Potential buyer of 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by taco57, Jan 13, 2021.
  1. Jan 13, 2021 at 5:25 PM
    taco57
    taco57 [OP] Well-Known Member
    Jeff
    Columbus Ohio
    2003 Tacoma SR5 4X4 2.7 5 speed
    • VIN 5TEMU4FN0AZ709142
    • Model 2010 Tacoma
    • Grade 4 x 4 LONG
    • Exterior Super White(040)
    • Interior Graphite
    • Engine 6-CYL
    • Body Type Double Cab
    • Drive Type 4WD
    • Transmission 5AT
    • Selling Dealer Beechmont Toyota
    • Servicing Dealer None Selected
    • Date of First Use March 31, 2010
    Additional Vehicle Details
    Order Date:
    10/2009
    Plant of Manufacture:
    Body Style:
    DBL CAB 4X4 V6 L/B
    Tire Make/Brand:
    Tire Size:
    16R245
    Spare Tire Brand:
    PORT OR FACTORY INSTALLED EQUIPMENT
    • CF Carpet Floor Mats & Door Sill Protector
    • Port
    • DK Preferred Owner's Portfolio
    • Port
    • FE 50 State Emissions
    • Factory
    • PQ TRD Sport Extra Value Package with JBL Satellite Audio & Bluetooth
    • Factory
    • RL Daytime Running Lights (DRL)
    • Factory
    • TO V6 Tow Package
    • Factory
  2. Jan 13, 2021 at 5:25 PM
    Taco? Who knows
    Taco? Who knows Well-Known Member
    New England
    2009 DCSB Off Road
    As the post quoted says, put the VIN in there and see what it says. That is the botton line up front, fastest way to get what the truck was as it left the factory.
    The Decals look like they say "Sport" not "Off Road" The switches in the cab don't look like the "Off Road" configuration more like the "Sport" configuration.
    With that many miles the price seems too high to me but you might be able to negotiate it down.
    Good luck.
    Edit: looks like you beat me to it. As you can see it is a "Sport" version not "Off Road" if that matters to you.
  3. Jan 13, 2021 at 5:27 PM
    taco57
    Jeff
    Columbus Ohio
    Thanks to all, you have been a great help. It is fun to shop for someone else!
    fatfurious2 likes this.
  4. Jan 13, 2021 at 5:29 PM
    Taco? Who knows
    New England
    2009 DCSB Off Road
    LOL, that is true, spending someone elses money is always fun!
    fatfurious2 and TomTwo like this.
  5. Jan 13, 2021 at 5:30 PM
    taco57
    Jeff
    Columbus Ohio
    STANDARD INSTALLATION EQUIPMENT
    • safety
      Star Safety System: Vehicle Stability Control (VSC) & Traction Control (TRAC) with Off Switch, Anti-Lock Brake System (ABS) with Electronic Brake Force Distribution (EBD) & Brake Assist Dr & Fr Pass Advanced Airbag System Dr & Fr Pass 3-Point Seatbelts, w/Pre- Tensioners & Force Limiters, Seat-Mntd Side Airbags & Side Curtain Airbags Driver & Front Passenger Active Hdrests 3-Point Rear Seatbelts w/ Adj Headrests, ALR & ELR in All Rear Seating Positions CRS Lower LATCH & Top Tether Anchors Tire Pressure Monitor System (TPMS)
    • interior
      Cloth Bucket Front Seats w/Pass-Side Fold-Flat, Driver-Side Lumbar Support, Adj Headrests & Center Console 60/40 Split Rr Bench w/ Adj Headrests Defroster-Linked Air Conditioning Power Windows / Door Locks / Mirrors AM/FM/CD with 6 Speakers, Aux Audio Input, MP3-CD & Sat Radio Capable Tilt/Telescoping Steering Wheel Engine Immobilizer
    • mechanical & performance
      4.0L V6 DOHC 24V VVT-i 236HP Engine 5-Speed ECT-i Automatic Transmission 4WDemand: Part-Time 4x4 Sys w/ 2-speed Electronically Controlled Transfer Case Automatic Limited Slip Diff (Auto LSD) Coil Over Shock Double A-Arm Front Susp Multi-Leaf Rear Suspension w/Staggered Outboard Mounted Shocks Power Assisted Fr Disc/Rr Drum Brakes 16" Styld Steel Wheels, P245/75R16 Tires
    • exterior
      Black Fr & Argent Rr Bumpers, Blk Hndles Mirrors, Overfenders & LED Taillamps Composite (SMC) Inner Bed w/Steel Outer Panels, Removable Tailgate & Rail Caps Deck Rail System w/4 Adj Tie-Down Cleats
  6. Jan 13, 2021 at 5:36 PM
    Taco? Who knows
    New England
    2009 DCSB Off Road
    All standard equipment with the "Sport" package. I have an "Off Road" so I can't comment on the "Sport" other than to say that is what comes with that level of trim. There are other that can chime in. It is a 4x4 (Body Style: DBL CAB 4X4 V6 L/B) to me that would be one of the must haves for what I intend to do with mine. It also says it is a Long Bed, some like long beds others like short beds.
    I hope this helps.
  7. Jan 13, 2021 at 5:43 PM
    taco57
    Jeff
    Columbus Ohio
    Yes, very helpful. Long bed is more rare isn't it?
  8. Jan 13, 2021 at 5:55 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I feel like the short beds are more rare..
  9. Jan 13, 2021 at 6:04 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Seems like these trucks last a while, but 260K is a lot of miles for me. Otherwise, inspect it the best they can and test drive it. If it has a good maintenance and service history I'd be more relaxed about the miles.
    We have a 2003 Tacoma in our family and we don't plan to get rid of it either. Such a solid truck.
  10. Jan 13, 2021 at 9:12 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    11 year old truck,O.P. IF the truck has no rust and is in good condition,maybe $12,500 ,as thats a lot of miles.
  11. Jan 14, 2021 at 2:53 AM
    taco57
    Jeff
    Columbus Ohio
    Thanks again all, good advice. That's what makes this forum the best!
  12. Jan 14, 2021 at 3:17 AM
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    regardless what bluebook says I'm with notion that 226k for 15k is steep. can find a much better deal elsewhere
  13. Jan 14, 2021 at 7:10 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    My opinion, way too much $$$$ for what it is ( kind'f normal for a dealer). If shopping is fun keep shopping & stay away from dealers. Remember who is paying for those big fancy buildings & shiney shoes the salesmen wear. Remember it's just my opinion.
