Potential issue?
Discussion in 'ICON Vehicle Dynamics' started by rogerkamp8817, Apr 27, 2014.
  1. May 5, 2014 at 10:04 PM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    I didn't review the second vid that closely, but I will... He should check that out. Thanks Iven..:)
  2. May 5, 2014 at 10:11 PM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Roger, I realized a made my comment based on your first LCA vid, but it really seemed plausible. Even the second vid, which is short and not as well lighted seemed to have the sound originating from the LCA pivot. Can you take a better lighted vid focused on the LCA pivot and see if there is some play and noise being generated there? It would be nice to weigh that factor out of the equation, but that might be the culprit??:confused:
  3. May 7, 2014 at 2:56 PM
    rogerkamp8817
    rogerkamp8817 [OP] Well-Known Member
    Orange County, California
    2010 Toyota TRD Off-Road 4x4, AC, Superwhite
    thanks for all the responses. work has been keeping me busy.
    i thought the same thing about the noise coming from the lower control arm pivot (alignment bolts). I thought the bushings were bad. instead of replacing the bushings, which didn't look very easy, i went ahead and replaced the entire lower control arm.
    i called Brad with Icon and he's been very eager to help. I appreciate the great service!
  4. May 7, 2014 at 6:40 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I love those LCAs tho :)
  5. May 7, 2014 at 10:22 PM
    rogerkamp8817
    thanks. here are some pics of the replacement lower control arm
  6. May 7, 2014 at 11:12 PM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Roger...those ROCK!:D Btw...did you solve the mystery of the sound???:confused:
  7. May 7, 2014 at 11:44 PM
    bullaculla
    Da big big island!
    My bad, I previously referred to them as TC LCAs, never seen pics of the DKs up close.
  8. May 8, 2014 at 12:13 AM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    You're forgiven...don't let it happen again...:D
  9. May 8, 2014 at 8:15 AM
    rogerkamp8817
    i have not figured it out yet. i'll keep you guys posted on how things turn out.
  10. May 15, 2014 at 10:09 AM
    Creole Knight
    Creole Knight Man's got to know his limitations.
    Ulysses
    So. Cal
    05 Super White PreRunner
    gear shift knob and other things.
    Hey Roger, been awhile I asked you a question about your UCA's toward the end of last year and I thank you for the answer. I did go with the Dirt King lower and upper control arms and other than having a shorter turning radius I love the whole set up the feel of the combonation is amazing feels like I driving a sports car rather than a lifted truck. I have not had any problems with the D/K's or the Icon's although I have the extended travel no Resi's. Anyway I hope you find the problem and it's nothing critical, I had my uppers and lowers installed by OutlawOffroad in Anahiem. Good Luck to you Roger.
  11. May 23, 2014 at 9:04 PM
    rogerkamp8817
    Thanks!
    I've been in contact with Icon. They've been very helpful. I'm trying to find time to get the shocks off my truck. I'll be sure to report back with what I find.
  12. May 23, 2014 at 11:12 PM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Hope the new shock solves it! ICON has been amazing! I had a bad shock that started rusting and they sent me a new one, no questions asked! They sent me a new one in the mail and it was the one w/o the CDC valve, but I had to put it on, since the rusted one was being sent back. Now they are sending me the one I originally bought with the CDC...again...no problem. Talk about someone standing behind their products!!
    Good Luck with yours!:D
  13. May 26, 2014 at 11:00 AM
    rogerkamp8817
    The noise is no longer there!
    I upgraded to reservoirs with CDC. The compression control definitely makes a big difference. My on-road ride quality has improved, specifically on pavement in poor condition or freeways with concrete panels. The truck reacts to them in a much more controlled manner now :D
    I'm going to send the old shocks to Icon to get them to take a look at them. They've been nothing but great with helping me out with the upgrades and communicating with me. I'm very pleased with their service.
    The old shocks will likely be put up for sale after Icon looks at them.
  14. May 26, 2014 at 11:06 AM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Outfuckingstanding!!!
    :woot::bananadance::dancingbacon:
  15. May 26, 2014 at 11:12 AM
    #35
    rogerkamp8817
    I was planning on getting an alignment done; however, with the new shocks, the truck drives like it is still aligned. Steering wheel is straight. The final height from ground to fender is only about half an inch different, at most. The springs are probably still settling. Should I get it realigned just to be safe or is it a waste of money? Truck drives straight as an arrow on the freeway still.
    Now I need to start thinking about my rear suspension. I'm currently running the factory 3 leaf + TSB with Bilstein 5100's. I'm not sure which direction I should go with it...
    1) Replace the entire leaf pack and go with the Icon 2.5 in CDC's
    2) Replace the leaf pack and get a shock hoop installed to use longer shocks.
    3) Convert to spring-under, replace leaf pack (given), install shock hoops, and go with longer shocks.
    I don't want to run an add-a-leaf or cut into the bed. I'm leaning towards the second option right now.
  16. May 26, 2014 at 11:26 AM
    #36
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Get it aligned!! It's a small price to pay for having tires wearing prematurely:D
  17. Jun 1, 2014 at 9:17 AM
    #37
    Creole Knight
    Ulysses
    So. Cal
    Hey Roger, I'm glad to see you got it fixed, how do you like your lower control arms, when I had them installed I was very pleased and it still drives like a sports car even with 35" trail grapps. I am thinking of going with the CDC's do you have them on just the front or the rear to.
  18. Jun 1, 2014 at 9:56 AM
    #38
    rogerkamp8817
    the lower control arms are great. very beefy. the uniballs are tight, but it sounds like that is typical when you upgrade to any kind of uniball control arms.
    i only have the CDC's on the front for now.
  19. Jun 1, 2014 at 10:13 AM
    #39
    Creole Knight
    Ulysses
    So. Cal
    Thank's Roger, you have a damn nice setup I like the way it looks in your well nice job man.
  20. Jun 11, 2014 at 7:53 PM
    #40
    rogerkamp8817
    I sent these shocks into Icon for service (under warranty). They've been very helpful and assisted me with the whole process.
    They check the shocks for nitrogen and oil levels, took it apart, and didn't find any issues.
    I'm thinking it was something else with my suspension that was making the noise. While reinstalling the new pair of shocks, I was extra diligent with taking my time, torqueing everything, and applying grease where needed. I'm thinking it could have been the UCA bolt where the UCA connects to the shock tower. I went heavy on the grease where the UCA bolt goes through the shock tower. I feel that even though I greased the UCA zerks, the grease couldn't really get into the shock tower where it was needed. I don't really know for sure...
    Anyways, I like to thank Icon for their support and service. They've been great and went above and beyond to help me out. I highly recommend them.
