Potential issue?
Discussion in 'ICON Vehicle Dynamics' started by rogerkamp8817, Apr 27, 2014.
  1. Apr 27, 2014 at 9:48 PM
    rogerkamp8817
    rogerkamp8817 [OP] Well-Known Member
    Orange County, California
    2010 Toyota TRD Off-Road 4x4, AC, Superwhite
  2. Apr 30, 2014 at 2:58 PM
    rogerkamp8817
    I've retorqued the upper shock mount bolts, lower shock mount bolts, removed the sway bar completely, checked my wheel bearings, greased upper and lower control arm bushings. I've also gone as far as replacing the lower control arm completely with an aftermarket control arm.
    The noise is still there. Could it be the shocks themselves making this noise?
    Thanks
    https://www.youtube.com/watch?v=MgPSKZGHgKA
  3. May 2, 2014 at 10:53 PM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    Roger...I have an ICON setup as well and I hear a noise when I go over bumps. Even though you have greased the UCA's, I think as they pivot up and down because of the urethane bushings they make a noise. I have a buddy with Fox coil-overs and he has to grease his UCA bushings on a monthly basis to minimize the noise. They are compressed fairly tight and I believe that might be the culprit. Not to say that anything is wrong...but it might just be a normalcy with our type of setup. Just my 2 cents...:D Great camera angles btw. Perhaps you should try to mount your camera focused up by the UCA bushings and see if it can be better detected visually and audible wise...
  4. May 3, 2014 at 2:09 PM
    rogerkamp8817
    Thanks for the response. It is reassuring to hear that the noise might be normal.
    I did take a shot of the UCA. Here is the video that I recorded. You can see that the sway bar is removed completely in this shot as well.
    https://www.youtube.com/watch?v=0o48LwujwsY
  5. May 3, 2014 at 2:58 PM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    I might try and mount my GoPro under the wheel well also and see if I can replicate it. What type of mount did you use? I have the suction mount, but no clamp mount right now. I might need to acquire one though:D I'll post a vid once I get a shot and figure out the best mount points..
  6. May 3, 2014 at 3:18 PM
    rogerkamp8817
    I used one of those sticky-tape mounts. Here is where I put it. I cleaned off the surface with a rag and just pressed it on as hard as I could. It feels really secure but still little scary thinking about my GoPro falling off and getting ran over.
  7. May 3, 2014 at 3:24 PM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Figured it out with what I got:D
    Don't mind the blue painters tape. Im derping the pinch weld...:cool:
  8. May 3, 2014 at 3:26 PM
    rogerkamp8817
    That looks like a good angle! I'm looking forward to seeing how your video / sound turns out.
  9. May 3, 2014 at 4:43 PM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Vid is uploading to Youtube right now and I'll post shortly. My initial thoughts are normal UCA flex sounds. You can judge for yourself..:D I would really like to get the camera inside the wheel well up closer, but I'll have to look for a better mount point. Standby...
  10. May 3, 2014 at 5:21 PM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
  11. May 3, 2014 at 5:24 PM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Hope it helps!:D I'm gonna have a buddy of mine who is an expert at this stuff watch the vids and chime in...
  12. May 4, 2014 at 9:25 AM
    rogerkamp8817
    Thanks for the video. I hear some similarities, but the popping/clunking noise sounds much louder with my truck.
  13. May 4, 2014 at 11:10 AM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Yeah...I agree. I wonder if it's something in the drivetrain...not sure...:confused:
  14. May 5, 2014 at 8:09 AM
    icon_rep
    icon_rep ICON Vehicle Dynamics Vendor
    Riverside, CA
    Roger,
    Have you called us yet and spoken to anyone here? We would be happy to take a look at the shocks and see if it is a culprit. One thing you can check prior to removal is the nitrogen level. Make sure the shocks are charged (and holding a charge) at 250psi.
    Feel free to give me a call at 951-689-4266
    Brad
  15. May 5, 2014 at 8:21 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    He doesnt seem upset he was just asking about the noise, and a ICONREP sees the thread and just to make sure it want their fault they offer help without being notified of anything. This is why I love ICON and will buy them again and again. Yall are great guys up there thanks for helping me when ive needed it and offering help for others.
    Bchncar likes this.
  16. May 5, 2014 at 9:24 AM
    rogerkamp8817
    Hi Brad,
    Thanks for the response. Do you know if any shops around Huntington Beach that can check the nitrogen pressure? Additionally, can they fill it up to 250 psi without removing the shocks from the truck? Can I just purchase the nitrogen charge port device and have like a welding shop with nitrogen fill it up for me? Can I drive my truck to your shop to get them filled without removing the shock?
    This is my only vehicle so I'm trying to find ways to make this work.
    Thanks,
    Roger
  17. May 5, 2014 at 9:52 PM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Roger after watching the video several times It appears that there might be some play in the bolt that's holding your LCA. If you watch the first video closely, focus on the Lower part of the picture where the bolt it (31 sec's in). There's a large washer directly inline with the bolt that is moving back and forth (moving towards the front and then towards the rear. It looks loose! I hope I am wrong, but it's an observation. It's 31 seconds in to the first video you posted. Looks like there's a gap moving back and forth as you turn the wheel that may be coming in contact with something causing the noise.
  18. May 5, 2014 at 9:59 PM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Remember since your GoPro is mounted low it seems to be picking up that sound near the LCA I believe. The shock looks to be performing normal, but the sound seems to be originating down low...
  19. May 5, 2014 at 10:02 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Yeah, that looked like the LCA pivot was moving around a lot in that first vid, but he also replaced the entire LCA with a Total Chaos LCA, with poly bushings in the 2nd vid.
    But it did look like the clunking sound coincided with the LCA bolt moving around.
  20. May 5, 2014 at 10:04 PM
    icon_rep
    Riverside, CA
    You have remote reservoir coilovers and they do not have a charge port like the non res versions. Yours have a standard schrader (just like a tire) that almost anyone can fill. You can come by our shop and we will do it for you and also fluid check them. Just give me a call if that is what you decide to do.
