Post your poverty spec !!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by PROseur, Nov 16, 2016.
  1. Nov 17, 2016 at 7:06 AM
    #41
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    Manual hubs avaliable through 2000.
    Punch you vin in at toydiy.com in the parts lookup. It will give trim level.
  2. Nov 17, 2016 at 7:17 AM
    #42
    retroboy1989
    99 2.7L 5spd 4x4
    My DLX 4x4
    Manual everything
    4 cyl
    No tach
    No clock
    Tape player
    It came with split three spoke alloys
    150k
    It now has:
    Fj wheels
    A clock
    Sony stereo
    A cluster w/tach
    DJB1, Dalandser and DustStorm4x4 like this.
  3. Nov 17, 2016 at 7:38 AM
    #43
    PROseur
    PROseur [OP] Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Beautiful truck
    But having click
    Cruise
    Tach
    Makes yours fit for a king and not fit for our poverty spec thread :)
  4. Nov 17, 2016 at 7:39 AM
    #44
    PROseur
    Pussy
    Sexy
  5. Nov 17, 2016 at 8:11 AM
    #45
    schultzboy
    schultzboy Active Member
    Ricky
    Seymour, TN (Knoxville)
    1997 Cardinal Red Tacoma Single Cab
    None. Yet.
    I forgot to mention that mine is a 97.
    PROseur[OP] likes this.
  6. Nov 17, 2016 at 8:26 AM
    #46
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Another miserely build...
    98 Tacoma PreRunner DLX (non-TRD)
    No before pictures -
    Purchased used for 6500 - my eldests first vehicle, it had a SnugTop lid as the only aftermarket access, and was shod with 225/75R15 tires on factory steelies
    Life twists and the truck becomes mine when she bought her own 02 Tacoma PreRunner TRD.
    She sit's today with 225,000~ miles
    Trim Code FD40
    285/75R16's on later model factory alloys (off her 02 when she got set of Ironman TRD rims)
    Converted to 4x4 using knowledge, parts, and assistance obtained through internet forums.
    New 4.88 gears, rear w/ ARB locker
    SAW coilovers up front, Wheeler's 5+3 leaf pack and Bilstiens
    Used front rear bumpers
    self fabricated bed rack (exc welding - outsourced)
    RTT
    Much more.
    Like others juggling life's responsibilities, I've had to do this in bit's and pieces - a little here, a little there. Some over-extension of credit early on, helped with big-ticket items. The 4x conversion took me 8 months. back end first. Daily drive for a while - tranny/trans/rear driveshaft, a month later - front drive components.
    Bought used parts whenever possible, fabricated materials as needed - pinched every dam n penny I could.
    Serves my needs to a T
    Fishmoose, Dalandser and DustStorm4x4 like this.
  7. Nov 17, 2016 at 8:42 AM
    #47
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    I hope I'm not booted out of this thread for having two of them. I'm such a poseur.
    The 1993 Pickup has poverty-spec four cylinder and crank windows but also has A/C, cruise, tilt wheel and intermittent wipers.
    The 2003 Tacoma has white gauges with tach and A/C but everything else is manual. I also gave it manual hubs to make it more poverty-spec.
    But usually people with the largest most heavily-optioned trucks also have the smallest bank account balances. Cruel irony.
    Dalandser, DustStorm4x4 and Willbeck like this.
  8. Nov 17, 2016 at 9:11 AM
    #48
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Lots of manual hubs up to 2000 I believe. Not offered starting in 01 if I am correct.
    Kemosabe[QUOTED] likes this.
  9. Nov 17, 2016 at 9:13 AM
    #49
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    For you poverty friends, can you send pictures of the cruise control module? Mine does not have cruise, but I do have a tach.
    No ABS
    My wipers have on and fast. No intermittent settings.
  10. Nov 17, 2016 at 9:20 AM
    #50
    PROseur
    Pussy
    Wow no fuel light!?!!!
    Man I feel mine is luxurious then compared to guy
    I love love your wheels
    I am looking to find some straight base wheels like yours
  11. Nov 17, 2016 at 9:21 AM
    #51
    PROseur
    Pussy
    Yours are mine are same
    No intermittent wipers
    Where would CC module be ?
  12. Nov 17, 2016 at 9:29 AM
    #52
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Passenger fender I believe. I have a plug there with 4 wires I believe, but nothing connected to it
  13. Nov 17, 2016 at 9:31 AM
    #53
    PROseur
    Pussy
    Mine has the same wheels as you
    With 285/75 is there any rub in factory suspension?
    I have 225/70 on same wheels on mine
  14. Nov 17, 2016 at 9:31 AM
    #54
    pray4surf
    Rick
    Oceanside, CA
    If you can locate the intermittent wiper stalk, it's a simple swap...
  15. Nov 17, 2016 at 9:31 AM
    #55
    PROseur
    Pussy
    I will look at mine today for you
  16. Nov 17, 2016 at 9:32 AM
    #56
    PROseur
    Pussy
    Doesn't rain here
    No issues for me
    3rYODA likes this.
  17. Nov 17, 2016 at 9:34 AM
    #57
    pray4surf
    Rick
    Oceanside, CA
    Lotus - yes, up front, frame rub with wheels fully turned both left and right. Also have some sidewall rubbing the UCA when aired down... Suspension isn't 'factory' however. At least not the coilovers and rear leafs/shocks..
    PROseur[QUOTED][OP] likes this.
  18. Nov 17, 2016 at 9:40 AM
    #58
    PROseur
    Pussy
    You are right about the bank account
    Funny thing is so far no poverty spec 4 door
    You guys are all regular cabs and access cabs
  19. Nov 17, 2016 at 9:43 AM
    #59
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    I think possibly because the 4 door was only available 01 and up, and the Tacoma was being seen less as a workhorse, and more of an adventure vehicle. Less demand for the no frills, no shit good truck
  20. Nov 17, 2016 at 9:47 AM
    #60
    DJB1
    Dave
    SLC, UT
    @lotuscupcar, yours is the only poverty spec 1st gen double cab I've seen. I didn't even know they exist.
    COMAtized99 and PROseur[OP] like this.
