Potential Gas Tank Sabotage - 2002 Prerunner Turns Over but Won't Start
Discussion in '1st Gen. Tacomas (1995-2004)' started by DWero, Mar 28, 2022.
  1. Jul 5, 2022 at 2:33 PM
    #121
    DWero
    DWero [OP] Well-Known Member
    D
    2002 Double Cab 4X2 V6 Prerunner
    Unfortunately, no. I had a couple of other things leapfrog ahead of this in regards of importance. Luckily, while a luxury, this truck is not needed, so it can sit in the backyard until I get back to it. I'm equally bummed out and disappointed that what I've done to date hasn't got it running again. I'll most definitely update the thread as news develops. Thanks for the nudge, though!
  2. Jul 5, 2022 at 5:18 PM
    #122
    alexh
    alexh Well-Known Member
    1998 TRD
    I didn't want to say anything when you posted that picture earlier for fear of you over imbibing on spirits....but it looks like your valves were hit with water or something containing moisture and rusted. Not saying this will prevent it from starting/running but it can't be good. The ones that were open when rusted might not be closing. Perhaps a compression test is in order.
    DWero[OP] likes this.
  3. Jul 5, 2022 at 6:13 PM
    #123
    DWero
    D
    Yes, they definitely didn't look good. I will do a compression test among a couple other things I want to try before I start ripping things apart.
  4. Aug 28, 2022 at 10:35 AM
    #124
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    @DWero any news to report??
    :fingerscrossed::fingerscrossed:
  5. Aug 28, 2022 at 6:42 PM
    #125
    Falkor1
    Falkor1 Well-Known Member
    David
    Arizona
    95.5 Tacoma 2.7 4x4
    2,000 Tacoma rear axle with E-Locker.
    Have you checked the fuse that is connected to you distributor and igniter? My 2.7 has a 30 amp fuse for the distributor, igniter and fuel pump. It kept blowing and turned out to be a bad condenser in my distributor.
  6. Aug 29, 2022 at 9:55 AM
    #126
    DWero
    D
    Yeah, unfortunately, with this truck no longer a daily driver it got pushed aside while I worked on a new (used) '99 4Runner Limited for my daughter. With the looks of the inside of the engine/valves, I may throw in the towel and take it to a motor shop. As mentioned a few times in this thread, I don't think there is a repair I can't do on this truck, if I'm told what repair to do. However, with my troubleshooting skills being pretty nonexistent, I need to be told what to do. I still probably will perform a compression test, for curiosity sake, and I will check out the fuse Falkor1 suggested, but know I checked fuses and tested relay operation at the beginning of this project. I may still have a look at the ignition relay and fuses, which I think is what Falkor1 suggested, but worth another look. This is too nice of a truck to dump, especially since it was deceased father in-law's truck, so I will get it running again some day... it just depends on whether I fix it or pay someone to do it for me. Thanks again for all of the feedback and suggestions! Not throwing in the towel yet, but pretty close.
  7. Aug 29, 2022 at 10:48 AM
    #127
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Don't give up!
    The more you learn the more you can do -- and the more you do the more you learn --
    -- or something like that... :notsure: :goingcrazy:
    Seriously, when I find myself muddled I try to step back, clear my head and start again at the beginning.
    Verify 100% that you have the 3 basic requirements to run:
    Compression
    Spark
    Fuel
    Once you figure out which one is missing the direction will become clearer. There are plenty of folks here familiar with that engine (not me unfortunately) to give you advice when you find out which one is missing.
    To do a compression test use the following steps:
    1) insure the battery is fully charged
    2) disable fuel - pull fuel pump fuse or relay
    3) disable ignition - should be a fuse
    4) remove all spark plugs
    5) block throttle wide open
    6) crank engine approximately the same number of times for each cylinder
    Record the readings, as a general rule the pressure should be around 130 - 160 psi and the lowest should be within 10% of the highest.
    If you have a cylinder that is suspiciously low pump a squirt or two of engine oil in the cylinder and test it again, if the reading stays about the same it usually indicates a valve problem, if it rises the rings are suspect.
    Two cylinders adjacent with identical low readings will usually be a blown head gasket.
    You are also doing some supplemental troubleshooting as you do the test -- the engine should crank about the same for each cylinder as you do the test, if one sounds different than the rest it will catch your ear.
    I had an old Jeep V8 suddenly start running rough years ago, in doing a compression test I found one cylinder with zero compression and when it stopped cranking I could hear a sucking noise. :confused:
    I removed the valve cover and found a broken rocker arm on the intake valve, easy fix.
  8. Aug 29, 2022 at 2:54 PM
    #128
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Not a bad idea, specifically the clearing of the mind and then retracing..helped me with a few real buggers.
    DWero[OP] and RustyGreen[QUOTED] like this.
  9. Aug 29, 2022 at 5:10 PM
    #129
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I always taught the kids at work when faced with an overwhelming problem (wiring for example) to "make it modular".
    Do the parts of the job that you understand and are comfortable with first, ground wires for example, this 1) gets you feeling more comfortable doing the work 2) eliminates some of the confusing visual clutter.
    As you chip away at the easier jobs the hard ones should become clearer.
  10. Aug 29, 2022 at 8:01 PM
    #130
    Falkor1
    David
    Arizona
    95.5 Tacoma 2.7 4x4
    Failure is just a step toward success.
  11. Aug 29, 2022 at 8:02 PM
    #131
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i doubt those valves will hold compression for long...the rust is going to start chipping off
  12. Aug 30, 2022 at 1:30 PM
    #132
    DWero
    D
    Thanks for the continued replies and support! Yes, I've done many things where stepping away, even if for 10 minutes, makes a world of difference. For instance, I just replaced the rear upper and lower control arm bushings (among lots of other repairs/job) on the '99 4Runner Limited I recently got for my daughter. I had done this same job on my '97 4Runner, so I had a little experience at it. Well, I had the hardest time getting the rear axle to move the way I wanted to enable me to extract the bolts without jacking up the threads. For each side I had to move the axle forward and backwards, which I don't recall having to do on the '97. I swear I spent more time with strap placement than I did making the actual repair. Regardless, I got stuck and could not get the lower control arm nut out on the passenger side. I went inside, took a 10 minute break, and bam! Got the axle to move the direction I wanted and got the bolt out in 5 minutes.
    So let's say the compression test is not good, or the valves are too rusty/jacked up? Then what? That's why I'm almost resigned to the fact that the compression test won't go well, and thinking ahead to the next step... but I'll still check it first, as it will be a great lesson. Thanks again guys!
    RustyGreen likes this.
  13. Aug 30, 2022 at 1:33 PM
    #133
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Where I used to live, fuel being siphoned from vehicles was a huge problem so a bunch of us started leaving a very sugary 5L jerry can in the bed of the truck, unlocked and just begging to be stolen.
    DWero[OP] and TartanEagle like this.
  14. Aug 31, 2022 at 12:17 AM
    #134
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Pull cylinder heads and inspect pistons and bore. Have cylinder heads rebuilt, exchange for reconditioned heads or used heads. Assuming bores and pistons look ok. Or replace engine with rebuilt or used.
    DWero[QUOTED][OP] likes this.
  15. Aug 31, 2022 at 12:38 AM
    #135
    StrangeDuck
    StrangeDuck Well-Known Member
    San Diego
    07 Prerunner AC TRD Offroad; 4.0 6-speed
    265/75 Bridgestone Dueler ATs, 5100s all around, OME 883s front, EL095R Dakars rear (overload removed), custom sliders, Clazzio seat covers, Softopper, KB Voodoo URTC
    I would go with a leakdown test after a bad compression test and before pulling things apart. That would give you an idea of what to expect.
  16. Aug 31, 2022 at 12:56 AM
    #136
    5efvz
    5efvz Well-Known Member
  17. Aug 31, 2022 at 6:46 PM
    #137
    mechanicjon
    Jon
    Scottsdale Arizona
    Good point. I missed that step.
    StrangeDuck[QUOTED] likes this.
  18. Sep 1, 2022 at 7:28 AM
    #138
    DWero
    D
  19. Sep 1, 2022 at 7:29 AM
    #139
    DWero
    D
    I don't know what a leakdown test is, but I'll look into it. Thanks!
  20. Nov 11, 2022 at 2:40 AM
    #140
    RustyGreen
    sleeping in a chair
    Pavement Princess
    @DWero
    Any progress to report? :fingerscrossed:
