 PM
    #305
    retroboy1989
    99 2.7L 5spd 4x4
    :thumbsup:
    PROseur[QUOTED][OP] likes this.
  6. Dec 11, 2016 at 7:47 PM
    #306
    retroboy1989
    99 2.7L 5spd 4x4
    ADD can be found on some 95-00 models.
    It was even found on some early 89-95 pickups and 4runners.
  7. Dec 11, 2016 at 7:51 PM
    #307
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Nice choice on brake pads. Toyota has Akebono make many of the brake pads that Toyota uses as OEM. Akebono makes a quality brake pad.
    Being that Toyota likely used Akebono pads as OEM on your truck, fortunately this will not pull you out of the poverty spec. :D Lol
  8. Dec 11, 2016 at 7:51 PM
    #308
    PROseur
    Pussy
    Thank you. Nothing but the best for my poverty spec!!!! :D
  9. Dec 11, 2016 at 10:14 PM
    #309
    retroboy1989
    99 2.7L 5spd 4x4
  10. Dec 11, 2016 at 11:21 PM
    #310
    silverbullet02
    silverbullet02 Well-Known Member
    Cole
    Minnesota
    2002 Reg Cab 2.7 5MT 2013 Access Cab Baja 6MT
    Check out my builds! ----->
    Anytime! I myself have never seen these wheels on another Tacoma either, even regular cabs. Quite odd if you ask me. I had did have stock 225/75/R15s, but I'm up to 265/75/R16 KO2s now. As @DJB1 said "ADD" is Automatic Differential Disconnect. I still have to pull the J-shifter (no push button 4x4), just no manual hubs to get out and switch.
    Here's a brochure from 2002 that shows all the wheels and other available options, it seems that those wheels on that Alaska extended cab are one step above the ones from my truck. http://www.russauto.com/ncinv/modelinfo/brochures/02Tacoma.pdf
    Disappointing that those dang white gauges are keeping me out of the cool club :pout:
    PROseur[QUOTED][OP] and JPinFL like this.
  11. Dec 12, 2016 at 12:01 AM
    #311
    DJB1
    Dave
    SLC, UT
    This is why I love poverty-spec trucks with pizza cutter tires, crank windows and manual transmissions; my dad's 1977 Chevrolet Suburban, "Old Blue." It was a 3/4 ton 4X4 with a 350, 4 speed manual transmission, crank windows, no A/C, and a black plastic cubby hole above the AM radio that always had a roll of toilet paper stuffed in it. Even the forest service Suburbans were better-equipped.
    ToxicTwin and PROseur[OP] like this.
  12. Dec 12, 2016 at 7:48 AM
    #312
    PROseur
    Pussy
    Thank you so much for the borschure
    See the first 15" wheel under the 4x2 ?
    I wish I had those
    Those look like the gorgeous 4Runner 5 star wheels that @DJB1 painted white on his truck
    However the OG owner of my truck ordered the last wheels on there the ugly twist 16" :(
    We will have to let you in the cool club, even with your KKk guages :D due to you helping with finding the correct wheels and amazing brochure :)
  13. Dec 12, 2016 at 9:40 AM
    #313
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    From the sounds of things my taco is a high class poverty rig. It's a 4 banger 5spd, manual hubs, man. Tcase, man. windows and locks, etc. But has clock, cruise, ac, tack, buckets, sliding window and aluminum wheels. From the sounds of things that puts her out of the poverty class, but I picked her up for only $1100 so it is what it is.
    ToxicTwin, ExplorHer and DJB1 like this.
  14. Dec 12, 2016 at 10:30 AM
    #314
    DJB1
    Dave
    SLC, UT
    Is your bed bobbed or is it just the angle of the photo?
  15. Dec 12, 2016 at 10:56 AM
    #315
    PROseur
    Pussy
    Nice truck
  16. Dec 12, 2016 at 10:58 AM
    #316
    silverbullet02
    Cole
    Minnesota
    Hooray!! Poverty life is the life for me! :D
  17. Dec 12, 2016 at 11:05 AM
    #317
    PROseur
    Pussy
    Me too.
    Though it seems too many of you NON poverty spec are trying hard to join our "exclusive" club :D
  18. Dec 12, 2016 at 1:47 PM
    #318
    vern650
    brandon
    hyrum, ut
    Yes she's bobbed 11 inches.............I mean she's so hungry from being poor and what not that she's losing weight.
  19. Dec 12, 2016 at 3:01 PM
    #319
    PROseur
    Pussy
    You have v6
    4x4
    Ac
    Tach
    Aluminum wheels
    Bucket seats
    Sliding window
    Only "poverty" in your truck is manual windows
    If yours is poverty,, then I might as well be driving a Daihatsu
  20. Dec 12, 2016 at 3:24 PM
    #320
    cruiserguy
    Elijah
    SEKS
    Lmao! I thought I was poverty pack material too, but now I'm not so sure. I never knew mine was an SR5. I've always thought it was deluxe due to the bench seat and manual everything. My guess is that it is the bare bones SR5 package, without a single upgrade. I'll bet the 'upgrades' it has are due to being SR5; the tach, automatic, and A/C. But it does have manual hubs, does anyone know if you could get an SR5 originally with manual hubs?
